While running tests for a python tool, the tests' outputs get printed in
whatever order they happen to run, without any indication as to which
output belongs to which test. Unittest supports capturing these outputs
and printing them as part of the test summaries, but when a failure or
error occurs it switches back to printing as the tests run. Testtools
and subunit tests can do the same as their parts inherit from unittest,
but they don't outright expose this functionality.
On the unittest side, enable output buffering for the custom test result
class. Try to avoid ugly outputs by not printing stdout/stderr before
the test summary for low verbosity levels and for successful tests.
On the subunit side, implement a custom TestProtocolClient that enables
the same underlying functionality and injects the captured streams as
additional test details. This causes them to be merged into their test's
error traceback message, which is later rebuilt into an exception and
passed to our unittest report class.
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
Fix pylint errors that can be fixed and mask those that seem to be
incorrect.
This gives a warning in some situations:
File "tools/dtoc/../concurrencytest/concurrencytest.py", line 95,
in do_fork
stream = os.fdopen(c2pread, 'rb', 1)
File "/usr/lib/python3.8/os.py", line 1023, in fdopen
return io.open(fd, *args, **kwargs)
RuntimeWarning: line buffering (buffering=1) isn't supported in binary
mode, the default buffer size will be used
Fix this by dropping the line-buffer parameter.
Remove incorrect indentation.
At present the tests run one after the other using a single CPU. This is
not very efficient. Bring in the concurrencytest module and run the tests
concurrently, using one process for each CPU by default. A -P option
allows this to be overridden, which is necessary for code-coverage to
function correctly.
This requires fixing a few tests which are currently not fully
independent.
At some point we might consider doing this across all pytests in U-Boot.
There is a pytest version that supports specifying the number of processes
to use, but it did not work for me.
