path: root/tools/binman
2018-07-09binman: Support updating the device tree with calc'd infoSimon Glass
It is useful to write the position and size of each entry back to the device tree so that U-Boot can access this at runtime. Add a feature to support this, along with associated tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Add a SetCalculatedProperties() methodSimon Glass
Once binman has packed the image, the position and size of each entry is known. It is then possible for binman to update the device tree with these positions. Since placeholder values have been added, this does not affect the size of the device tree and therefore the packing does not need to be performed again. Add a new SetCalculatedProperties method to handle this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Add a ProcessFdt() methodSimon Glass
Some entry types modify the device tree, e.g. to remove microcode or add a property. So far this just modifies their local copy and does not affect a 'shared' device tree. Rather than doing this modification in the ObtainContents() method, and a new ProcessFdt() method which is specifically designed to modify this shared device tree. Move the existing device-tree code over to use this method, reducing ObtainContents() to the goal of just obtaining the contents without any processing, even for device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Complete documentation of stagesSimon Glass
At present one of the stages is badly numbered and not described. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Move capture_sys_output() to test_utilSimon Glass
This function is useful in various tests. Move it into the common test utility module. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Move coverage logic into a new test_util fileSimon Glass
At present only binman has the logic for determining Python test coverage but this is useful for other tools also. Move it out into a separate file so it can be used by other tools. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Tidy up setting of entry contentsSimon Glass
At present the contents of an entry are set in subclasses simply by assigning to the data and content_size properties. Add some methods to do this, so that we have more control. In particular, add a method to set the contents without changing its size, so we can validate that case. Add a test case for trying to change the size when this is not allowed. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Tidy up execution of testsSimon Glass
Move all the test execution into the same mechanism so that we can request a particular test (from any suite) by passing it as an argument to 'binman -t'. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Correct operation of ObtainContents()Simon Glass
This method is supposed to return the contents of an entry. However at present there is no check that it actually does. Also some implementations do not return 'True' to indicate success, as required. Add a check for things working as expected, and correct the implementations. This requires some additional test cases to cover things which were missed originally. Add these at the same time. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Tidy up variables in _RunMicrocodeTest()Simon Glass
At present we call the three entries first, second and third. Rename them to reflect their contents instead, for clarity. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Make the operation of Entry__testing explicitSimon Glass
This fake entry is used for testing. At present it only has one behaviour which is to return an invalid set of entry positions, to cause an error. The fake entry will need to be used for other things too. Allow the test .dts file to specify the behaviour of the fake entry, so we can control its behaviour easily. While we are here, drop the ReadContents() method, since this only applies to subclasses of Entry_blob, which Entry__testing is not. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09binman: Switch to 'python-coverage'Tom Rini
The most portable way to get access to coverage is to invoke it as 'python-coverage'. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Mark 'align-end' as implementedSimon Glass
The documentation says this is not implemented, but it is. Update the documentation, and clarify its operation. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Add support for adding a name prefix to entriesSimon Glass
Sometimes we have several sections which repeat the same entries (e.g. for a read-only and read-write version of the same section). It is useful to be able to tell these entries apart by name. Add a new 'name-prefix' property for sections, which causes all entries within that section to have a given name prefix. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Add support for outputing a map fileSimon Glass
It is useful to be able to see a list of regions in each image produced by binman. Add a -m option to output this information in a '.map' file alongside the image file. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Tidy up some docs and commentsSimon Glass
Fix a few missing comments and tidy up some existing ones. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Allow a single test to be executedSimon Glass
Provide an easy way to execute a single binman test by specifying it on the command line. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Add documentation for pos-unset propertySimon Glass
This property is not documented. Add a note to the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Add support for sectionsSimon Glass
It is useful to be able to split an image into multiple sections, each with its own size and position, for cases where a flash device has read-only and read-write portions. Add support for this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Avoid setting sys.path globallySimon Glass
At present we set the Python path at the start of binman so we can read modules in the 'etype' directory. This is a bit messy since it affects 'import' statements through binman. Adjust the code to set the path locally, just where it is needed. Move the 'entry' module in with the other base modules to help with this. It makes more sense here anyway since it does not implement an entry type. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Rename Entry property to 'section'Simon Glass
Entries are now passed a Section object rather than an Image. Rename this property to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Rename ELF parameters to 'section'Simon Glass
We now pass a Section object to these functions rather than an Image. Rename the parameters to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Refactor much of the image code into 'section'Simon Glass
We want to support multiple sections within a single image. To do this, move most of the Image class implementation into a new Section class. An Image contains only a single Section, but at some point we will support a new 'section' entry, thus allowing Sections within Sections. Use the name 'bsection' for the module so we can use 'section' for the etype module. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-07binman: Allow unit addresses for binariesSimon Glass
Allow the same binary to appear multiple times in an image by using the device-tree unit-address feature (u-boot@0, u-boot@1). Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-16tools: Update python "help" tests to cope with "more" odditiesTom Rini
