commit 4a6105e7830e9e945a6dc556a43ffaf26f0156e5 upstream.
Add test case for an address range which is coalescing with one of
range and overlapping with next range
Cc: Simon Glass <sjg@google.com>
Signed-off-by: Udit Kumar <u-kumar1@ti.com>
commit 4583c00236efd4ee768ff874f92526c229891a05 upstream
The patman directory has a number of modules which are used by other tools
in U-Boot. This makes it hard to package the tools using pypi since the
common files must be copied along with the tool that uses them.
To address this, move these files into a new u_boot_pylib library. This
can be packaged separately and listed as a dependency of each tool.
Signed-off-by: Neha Malcom Francis <n-francis@ti.com>
Test that:
- sandbox shows a warning when an unmigrated DT is used
- sandbox fails to run when migration is turned off
- sandbox_spl fails to build when migration is turned off
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
This is useful when we need to control a particular environment variable.
Add a way to handle this.
Update various build and test components to use the new schema.
commit 83d48a3c8bfbbbc2a8ad951b211081f72fc268b6 upstream.
test_abootimg is extended to include the testing of boot images
version 4. For this, boot.img and vendor_boot.img have been
generated using mkbootimg tool with setting the header
version to 4.
This tests:
- Getting the header version using abootimg
- Extracting the load address of the dtb
- Extracting the dtb start address in RAM
Running test:
$ ./test/py/test.py --bd sandbox --build -k test_abootimg
Signed-off-by: Safae Ouajih <souajih@baylibre.com>
Tested-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Signed-off-by: Praneeth Bajjuri <praneeth@ti.com>
The second call to cli_ch_process() is in the wrong place, meaning that
the one of the characters of an invalid escape sequence is swallowed
instead of being returned.
Fix the bug and add a test to cover this.
This behaviour matches that of the code before cli_getch() was
introduced. This was verified on the commit before b08e9d4b66 i.e.:
7d850f85aad ("sandbox: Enable mmc command and legacy images")
Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
This function does not behave as expected when unknown escape sequences
are sent to it:
- it fails to store (and thus echo) the last character of the invalid
sequence
- it fails to set esc_len to 0 when it finishes emitting the invalid
sequence, meaning that the following character will appear to be part
of a new escape sequence
- it processes the first character of the rejected sequence as a valid
character, just starting the sequence all over again
The last two bugs conspire to produce an "impossible condition #876"
message which is the main symptom of this behaviour.
Fix these bugs and add a test to verify the behaviour.
Add a unit test for the crc8() function.
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Add 'fdt bootcpu' test which works as follows:
- Create basic FDT, map it to sysmem
- Print the FDT bootcpu
- Set the FDT bootcpu and read the value back using 'fdt header get'
- Perform the previous step twice to validate bootcpu overwrite
The test case can be triggered using:
./u-boot -Dc 'ut fdt'
To dump the full output from commands used during test, add '-v' flag.
Signed-off-by: Marek Vasut <marek.vasut+renesas@mailbox.org>
Add 'fdt rm' test which works as follows:
- Create fuller FDT, map it to sysmem
- Selectively delete nodes or properties by both path and aliases
- Verify created nodes or properties using fdt print command
Add 'fdt mknode' test which works as follows:
- Create node either in / or subnode
- Attempt to create node over existing node, which fails
- Attempt to create subnodes in non-existing nodes or aliases
- Verify created nodes using fdt list command
Add 'fdt set' test which works as follows:
- Set either existing property to overwrite it, or new property
- Test setting both single properties as well as string and integer arrays
- Test setting to non-existent nodes and aliases
- Verify set values using 'fdt get value'
Add 'fdt get size' test which works as follows:
- Get size of various properties
- Get node count of available nodes
- Test non-existent nodes and properties
Add 'fdt get addr' test which works as follows:
- Get address of various properties
- Compare addresses calculated by UT and fdt command
This test is special in that it has to go through gruesome remapping scheme
where the test calculates:
- pointer offsets of the generated FDT root and the property being tested
- map_sysmem() result of environment variable "fdtaddr" and the one set
by the test matching address of property being tested
- difference between the later and the former, to obtain offset of the
DT property from start of DT
The offsets must match in both the UT and the tested U-Boot, if they do
not, the test fails.
Add 'fdt get name' test which works as follows:
- Get name of / node 0, 1 and /clk-test node 0
- Compare output and validate the node name
- Get name of / node 2 and /clk-test node 1
- Compare output and validate the node is not present
- Get name of / node -1 and /clk-test node -1
- Compare output and validate the node name equals node 0 name
- Check nonexistent node, verify the command errors out
Add 'fdt resize' test which works as follows:
- Create simple FDT with extra size 0, map it to sysmem
- 'resize' the FDT by 0x2000 bytes
- Verify the new space has been added to the FDT
Add 'fdt move' test which works as follows:
- Create simple FDT, map it to sysmem
- 'move' the FDT into new zeroed out sysmem location
- Verify newly active FDT is in the new location
- Compare both locations
The 'fdt get value' subcommand now supports extraction of integer value
from integer arrays, add test for it, including a test for special case
unindexed integer array read, which is handled as hash and treated as a
long string instead of integer.
