The pylibfdt is used by dtoc (and, indirectly by binman), but there
is no reason why it must be generated in the tools/ directory.
Recently, U-Boot switched over to the bundled DTC, and the directory
structure under scripts/dtc/ now mirrors the upstream DTC project.
So, scripts/dtc/pylibfdt is the best location.
I also rewrote the Makefile in a cleaner Kbuild style.
The scripts from the upstream have been moved as follows:
lib/libfdt/pylibfdt/setup.py -> scripts/dtc/pylibfdt/setup.py
lib/libfdt/pylibfdt/libfdt.i -> scripts/dtc/pylibfdt/libfdt.i_shipped
The .i_shipped is coped to .i during building because the .i must be
located in the objtree when we build it out of tree.
Last user of this option went away in commit:
fdc7718999 ("board: usb_a9263: Update to support DT and DM")
In some cases, such as FreeBSD, the path to an alternative dtc needs to
be used. Rather than override the one given in the Makefile on the
command line, make this part of the build configuration.
This should not be printed by default. Prefix it with $(Q).
Fixes ee95d10b: ("fdt: Build the new python libfdt module")
Since commit 3809e302 "Makefile: honor PYTHON configuration properly",
the build commands of libfdt are printed while previously were not.
This adds the missing '--quiet' back.
On some systems `python` is `python3` (for instance, Archlinux). The
`PYTHON` variable can be used to point to `python2` to have a successful
build.
The use of `PYTHON` is currently limited in the Makefile and needs to be
extended in other places:
First, pylibfdt is required to be a Python 2 binding (binman imports
pylibfdt and is only compatible Python 2), so its setup.py needs to be
called accordingly. An alternative would be to change the libfdt
setup.py shebang to python2, but the binding is actually portable. Also,
it would break on system where there is no such thing as `python2`.
Secondly, the libfdt import checks need to be done against Python 2 as
well since the Python 2 compiled modules (in this case _libdft.so) can
not be imported from Python 3.
Note on the libfdt imports: "@if ! PYTHONPATH=tools $(PYTHON) -c 'import
libfdt'; then..." is probably simpler than the currently sub-optimal
pipe.
Reviewed-by: Jonathan Gray <jsg@jsg.id.au>
About a quarter of the files in common/ relate to the environment. It
seems better to put these into their own subdirectory and remove the
prefix.
U-Boot has up until now built with -fpic for the MIPS architecture,
producing position independent code which uses indirection through a
global offset table, making relocation fairly straightforward as it
simply involves patching up GOT entries.
Using -fpic does however have some downsides. The biggest of these is
that generated code is bloated in various ways. For example, function
calls are indirected through the GOT & the t9 register:
8f998064 lw t9,-32668(gp)
0320f809 jalr t9
Without -fpic the call is simply:
0f803f01 jal be00fc04 <puts>
This is more compact & faster (due to the lack of the load & the
dependency the jump has on its result). It is also easier to read &
debug because the disassembly shows what function is being called,
rather than just an offset from gp which would then have to be looked up
in the ELF to discover the target function.
Another disadvantage of -fpic is that each function begins with a
sequence to calculate the value of the gp register, for example:
3c1c0004 lui gp,0x4
279c3384 addiu gp,gp,13188
0399e021 addu gp,gp,t9
Without using -fpic this sequence no longer appears at the start of each
function, reducing code size considerably.
This patch switches U-Boot from building with -fpic to building with
-fno-pic, in order to gain the benefits described above. The cost of
this is an extra step during the build process to extract relocation
data from the ELF & write it into a new .rel section in a compact
format, plus the added complexity of dealing with multiple types of
relocation rather than the single type that applied to the GOT. The
benefit is smaller, cleaner, more debuggable code. The relocate_code()
function is reimplemented in C to handle the new relocation scheme,
which also makes it easier to read & debug.
