Many entries start 'Entry containing a'. This looks fine in the source
code but is annoying when viewed in the htmldocs table of contents. Drop
these unnecessary words.
Many of the existing blobs rely on external binaries which may not be
available. Move them over to use blob_ext to indicate this.
Unfortunately cros-ec-rw cannot use this class because it inherits
another. So set the 'external' value for that class.
While we are here, drop the import of Entry since it is not used (and
pylint3 complains).
It is easier and less error-prone to use super() when the parent type is
needed. Update binman to remove the type names.
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing
changes made to 56d37f1c564107e27d873181d838571b7d7860e7.
Unfortunately this is causing CI failures:
https://travis-ci.org/github/trini/u-boot/jobs/711313649
pylint3 complains).
At present binman sets the python path on startup so that it can access
the libraries it needs. If we convert to use absolute imports this is not
necessary.
Move binman to use absolute imports. This enables removable of the path
adjusting in Entry also.
Some platforms use this instead of FSP to set up the platform, including
memory. Add support for this in binman. This is needed for
chromebook_samus, for example.