In some cases when "more" is told to page a given file it will prepend the output with: :::::::::::::: /PATH/TO/THE/FILE :::::::::::::: And when this happens the output will not match the expected length. Further, if we use a different pager we will instead fail the coverage tests as we will not have 100% coverage. Update the help test to remove the string in question. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-15dtoc: Allow DTC environment variable to provide path to dtcSimon Glass
The system device-tree compiler may not be new enough to run the tests we use in U-Boot (e.g. with binman). Allow use of a DTC environment variable to point to the correct dtc. If not defined, the dtc on the default PATH is used. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-12binman: Add documentation for the symbol featureSimon Glass
Add this feature to the README. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-12-12binman: Support accessing binman tables at run timeSimon Glass
Binman construct images consisting of multiple binary files. These files sometimes need to know (at run timme) where their peers are located. For example, SPL may want to know where U-Boot is located in the image, so that it can jump to U-Boot correctly on boot. In general the positions where the binaries end up after binman has finished packing them cannot be known at compile time. One reason for this is that binman does not know the size of the binaries until everything is compiled, linked and converted to binaries with objcopy. To make this work, we add a feature to binman which checks each binary for symbol names starting with '_binman'. These are then decoded to figure out which entry and property they refer to. Then binman writes the value of this symbol into the appropriate binary. With this, the symbol will have the correct value at run time. Macros are used to make this easier to use. As an example, this declares a symbol that will access the 'u-boot-spl' entry to find the 'pos' value (i.e. the position of SPL in the image): binman_sym_declare(unsigned long, u_boot_spl, pos); This converts to a symbol called '_binman_u_boot_spl_prop_pos' in any binary that includes it. Binman then updates the value in that binary, ensuring that it can be accessed at runtime with: ulong u_boot_pos = binman_sym(ulong, u_boot_spl, pos); This assigns the variable u_boot_pos to the position of SPL in the image. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-12binman: Support enabling debug in testsSimon Glass
The elf module can provide some debugging information to assist with figuring out what is going wrong. This is also useful in tests. Update the -D option so that it is passed through to tests as well. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-12binman: Adjust size of test SPL binarySimon Glass
This is only 3 bytes long which is not enough to hold two symbol values, needed to test the binman symbols feature. Increase it to 15 bytes. Using very small regions is useful since we can easily compare them in tests and errors are fairly easy to diagnose. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-12binman: Add tests binaries with binman symbolsSimon Glass
For testing we need to build some ELF files containing binman symbols. Add these to the Makefile and check in the binaries: u_boot_binman_syms - normal, valid ELF file u_boot_binman_syms_bad - missing the __image_copy_start symbol u_boot_binman_syms_size - has a binman symbol with an invalid size Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-12binman: Drop a stale comment about the 'board' featureSimon Glass
This feature is now supported. Drop the incorrect comment. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-12binman: Add support for including spl/u-boot-spl-nodtb.binSimon Glass
This file contains SPL image without a device tree. Add support for including this in images. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-12binman: Add support for including spl/u-boot-spl.dtbSimon Glass
This file contains the SPL device tree. Add support for including this by itself in images. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-12binman: Add a function to read ELF symbolsSimon Glass
In some cases we need to read symbols from U-Boot. At present we have a a few cases which does this via 'nm' and 'grep'. It is better to use objdump since that tells us the size of the symbols and also whether it is weak or not. Add a new module which reads ELF information from files. Update existing uses of 'nm' to use this module. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Return non-zero exit code on test failureSimon Glass
Return exit code 1 when test fail so that callers can detect this. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Add add test for using an Intel MRC binarySimon Glass
MRC (Memory Reference Code) is a binary blob used to set up the SDRAM controller on some Intel boards. Add a test for this feature. With this test coverage on binman is back up to 100%. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Add add test for SPL with a microcode pointerSimon Glass
Add a test for this feature. It allows SPL to hold a pointer to the microcode block. This is used for 64-bit U-Boot on x86. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Add a test for x86-start16-splSimon Glass
This allows us to put the 16-bit x86 start-up code in SPL. Add a test for it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Add test for u-boot-spl-bss-padSimon Glass
Add a test that we can pad the BSS with zero bytes. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Check for files missing from test coverageSimon Glass
Files that are never imported are not shown in the test-coverage report. Detect these and show an error. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Increase test coverage back to 100%Simon Glass
Make a minor tweak to fix test coverage. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Add a main program to the testsSimon Glass
Add a main program so that the tests can be executed directly, without going through the main binman program. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Add tests for importlib availabilitySimon Glass
Add a test that the 'entry' module works with or without importlib. The tests are numbered so that they are executed in the correct order. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Set up 'entry' to permit full test coverageSimon Glass
There is a little check at the top of entry.py which decides if importlib is available. At present this has no test coverage. To add this we will need to import the module twice, once with importlib and once without. In preparation for allowing a test to control the importing of this module, remove all global imports of the 'entry' module. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Append to PYTHONPATH when running test coverageSimon Glass
Rather that overwrite this, append to it, in case the caller has already set up the path correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Rename tests to ftestSimon Glass
At present these tests use the same filename as patman. This adds confusion when running all tests, since error messages look very similar. In fact binman tries to run the wrong tests at present. Rename the tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Add a Makefile for test-program compilationSimon Glass
These test programs are includedd as binary files in U-Boot to avoid having to build them (and associated toolchain differences). Instructions on building are in the files themselves, but it seems better to provide a Makefile which can be manually run when desired. Add a Makefile, separate from the normal build system, to handle this. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22binman: Add docs explaining how to enable binman for a boardSimon Glass
The process is not obvious. Add a little section to explain how to move a board to use binman. Signed-off-by: Simon Glass <sjg@chromium.org>
