path: root/tools/Makefile
2011-07-31MIPS: INCA-IP: rename inca-swap-bytes host toolDaniel Schwierzeck
The INCA-IP SoC belongs to the Lantiq XWAY SoC product portfolio. For the upcoming support of other Lantiq SoC devices this tool should not solely depend on the INCA-IP board. Rename the tool to xway-swap-bytes and add an config option to enable compilation optionally. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Thomas Langer <thomas.langer@lantiq.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-07-27digsy_mtc: move board into vendor dir and add vendor logoAnatolij Gustschin
2011-06-22tools: make it possible to build tools unconfiguredMike Frysinger
On Sunday, June 19, 2011 13:55:13 Ilya Yanok wrote: > On 18.06.2011 23:03, Mike Frysinger wrote: > >> - tools/Makefile put common/env_embedded.o and envcrc.o to object list > >> > >> conditionally. This fixes errors during dependency generation. > > > > pretty sure this breaks board builds. if the only thing this fixes is a > > I'm sorry but I can't see how this can break the builds. Could you > please be more specific? I've tried to build some boards, it actually > works... i might be thinking of a different env_embedded situation. a different problem with your patch to tools/Makefile: you copied the same logic multiple times which means more bitrot. why dont you do something like: > > harmless warning when generating dependency files, then i say ignore it. > > after all, this is how it has always worked in the past and no one really > > cared. > > Yep, they are harmless but they are not warnings but rather scary errors > actually. ;) I think it's better to fix them. i guess my threshold for being scared is a bit higher :p -mike
2011-05-13Revert "Fix building tools alone with host compiler"Wolfgang Denk
This reverts commit bbc6353c740064c8e0741b772376a1a67a1c3f01. It breaks building on many systems: ... .../common/env_embedded.c:28:20: fatal error: config.h: No such file or directory compilation terminated. .../common/image.c:27:20: fatal error: common.h: No such file or directory compilation terminated. .../lib/crc32.c:12:20: fatal error: common.h: No such file or directory compilation terminated. .../lib/md5.c:28:22: fatal error: compiler.h: No such file or directory compilation terminated. .../lib/sha1.c:33:20: fatal error: common.h: No such file or directory compilation terminated.
2011-05-12Fix building tools alone with host compilerFrançois Revol
- don't include config.h when building with host cc, - HOSTCFLAGS was defined with the wrong name, so wasn't used, - make sure make finds sources outside of tools/. Signed-off-by: François Revol <revol@free.fr>
2010-11-14Makefile: move include for config.mk upFrançois Revol
Reorder including config.mk before the HOSTCC check, so HOSTCC is actually defined when checking for it. Signed-off-by: François Revol <revol@free.fr> Cleaned up commit message Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-21logos: add Freescale logoTimur Tabi
Add the Freescale logo and update the Makefile to build it when building a Freescale board. Signed-off-by: Timur Tabi <timur@freescale.com>
2010-09-19tools: enable img2srec for "tools-all" targetMike Frysinger
2010-08-10ARM: Add support for jadecpu board based on MB86R01 SoCMatthias Weisser
This patch adds support for the jadecpu board using the MB86R01 'Jade' SoC from Fujitsu. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-04-13Move libfdt/ into lib/Peter Tyser
Move the libfdt directory into the common lib/ directory to clean up the top-level directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-02-12at91: Add esd gmbh OTC570 board supportDaniel Gorsulowski
This patch adds support for esd gmbh OTC570 board. The OTC570 is based on an Atmel AT91SAM9263 SoC. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2010-01-26tools: give explicit libfdt pathsMike Frysinger
The current libfdt object rules hard depend implicitly on the .depend file being correct. If it isn't, then it is unable to properly compile the objects. Give it a full path like all the other implicit rules here so it will always work in face of .depend issues. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-25mkimage: Add Freescale imx Boot Image support (imximage)Stefano Babic
This patch adds support for "imximage" (MX Boot Image) to the mkimage utility. The imximage is used on the Freescales's MX.25, MX.35 and MX.51 processors. Further details under doc/README.imximage. This patch was tested on a Freescale mx51evk board. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-01-21tools: allow people to compile w/out configuringMike Frysinger
It's useful to be able to build up the host tools without having to select a board first. Pretty much all tools in there are config-independent anyways. Also add a shortcut "tools-all" to quickly build all host tools that are actually config-independent to allow for simple test builds. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-12-02makefiles: fixes for building build toolsScott Wood
