path: root/tools/.gitignore
2019-06-14tools: add tools/spl_size_limit to ignore listSimon Goldschmidt
This tool has just been added but it seems I forgot to add it to the ignore list. So to prevent the built binary being marked as unversioned, add it to the ignore list. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-11-26tools: .gitignore: add prelink-riscvLukas Auer
Ignore tools/prelink-riscv. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Rick Chen <rick@andestech.com>
2018-01-22tools: provide a tool to convert a binary file to an includeHeinrich Schuchardt
For testing EFI disk management we need an in-memory image of a disk. The tool file2include converts a file to a C include. The file is separated into strings of 8 bytes. Only the non-zero strings are written to the include. The output format has been designed to maintain readability. #define EFI_ST_DISK_IMG { 0x00010000, { \ {0x000001b8, "\x94\x37\x69\xfc\x00\x00\x00\x00"}, /* .7i..... */ \ {0x000001c0, "\x02\x00\x83\x02\x02\x00\x01\x00"}, /* ........ */ \ {0x000001c8, "\x00\x00\x7f\x00\x00\x00\x00\x00"}, /* ........ */ \ {0x000001f8, "\x00\x00\x00\x00\x00\x00\x55\xaa"}, /* ......U. */ \ ... {0x00006000, "\x48\x65\x6c\x6c\x6f\x20\x77\x6f"}, /* Hello wo */ \ {0x00006008, "\x72\x6c\x64\x21\x0a\x00\x00\x00"}, /* rld!.... */ \ {0, NULL} } } As the disk image needed for testing contains mostly zeroes a high compression ratio can be attained. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-11-17pylibfdt: move pylibfdt to scripts/dtc/pylibfdt and refactor makefileMasahiro Yamada
The pylibfdt is used by dtoc (and, indirectly by binman), but there is no reason why it must be generated in the tools/ directory. Recently, U-Boot switched over to the bundled DTC, and the directory structure under scripts/dtc/ now mirrors the upstream DTC project. So, scripts/dtc/pylibfdt is the best location. I also rewrote the Makefile in a cleaner Kbuild style. The scripts from the upstream have been moved as follows: lib/libfdt/pylibfdt/setup.py -> scripts/dtc/pylibfdt/setup.py lib/libfdt/pylibfdt/libfdt.i -> scripts/dtc/pylibfdt/libfdt.i_shipped The .i_shipped is coped to .i during building because the .i must be located in the objtree when we build it out of tree. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-09-07tools: .gitignore: Add libfdt related filesBin Meng
Some files are generated during libfdt build. Ignore them. This was wrongly put in the .gitignore in the root directory before. Now let's remove entries there and put them in the right place. Fixes: 34e2c285 ("gitignore: add intermediates from libfdt build") Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-07tools: .gitignore: Sort in alphabetical orderBin Meng
These are currently out of alphabetical order. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-25MIPS: Stop building position independent codePaul Burton
U-Boot has up until now built with -fpic for the MIPS architecture, producing position independent code which uses indirection through a global offset table, making relocation fairly straightforward as it simply involves patching up GOT entries. Using -fpic does however have some downsides. The biggest of these is that generated code is bloated in various ways. For example, function calls are indirected through the GOT & the t9 register: 8f998064 lw t9,-32668(gp) 0320f809 jalr t9 Without -fpic the call is simply: 0f803f01 jal be00fc04 <puts> This is more compact & faster (due to the lack of the load & the dependency the jump has on its result). It is also easier to read & debug because the disassembly shows what function is being called, rather than just an offset from gp which would then have to be looked up in the ELF to discover the target function. Another disadvantage of -fpic is that each function begins with a sequence to calculate the value of the gp register, for example: 3c1c0004 lui gp,0x4 279c3384 addiu gp,gp,13188 0399e021 addu gp,gp,t9 Without using -fpic this sequence no longer appears at the start of each function, reducing code size considerably. This patch switches U-Boot from building with -fpic to building with -fno-pic, in order to gain the benefits described above. The cost of this is an extra step during the build process to extract relocation data from the ELF & write it into a new .rel section in a compact format, plus the added complexity of dealing with multiple types of relocation rather than the single type that applied to the GOT. The benefit is smaller, cleaner, more debuggable code. The relocate_code() function is reimplemented in C to handle the new relocation scheme, which also makes it easier to read & debug. Taking maltael_defconfig as an example the size of u-boot.bin built using the Codescape MIPS 2016.05-06 toolchain (gcc 4.9.2, binutils 2.24.90) shrinks from 254KiB to 224KiB. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: u-boot@lists.denx.de Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Tested-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-04-07tools: sunxi: Add spl image builderMaxime Ripard
