path: root/tools/bddb/donew.php
2014-10-27ppc: Zap Hymod boardMarek Vasut
Remove this board as this is the only one last user of eeprom_probe(), which is pretty non-standard stuff. This patch also removes all the PHP, SQL and CSS stuff from U-Boot, which probably makes U-Boot a bit less IoT ;-) Signed-off-by: Marek Vasut <marex@denx.de> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de>
2005-08-12Update Hymod Board Database PHP code in "tools" directoryWolfgang Denk
Patch by Murray Jensen, 01 Jul 2005
2005-08-12Fix Murray Jensen's mail address.Wolfgang Denk
Patch by Murray Jensen, 30 Jun 2005