Currently, some of the tools instead set CC to be HOSTCC in order to re-use some pattern rules -- but this fails when the user overrides CC on the make command line. Also, the HOSTCFLAGS in tools/Makefile are currently not being used because config.mk overwrites them. This patch adds static pattern rules for files that have been requested to be built with the native compiler using $(HOSTSRCS) and $(HOSTOBJS), and converts the tools to use them. It restores easylogo to using the host compiler, which was broken by commit 38d299c2db81bd889c601b5dfc12c4e83ef83333 (if this was an intentional change, please let me know -- but it seems to be a build tool). It restores -pedantic and the special flags for darwin and cygwin that were requested in tools/makefile (but keeps the flags added by config.mk) -- hopefully someone can test this on those platforms. It no longer conditionalizes -pedantic on not being darwin; it wasn't clear that that was intentional, and unless there's a real problem it's just inviting people to contribute non-pedantic patches to those files (I'm not a fan of -pedantic personally, but if it's on for one platform it should be on for all). HOST_LDFLAGS is renamed HOSTLDFLAGS for consistency with the previous HOST_CFLAGS to HOSTCFLAGS rename. A new HOSTCFLAGS_NOPED is made available for those files which currently cannot be built with -pedantic, and replaces the old FIT_CFLAGS. imls now uses the cross compiler properly, rather than by trying to reconstruct CC using the typoed $(CROSS_COMPILER). envcrc.c is now dependency-processed unconditionally -- previously it would be built without being on (HOST)SRCS if CONFIG_ENV_IS_EMBEDDED was not selected. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-10-27Revert "env: only build env_embedded and envcrc when needed"Wolfgang Denk
Breaks building on many boards, and no really clean fix available yet. This reverts commit 6dab6add2d8ee80905234b326abc3de11be1d178.
2009-10-18env: only build env_embedded and envcrc when neededMike Frysinger
The env code is protected by the ENV_IS_EMBEDDED define, so attempting to compile the code when this isn't defined is pointless. Now that the env headers have unified around CONFIG_ENV_IS_EMBEDDED, convert the build system to only build the env objects when this is enabled. And now that the env code is conditionally compiled, we can drop the source code checks. For people who want to extract the environment manually, add a new option CONFIG_BUILD_ENVCRC that only enables the envcrc utility. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-10mkimage: Add Kirkwood Boot Image support (kwbimage)Prafulla Wadaskar
This patch adds support for "kwbimage" (Kirkwood Boot Image) image types to the mkimage code. For details refer to docs/README.kwbimage This patch is tested with Sheevaplug board Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron@debian.org> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-09-10mkimage: Include missing files in build dependency calculationsPrafulla Wadaskar
Include default_image.o and fit_image.o into the build dependency calculations. This makes sure they get rebuilt if any of the headers they include are modified Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron@debian.org> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-10tools: mkimage: split code into core, default and FIT image specificPrafulla Wadaskar
This is a first step towards reorganizing the mkimage code to make it easier to add support for additional images types. Current mkimage code is specific to generating uImage and FIT image files, but the same framework can be used to generate other image types like Kirkwood boot images (kwbimage-TBD). For this, the mkimage code gets reworked: Here is the brief plan for the same:- a) Split mkimage code into core and image specific support b) Implement callback functions for image specific code c) Move image type specific code to respective C files Currently there are two types of file generation/list supported (i.e uImage, FIT), the code is abstracted from mkimage.c/.h and put in default_image.c and fit_image.c; all code in these file is static except init function call d) mkimage_register API is added to add new image type support All above is addressed in this patch e) Add kwbimage type support to this new framework (TBD) This will be implemented in a following commit. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Edit commit message, fix coding style and typos. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-10tools: mkimage: Makefile sortedPrafulla Wadaskar
The tools/Makefile is sorted for all entries, Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-07-23unify HOST_CFLAGS and HOSTCFLAGSMike Frysinger
