path: root/tools/atmelimage.c
2016-05-02Change my mailaddressAndreas Bießmann
I'll switch my mails to my own server, so drop all gmail references. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-28tools/atmelimage.c: Fix warning when debug is enabledTom Rini
Otherwise we get: tools/atmelimage.c:134:3: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘size_t’ [-Wformat=] debug("atmelimage: interrupt vector #%d is 0x%08X\n", pos+1, ^ Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-01-29imagetool: replace image registration function by linker_lists featureGuilherme Maciel Ferreira
The registration was introduced in commit f86ed6a8d52c99bb2d17d3cac1647edca0c4399c This commit also removes all registration functions, and the member "next" from image_type_params struct Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2014-05-27mkimage: add atmelimageAndreas Bießmann
The new atmelimage converts a machine code BLOB to bootable ROM image. Atmel ROM has no sophisticated image format, it only checks the first 7 ARM vectors. The vectors can contain valid B or LDR opcodes, the 6'th vector contains the image size to load. Additionally the PMECC header can be written by the atmelimage target. The parameters must be given via the -n switch as a coma separated list. For example: mkimage -T atmelimage \ -n usePmecc=1,sectorPerPage=4,sectorSize=512,spareSize=64,eccBits=4,eccOffset=36 \ -d spl/u-boot-spl.bin boot.bin A provided image can be checked for correct header setup. It prints out the PMECC header parameters if it has one and the 6'th interrupt vector content. ---8<--- Image Type: ATMEL ROM-Boot Image with PMECC Header PMECC header ==================== eccOffset: 36 sectorSize: 512 eccBitReq: 4 spareSize: 64 nbSectorPerPage: 4 usePmecc: 1 ==================== 6'th vector has 17044 set --->8--- A SPL binary modified with the atmelimage mkimage target was succesfully booted on a sama5d34ek via MMC and NAND. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Heiko Schocher <hs@denx.de> Tested-by: Bo Shen <voice.shen@atmel.com>
