path: root/tools/bmp_logo.c
2009-07-19compiler.h: unify system ifdef cruft hereMike Frysinger
Shove a lot of the HOSTCC and related #ifdef checking crap into the new compiler.h header so that we can keep all other headers nice and clean. Also introduce custom uswap functions so we don't have to rely on the non standard implementations that a host may (or may not in the case of OS X) provide. This allows mkimage to finally build cleanly on an OS X system. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-28bmp_logo: Check return value of fread()Peter Tyser
Add basic error handling to fread() function calls. This prevents compililation warnings such as: bmp_logo.c: In function ‘main’: bmp_logo.c:71: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2005-09-25Fix tools/bmp_logo.c using incorrect offset to pixel dataWolfgang Denk
Patch by Andrew Dyer, 31 Jan 2005
2004-10-09* Clean up tools/bmp_logo.c to not add trailing white spacewdenk
* Patch by Hinko Kocevar, 21 Aug 2004: - Group common framebuffer functions in common/lcd.c - Group common framebuffer macros and #defines in include/lcd.h - Provide calc_fbsize() for video ATAG
2003-10-30* Fix parameter passing to standalone images with bootm commandU-Boot-1_0_0wdenk
* Patch by Kyle Harris, 30 Oct 2003: Fix build errors for ixdp425 board * Patch by David M. Horn, 29 Oct 2003: Fixes to build under CYGWIN * Get IceCube MGT5100 working (again)
2002-03-14Initial revisionwdenk