This program generates raw SPL images that can be flashed on the NAND with the ECC and randomizer properly set up. This has been copied (and tweaked to find the right headers) from the sunxi-tools (https://github.com/linux-sunxi/sunxi-tools) upstream repository, commit 1c3a6ca5. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-02-07tools: Add tool to add crc8 to a mac addressoliver@schinagl.nl
This patch adds a little tool that takes a generic MAC address and generates a CRC byte for it. The output is the full MAC address without any separators, ready written into an EEPROM. Signed-off-by: Olliver Schinagl <o.schinagl@ultimaker.com> Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-05-27tools: Add entry for generated tools/bin2header to tools/.gitignoreRobert P. J. Day
2015-08-05gitignore: Add defconfig and fdtgrepBin Meng
Ignore defconfig and tools/fdtgrep. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-27tools: remove mpc86x_clk toolMasahiro Yamada
This is commented out in the Makefile for more than 10 years. I assume it is proof that this tool is unused. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Pantelis Antoniou <panto@intracom.gr>
2014-11-25tools: Add ifdtool to .gitignoreBin Meng
2014-10-27gitignore: ignore atmel pmecc parameter toolAndreas Bießmann
2014-06-11.gitignore: move *.exe pattern to the top gitignore for CygwinMasahiro Yamada
GCC on Cygwin generates executables with .exe extension, for example: scripts/basic/fixdep.exe scripts/docproc.exe To ignore them, *.exe pattern should be moved from tools/.gitignore to ./.gitignore Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-11kbuild, tools: generate wrapper C sources automatically by MakefileMasahiro Yamada
There are many source files shared between U-boot image and tools. Instead of adding a lot of dummy wrapper files that just include the corresponding file in lib/ or common/ directory, Makefile should automatically generate them. The original inspiration for this came from scripts/Makefile.asm-generic of Linux Kernel. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-05-25sunxi: non-FEL SPL boot support for sun7iIan Campbell
Add support for booting from an MMC card. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Henrik Nordström <henrik@henriknordstrom.net> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Cc: Tom Cubie <Mr.hipboi@gmail.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-03-21tools, fit_check_sign: verify a signed fit imageHeiko Schocher
add host tool "fit_check_sign" which verifies, if a fit image is signed correct. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org>
2014-03-21tools, fit: add fit_info host commandHeiko Schocher
add fit_info command to the host tools. This command prints the name, offset and the len from a property from a node in a fit file. This info can be used to extract a properties data with linux tools, for example "dd". Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19kernel-doc: move kernel-doc tools to scripts/Masahiro Yamada
tools/kernel-doc/docproc.c and tools/kernel-doc/kernel-doc are files imported from Linux Kernel. They originally resided under scripts/ directory in Linux Kernel. This commit moves them to the original location. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19tools/env: cross-compile fw_printenv without setting HOSTCCMasahiro Yamada
fw_printenv is a program which mostly runs on the target Linux. Before switching to Kbuild, we needed to set HOSTCC at the command line like this: make HOSTCC=<your CC cross-compiler> env Going forward we can cross compile it by specifying CROSS_COMPILE: make CROSS_COMPILE=<your cross-compiler prefix> env This looks more natural. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19tools: convert makefiles to kbuild styleMasahiro Yamada
Before this commit, makefiles under tools/ directory were implemented with their own way. This commit refactors them by using "hostprogs-y" variable. Several C sources have been added to wrap other C sources to simplify Makefile. For example, tools/crc32.c includes lib/crc32.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-20.gitignore: ignore u-boot.elf and tools/relocate-relaMasahiro Yamada
2013-12-16Makefile, .gitignore: Cleanup non-existing binariesMasahiro Yamada
2013-12-13Add dumpimage, a tool to extract data from U-Boot imagesGuilherme Maciel Ferreira