The top build system sets up HOSTCFLAGS a bit and exports it, but other places use HOST_CFLAGS instead. Unify the two as HOSTCFLAGS so that the values stay in sync. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-17envcrc: add missing dependencies on env storageMike Frysinger
When the envcrc building was made conditional, it missed a bunch of env storage types, so add all currently supported types. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-16at91: add support for the PM9263 board of Ronetix GmbHIlko Iliev
The PM9263 board is based on the AT91SAM9263-EK board. Here is the page on Ronetix website: http://www.ronetix.at/starter_kit_9263.html Signed-off-by: Ilko Iliev <iliev@ronetix.at> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-05One more fix for building env_embedded.oWolfgang Denk
In addition to the changes for CONFIG_ENV_IS_IN_FLASH as done in commit afcbce07, we also need to do the same for CONFIG_ENV_IS_IN_EEPROM and CONFIG_ENV_IS_IN_NVRAM. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-04Fix building of env_embedded.oWolfgang Denk
Since commit a706bfc7 common/env_embedded.o and tools/envcrc were only built when CONFIG_ENV_IS_EMBEDDED was set, but this breaks building for many boards. We always have to build these files when CONFIG_ENV_IS_IN_FLASH is set. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-04tools/Makefile: fix image.c dependancy locationJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-04Add support for building native win32 toolsPeter Tyser
Add support for compiling the host tools in the tools directory using the MinGW toolchain. This produces executables which can be used on standard Windows computers without requiring cygwin. One must specify the MinGW compiler and strip utilities as if they were the host toolchain in order to build win32 executables, eg: make HOSTCC=i586-mingw32msvc-gcc HOSTSTRIP=i586-mingw32msvc-strip tools Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Simplify HOST_CFLAGS/HOST_LDFLAGS generationPeter Tyser
2009-04-04tools/Makefile: Create generic build rulesPeter Tyser
Create a few generic build rules to replace the current method which has 1 build target for each file Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Use auto-generated object file dependenciesPeter Tyser
Files in the SRCS variable have their dependencies automatically generated so remove duplicate explicit dependencies Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Remove symlinks for remaining source filesPeter Tyser
2009-04-04tools/Makefile: Dynamically generate libfdt object dependenciesPeter Tyser
Add the libfdt files to the SRCS variable so that they have their dependencies automatically generated Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Remove symlinks for fdt targetsPeter Tyser
2009-04-04tools/Makefile: Add libfdt/ to the include search pathPeter Tyser
This change makes the process of symlinking libfdt_internal.h unnecessary Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools: Remove unecessary symlinking of zlib.hPeter Tyser
crc32.c uses the zlib.h header in include/u-boot/zlib.h. The symlink was previously necessary to give U-Boot's version of zlib.h precedence over the host computer's version of zlib.h. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Add tools/ to the include search pathPeter Tyser
This change makes the process of symlinking mkimage.h and fdt_host.h unnecessary Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Compile ncb when CONFIG_NETCONSOLEPeter Tyser
Also conditionally add ncb.o to OBJ_FILES list Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Make gen_eth_addr dependent upon CONFIG_CMD_NETPeter Tyser
2009-04-04tools/Makefile: Make envcrc dependent upon CONFIG_ENV_IS_EMBEDDEDPeter Tyser
2009-04-04tools/Makefile: Make inca-swap-bytes dependent on CONFIG_INCA_IPPeter Tyser
2009-04-04tools/Makefile: Make ubsha1 dependent upon CONFIG_SHA1_CHECK_UB_IMGPeter Tyser
2009-04-04tools/Makefile: Make img2srec dependent upon CONFIG_CMD_LOADSPeter Tyser
2009-04-04tools/Makefile: Build bmp_logo only when LCD or VIDEO logos are enabledPeter Tyser
2009-04-04tools/Makefile: Split variable declarations into multiple linesPeter Tyser
Split variable declarations into multiple lines and use the standard VAR-y convention. Also move object and binary variable declarations to after config.mk has been included to allow for these lists to utilize the CONFIG_XXX variables. These changes lay the groundwork for conditional compilation of files in the tools directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Remove inappropriate double-tabsPeter Tyser
2009-04-04tools/Makefile: Remove HOSTARCH HOSTOS definesPeter Tyser
The values of HOSTARCH and HOSTOS which are exported from the top-level Makefile should be used Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