Taking maltael_defconfig as an example the size of u-boot.bin built
using the Codescape MIPS 2016.05-06 toolchain (gcc 4.9.2, binutils
2.24.90) shrinks from 254KiB to 224KiB.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: u-boot@lists.denx.de
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Tested-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
FreeBSD recently switch to it's BSDL dtc. While it support most of the
features of the GPL one it still lacks the incbin directive.
Add the possibility to specify which dtc we want to use for compiling dts
and generating fit image.
Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
This is no-longer needed, so stop building it.
Build the upstream python libfdt module. At present the legacy module is
still built and is the one that it used. Future work will switch this
over.
Now that this module has been accepted upstream we should stop using the
local U-Boot one. In preparation for this, rename it to indicate it is for
legacy use.
At present only a subset of source files are build. Add the rest and
refactor this so that a source file list is available also. This will be
used in later commit.
Not force to use python from PATH. Issue was noted when building with
Yocto, because python from the distro is always taken instead of
python-native built during Yocto process.
CC: Simon Glass <sjg@chromium.org>
This program generates raw SPL images that can be flashed on the NAND with
the ECC and randomizer properly set up.
This has been copied (and tweaked to find the right headers) from the
sunxi-tools (https://github.com/linux-sunxi/sunxi-tools) upstream
repository, commit 1c3a6ca5.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
When building u-boot tools in cross-build environment CFLAGS environment
variable set up for target is taken into an account when building code
for host. Make it empty on invocation of python.
This fixes the following build errors when cross-compiling for xtensa:
cc1: error: unrecognized command line option "-mlongcalls"
cc1: error: unrecognized command line option "-mauto-litpools"
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Richard reported U-Boot tools issues in OpenEmbedded/Yocto project.
OE needs to be able to change the default compiler. If we pass in
HOSTCC through the make command, it overwrites all HOSTCC instances,
including ones in tools/Makefile and tools/env/Makefile, which breaks
"make cross_tools" and "make env", respectively.
Add "override" directives to avoid overriding HOSTCC instances that
really need to point to the cross-compiler.
Reported-by: Richard Purdie <richard.purdie@linuxfoundation.org>
This define is not used in tools sources and can be removed
to avoid unnecessary link between tools and defconfig
The previous commit ("add a new command to show .config contents")
improves the basic infrastructure of "embed a compressed file into
the U-Boot image, and print it by a command". The same pattern for
the "license" command.
This commit reworks the command to improve the following:
[1] Improve log style
Kbuild style log
GZIP cmd/license_data.gz
CHK cmd/license_data_gz.h
UPD cmd/license_data_gz.h
CHK cmd/license_data_size.h
UPD cmd/license_data_size.h
instead of the bare Make log:
cat ./Licenses/gpl-2.0.txt | gzip -9 -c | \
tools/bin2header license_gzip > ./include/license.h
[2] Collect related code into the "cmd" directory
Prior to this commit, the license.h was created by tools/Makefile,
placed under the "include" directory, included from cmd/license.c,
and deleted by the top-level Makefile. It is not a good idea to
scatter related code.
[3] Drop the fixed-malloc size LICENSE_MAX
Just allocate the minimum required size of buffer because we know
the size of the original gpl-2.0.txt.
[4] Fix more issues
Terminate the buffer with zero to prevent puts() from over-running.
Add "static" to do_license.
This patch adds a little tool that takes a generic MAC address and
generates a CRC byte for it. The output is the full MAC address without
any separators, ready written into an EEPROM.
Signed-off-by: Olliver Schinagl <o.schinagl@ultimaker.com>
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
This patch enables crc8 to be used from within the tools directory using
u-boot/crc.h.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
The patch implements secure booting for the mvebu architecture.
This includes:
- The addition of secure headers and all needed signatures and keys in
mkimage
- Commands capable of writing the board's efuses to both write the
needed cryptographic data and enable the secure booting mechanism
- The creation of convenience text files containing the necessary
commands to write the efuses
The KAK and CSK keys are expected to reside in the files kwb_kak.key and
kwb_csk.key (OpenSSL 2048 bit private keys) in the top-level directory.
Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc>
Signed-off-by: Mario Six <mario.six@gdsys.cc>
When we have python building tools for the host it will not check HOSTXX
variables but only XX variables, for example LDFLAGS and not
HOSTLDFLAGS.
Reported-by: Heiko Schocher <hs@denx.de>
Fixes: 1905c8fc711a ("build: Always build the libfdt python module")
Tested-by: Heiko Schocher <hs@denx.de>
Do not rely on CONFIG_SPL_OF_PLATDATA to build the libfdt python module.
If swig is present, this will be build
The Makefile in tools/ tries to find the "swig" utility by calling "which".
If nothing is found in the path, some versions of which will print an error
message:
$ make clean
which: no swig in (/usr/local/bin:/usr/bin:/bin)
This does not apply to all version of "which", though:
$ echo $0
bash
$ type which
which is aliased to `type -path'
$ which foo <== this version is OK
$ /usr/bin/which foo <== this one is chatty
/usr/bin/which: no foo in (/usr/local/bin:/usr/bin:/bin)
$ sh <== make uses /bin/sh
sh-4.3$ which foo <== no alias here
This error message is rather pointless in our case, since we just have
this very check to care for this. So add stderr redirection to suppress
the message.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Commit fed329aebe3a ("tools: add mksunxiboot to tools-all target") added
mksunxiboot to the tools-all target, but used the CONFIG_SUNXI symbol
to enable its build. Now commit aec9a0f19f64 ("sunxi: Rename CONFIG_SUNXI
to CONFIG_ARCH_SUNXI"), merged before that, renamed that symbol, so that
the first patch basically gets ineffective.
Adjust the symbol name in tools/Makefile to make it build again.
mksunxiboot is useful outside of u-boot, it is e.g. used by sunxi-tools.
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
CONFIG_SUNXI -> CONFIG_ARCH_SUNXI
and removed CONFIG_SUNIX from config_whitelist.txt
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
This format can be flashed directly at address 0 of
the NAND FLASH, as it contains all necessary headers.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
When swig is not available, we can still build correctly. So make this
optional. Add a comment about how to enable this build.
Add a Python version of the libfdt library which contains enough features to
support the dtoc tool. This is only a very bare-bones implementation. It
requires the 'swig' to build.
Because a gpimage cannot be detected, a false
GP header is printed instead of checking
for further image types.
Move gpimage as last to be linked, letting check
all other image types and printing a GP header just
in case no image is detected.
Add support for the zynqmpimage to mkimage.
Only basic functionality is supported without encryption and register
initialization with one partition which is filled by U-Boot SPL.
For more detail information look at Xilinx ZynqMP TRM.
The license command isn't usually built and has a few problems:
- The rules to generate license.h haven't worked in a long time,
re-write these based on the bmp_logo.h rules.
- 'tok' is unused and the license text size has increased
- bin2header.c wasn't grabbing unistd.h to know the prototype for
read().
At present this file is omitted. It is used to build up a binary device
tree. We plan to do this in mkimage, so include this file in the build.
Since OpenSSL is deprecated on OS X in favour of Common Crypto API disable the
warning for this host OS.
Another solution would be to add some glue layer for crypto stuff, but I think
this is not worth the effort.
Until now, the SoC selection for the ARCH_MVEBU platforms has been done
in the config header. Using CONFIG_ARMADA_XP in a non-clear way. As
it needed to get selected for AXP and A38x based boards. This patch
now changes this to move the SoC selection to Kconfig. And also
uses CONFIG_ARCH_MVEBU as a common define for both AXP and A38x.
This makes things a bit clearer - especially for new board additions.
Additionally the defines CONFIG_SYS_MVEBU_DDR_AXP and
CONFIG_SYS_MVEBU_DDR_A38X are replaced with the already available
CONFIG_ARMADA_38X and CONFIG_ARMADA_XP.
