path: root/tools/Makefile
2004-09-28* Patch by Yuli Barcohen, 19 Jul 2004:wdenk
- Fix host tools building in Cygwin environment - Fix header files search order for host tools * Patch by Tom Armistead, 19 Jul 2004: Fix kgdb.S support for 74xx_75x cpu
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-10-30* Fix parameter passing to standalone images with bootm commandU-Boot-1_0_0wdenk
* Patch by Kyle Harris, 30 Oct 2003: Fix build errors for ixdp425 board * Patch by David M. Horn, 29 Oct 2003: Fixes to build under CYGWIN * Get IceCube MGT5100 working (again)
2003-10-08* Patch by Anders Larsen, 18 Sep 2003:wdenk
allow mkimage to build and run on Cygwin-hosted systems * Patch by Frank Müller, 18 Sep 2003: use bi_intfreq instead of bi_busfreq to compute fec_mii_speed in cpu/mpc8xx/fec.c * Patch by Pantelis Antoniou, 16 Sep 2003: add tool to compute fileds in the PLPRCR register for MPC86x
2003-08-17* Make Ethernet autonegotiation on INCA-IP work for all clock rates;U-Boot-0_4_6wdenk
allow selection of clock frequency as "make" target * Implement memory autosizing code for IceCube boards * Configure network port on INCA-IP for autonegotiation * Fix overflow problem in network timeout code * Patch by Richard Woodruff, 8 Aug 2003: Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
2003-08-07Removed tools/gdb from "make all" target. Added make target "gdbtools"dzu
in toplevel directory instead. Removed astest.c from tools/gdb because it is no longer relevant.
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
