Add an option to specify the output directory to override the
default path '../'. This is useful for building in a ramdisk.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
A common use-case is to build all boards for a particular SoC. This can
be achieved by:
./tools/buildman/buildman -b mainline_dev tegra20
However, when the SoC is a member of a family of SoCs, and each SoC has
a different name, it would be even more useful to build all boards for
every SoC in that family. This currently isn't possible since buildman's
board selection command-line arguments are compared to board definitions
using pure string equality.
To enable this, compare using a regex match instead. This matches
MAKEALL's handling of command-line arguments. This enables:
(all Tegra)
(all Tegra)
./tools/buildman/buildman -b mainline_dev '^tegra.*$'
(all Tegra20, Tegra30 boards, but not Tegra114)
./tools/buildman/buildman -b mainline_dev 'tegra[23]'
This is a trivial fix for c'n'p error.
python used in buildman doesn't need to be placed in
/usr/bin/python, So use env to ensure that the interpreter
will pick the python from environment.
Usefull with several versions of python's installed on system.
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
When a toolchain invocation fails, an exception is thrown but not caught
which then aborts the entire toolchain detection process. To solve this,
request that exceptions not be thrown, since the toolchain init code
already error-checks the command result. This solves e.g.:
- found '/usr/bin/winegcc'
Traceback (most recent call last):
Exception: Error running '/usr/bin/winegcc --version'
Change-Id: I579c72ab3b021e38b14132893c3375ea257c74f0
(formatted to 80cols)
There are a few make options such as BUILD_TAG which can be provided when
building U-Boot. Provide a way for buildman to pass these flags to make
also.
The flags should be in a [make-flags] section and arranged by target name
(the 'target' column in boards.cfg. See the README for more details.
Commit 27af930e9a5c91365ca639ada580b338eabe4989 changed the boards.cfg format
but missed to change the parsing in buildman. A follow-on commit
03c1bb242548e4e9d267d784861ccd69a1887aa0 fixed this but missed fixing the
tests.
This patch updates the tests to fit the new Board constructor.
./tools/buildman/buildman -t
<unittest.result.TestResult run=1 errors=0 failures=0>
This patch changes c'tor of Board class to the new sequence, but omits
maintainer field.
Put all informations about targets, including state (active or
orphan) and maintainers, in boards.cfg; remove MAINTAINERS;
adjust the build system accordingly.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
[trini: Fixup common/cmd_io.c]
Rather than a backtrace, produce a nice error message when an invalid
branch is provided to buildman.
Conflicting tags can prevent buildman from building two series which exist
one after the other in a branch. There is no reason not to allow this sort
of workflow with buildman, so ignore conflicting tags in buildman.
Change-Id: I2231d04d8684fe0f8fe77f8ea107e5899a3da5e8
Reviewed-by: Tom Rini <trini@ti.com>
This tool handles building U-Boot to check that you have not broken it
with your patch series. It can build each individual commit and report
which boards fail on which commits, and which errors come up. It also
shows differences in image sizes due to particular commits.
Buildman aims to make full use of multi-processor machines.
Documentation and caveats are in tools/buildman/README.