Given a multi-file image created through the mkimage's -d option: $ mkimage -A x86 -O linux -T multi -n x86 -d vmlinuz:initrd.img:System.map \ multi.img Image Name: x86 Created: Thu Jul 25 10:29:13 2013 Image Type: Intel x86 Linux Multi-File Image (gzip compressed) Data Size: 13722956 Bytes = 13401.32 kB = 13.09 MB Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 4040128 Bytes = 3945.44 kB = 3.85 MB Image 1: 7991719 Bytes = 7804.41 kB = 7.62 MB Image 2: 1691092 Bytes = 1651.46 kB = 1.61 MB It is possible to perform the innverse operation -- extracting any file from the image -- by using the dumpimage's -i option: $ dumpimage -i multi.img -p 2 System.map Although it's feasible to retrieve "data files" from image through scripting, the requirement to embed tools such 'dd', 'awk' and 'sed' for this sole purpose is cumbersome and unreliable -- once you must keep track of file sizes inside the image. Furthermore, extracting data files using "dumpimage" tool is faster than through scripting. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Add proftool to decode profile dataSimon Glass
This tool provides the facility to decode U-Boot trace data and write out a text file in Linux ftrace format for use with pytimechart. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-15kerneldoc: Implant DocBook from Linux kernelMarek Vasut
Pull slightly modified version of Documentation/DocBook, the related perl script scripts/kernel-doc and the scripts/docproc.c from Linux kernel and implant it into U-Boot. This will allow smooth generation of kerneldoc style documentation. It was necessary to modify the DocBook/Makefile to work with U-Boot build system. The changes were only minor though and involved replacing the kbuild specific parts. It was also necessary to replace use of variables like KERNEL_VERSION with U_BOOT_VERSION, strings like Linux kernel with U-Boot Bootloader etc. so the generated result actually matches. Finally, it was necessary to adjust docproc.c, since the documentation in U-Boot is located in doc/DocBook instead of Documentation/DocBook as is in case of the Linux kernel. Some parts of the DocBook Makefile are unused, but to allow easier sync with Linux kernel, these parts are still left in. The targets enabled now are "htmldocs" "pdfdocs" "psdocs" "xmldocs" and "cleandocs" to remove the results of documentation build. Linux scripts/docproc.c: commit f0f3ca8d967462dafb815412b14ca3339b9817a6 Date: Wed Jun 15 11:53:13 2011 +0200 Linux scripts/kernel-doc: commit 1b40c1944db445c1de1c47ffd8cd426167f488e8 Date: Sun Aug 12 10:46:15 2012 +0200 Linux Documentation/DocBook: commit bb8187d35f820671d6dd76700d77a6b55f95e2c5 Date: Thu May 17 19:06:13 2012 -0400 Signed-off-by: Marek Vasut <marex@denx.de>
2012-08-10tools: add kwboot binary to .gitignore fileLuka Perkov
Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Acked-by: Prafulla Wadaskar <Prafulla@marvell.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-07-27MIPS: fix renaming of inca-swap-bytes to xway-swap-bytesDaniel Schwierzeck
Fix some remains of the renaming of inca-swap-bytes introduced in commit 60b74bde9280e85f4423c05a50ecc41de56ad980 MIPS: INCA-IP: rename inca-swap-bytes host tool Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2011-11-27ignore new mkenvimage toolMike Frysinger
2011-11-11iMX28: Add image header generator toolMarek Vasut
This tool can now generate proper image for "BootStream" files. NOTE: This tool now works only for NAND. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2010-09-19tools: update .gitignoreMike Frysinger
2009-11-24tools: gitignore *.exe binariesMike Frysinger
2009-04-04tools: add ncb to gitignoreMike Frysinger
2009-04-04tools/Makefile: Remove symlinks for remaining source filesPeter Tyser
2009-04-04tools/Makefile: Remove symlinks for fdt targetsPeter Tyser
2009-04-04tools/Makefile: Add libfdt/ to the include search pathPeter Tyser
This change makes the process of symlinking libfdt_internal.h unnecessary Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools: Remove unecessary symlinking of zlib.hPeter Tyser
crc32.c uses the zlib.h header in include/u-boot/zlib.h. The symlink was previously necessary to give U-Boot's version of zlib.h precedence over the host computer's version of zlib.h. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-07-15tools/gitignore: update to all generated filesJean-Christophe PLAGNIOL-VILLARD
2008-04-29Update .gitignore for zlib.hKumar Gala
2008-03-14Add MD5 support to the new uImage formatBartlomiej Sieka
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-02-29[new uImage] Add libfdt support to mkimageBartlomiej Sieka
2007-11-15Add .gitignore filesGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Kim Phillips <kim.phillips@freescale.com>