And CONFIG_DDR3 is removed, as its not referenced anywhere.
Cc: Luka Perkov <luka.perkov@sartura.hr>
This feature was dropped at some point. Restore it.
This reverts commit 10b4615f9d7e177ec7fe644fbb2616e0e0956f6e
Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com>
Our chips may have different max spl size and spl header, so
we need to add configs for that.
Dropped CONFIG_ROCKCHIP_MAX_SPL_SIZE from rk3288_common.h,
Added $(if...) to tools/Makefile to fix widespread build breakage
Series-changes: 8
- Drop CONFIG_ROCKCHIP_MAX_SPL_SIZE from rk3288_common.h,
- Add $(if...) to tools/Makefile to fix widespread build breakage
As with other platforms vendors love to create their own boot header
formats. Xilinx is no different and for the Zynq platform/SoC there
exists the "boot.bin" which is read by the platforms bootrom. This
format is described to a useful extent within the Xilinx Zynq TRM.
This implementation adds support for the 'zynqimage' to mkimage. The
implementation only considers the most common boot header which is
un-encrypted and packed directly after the boot header itself (no
XIP, etc.). However this implementation does take into consideration the
other fields of the header for image dumping use cases (vector table and
register initialization).
Signed-off-by: Nathan Rossi <nathan@nathanrossi.com>
Cc: Michal Simek <michal.simek@xilinx.com>
The Rockchip boot ROM requires a particular file format. It consists of
64KB of zeroes, a 512-byte header encoded with RC4, and then some executable
code.
Add support to mkimage so that an SPL image (u-boot-spl-dtb.bin) can be
converted to this format.
Rockchip SoCs require certain formats for code that they execute, The
simplest format is a 4-byte header at the start of a binary file. Add
support for this so that we can create images that the boot ROM understands.
This is commented out in the Makefile for more than 10 years.
I assume it is proof that this tool is unused.
Cc: Pantelis Antoniou <panto@intracom.gr>
To use this offset for other boot device (like SDIO/MMC), lets rename
it to a more generic name. This will be used be the SDIO/MMC SPL boot
support for the A38x.
Cc: Dirk Eibach <eibach@gdsys.de>
This tool allows us to extract subsets of a device tree file. It is used by
the SPL vuild, which needs to cut down the device tree size for use in
limited memory.
This tool was originally written for libfdt but it has not been accepted
upstream, so for now, include it in U-Boot. Several utilfdt library
functions been included inline here.
If fdtgrep is eventually accepted in libfdt then we can bring that version
of libfdt in here, and drop fdtgrep (requiring that fdtgrep is provided by
the user).
If it is not accepted then another approach would be to write a special
tool for chopping down device tree files for SPL. While it would use the
same libfdt support, it would be less code than fdtgrep.c because it would
not have general-purpose functions.
Another approach (which was used with v1 of this series) is to sprinkler all
the device tree files with #ifdef. I don't like that idea.
Instead of hardcoding -lssl -lcrypto as the flags needed to build
mkimage with FIT signature enabled, use pkg-config when
available. This allows to properly support cases where static linking
is used, which requires linking with -lz, since OpenSSL uses zlib
internally.
We gracefully fallback on the previous behavior of hardcoding -lssl
-lcrypto if pkg-config is not available or fails with an error.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Commit a93648d197df48fa46dd55f925ff70468bd81c71 introduced linker generated
lists for imagetool which is the base for some host tools (mkimage, dumpimage,
et al.). Unfortunately some host tool chains do not support the used type of
linker scripts. Therefore this commit broke these host-tools for them, namely
FreeBSD and Darwin (OS/X).
This commit tries to fix this. In order to have a clean distinction between host
and embedded code space we need to introduce our own linker generated list
instead of re-using the available linker_lists.h provided functionality. So we
copy the implementation used in linux kernel script/mod/file2alias.c which has
the very same problem (cause it is a host tool). This code also comes with an
abstraction for Mach-O binary format used in Darwin systems.
Cc: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