The 'fdt' command help contains the following note:
Dereference aliases by omitting the leading '/', e.g. fdt print ethernet0.
Add test for it.
Implement function to generate internal test DT fragment and switch
the 'fdt get value' test to this instead of depending on the sandbox
DT. Rename clk-test node to test-node node. This FDT fragment will be
reused by other tests. No functional change.
The 'fdt get' command has a 'get value' subcommand, rename the fdt_test_get()
to fdt_test_get_value() to avoid confusion about what it is testing. There is
currently no get 'get name', 'get addr', 'get size' subcommand test.
The 'fdt' command has a 'resize' subcommand, rename the fdt_test_resize()
to fdt_test_addr_resize() to avoid confusion about what it is testing.
There is currently no resize test.
We expect the profile and bootstage to agree on timing, but when
running on slow machines there can be a larger descrepency. Increase the
tolerance to fix this.
Fixes: 9cea4797aeb ("trace: Add a test")
This allows devm_reset_control_get(dev, NULL) to work and get the first
reset control, which is common in code ported from Linux.
Signed-off-by: Samuel Holland <samuel@sholland.org>
Link: https://lore.kernel.org/r/20230122000252.53642-2-samuel@sholland.org
This allows devm_clock_get(dev, NULL) to work and get the first clock,
Reviewed-by: Sean Anderson <seanga2@gmail.com>
Link: https://lore.kernel.org/r/20230122000252.53642-1-samuel@sholland.org
Add a test which runs sandbox, collects a trace and makes sure it can
be processed by trace-cmd. This should ensure that this feature continues
to work as U-Boot and trace-cmd evolve.
Linux event code must be used in input devices, using buttons.
Signed-off-by: Dzmitry Sankouski <dsankouski@gmail.com>
Property count may change in /buttons node, if more button tests added,
and this will break ofnode_for_each_prop.
Add separate node for mentioned test.
First, this test depends on CONFIG_LMB_USE_MAX_REGIONS, so add that as a
test before building. Second, instead of using a hard-coded value of 8,
which is the default of CONFIG_LMB_USE_MAX_REGIONS previously, use that
directly and update the comments. The only trick here is that one part
of the test itself also was written with the value of 8 itself in mind.
Rework the size of the lmb region we allocate to scale with the value of
CONFIG_LMB_USE_MAX_REGIONS.
Add a command to load SEAMA (Seattle Image), a NAND flash
on-flash storage format.
This type of flash image is found in some D-Link routers such
as DIR-645, DIR-842, DIR-859, DIR-860L, DIR-885L, DIR890L and
DCH-M225, as well as in WD and NEC routers on the ath79
(MIPS), Broadcom BCM53xx, and RAMIPS platforms.
This U-Boot command will read and decode a SEAMA image from
raw NAND flash on any platform. As it is always using big endian
format for the data decoding is always necessary on platforms
such as ARM.
The command is needed to read a SEAMA-encoded boot image on the
D-Link DIR-890L router for boot from NAND flash in an upcoming
port of U-Boot to the Broadcom Northstar (BCM4709, BCM53xx)
architecture.
A basic test and documentation is added as well. The test must
be run on a target with NAND flash support and at least one
resident SEAMA image in flash.
Cc: Rafał Miłecki <rafal@milecki.pl>
These are only used in one place, so move them there.
This test will block compilation of the entire test suite
on platforms without USB support. Make the extern
"usb_started" conditional on USB host or gadget and
define a dummy flag if neither is enabled.
To test decode_panel_timing add a panel-timings node
and a DM test for decode panel timingd by matching
the panel timing node parameters.
Signed-off-by: Nikhil M Jain <n-jain1@ti.com>
Test that we correctly probe an IOMMU that is mapped by an
"iommu-map" device tree property of a PCIe controller node.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Test that the map and unmap operations work for devices that
have DMA translated by an IOMMU and devices that don't have
DMA translated by an IOMMU.
Extend support for signing in auto-generated (-f auto) FIT. Previously,
it was possible to get signed 'images' subnodes in the FIT using
options -g and -o together with -f auto. This patch allows signing
'configurations' subnodes instead of 'images' ones (which are hashed),
using option -f auto-conf instead of -f auto. Adding also -K <dtb> and
-r options, will add public key to <dtb> file with required = "conf"
property.
Summary:
-f auto => FIT with crc32 images
-f auto -g ... -o ... => FIT with signed images
-f auto-conf -g ... -o ... => FIT with sha1 images and signed confs
Example: FIT with kernel, two device tree files, and signed
configurations; public key (needed to verify signatures) is
added to u-boot.dtb with required = "conf" property.
mkimage -f auto-conf -A arm -O linux -T kernel -C none -a 43e00000 \
-e 0 -d vmlinuz -b /path/to/first.dtb -b /path/to/second.dtb \
-k /folder/with/key-files -g keyname -o sha256,rsa4096 \
-K u-boot.dtb -r kernel.itb
Example: Add public key with required = "conf" property to u-boot.dtb
without needing to sign anything. This will also create a useless FIT
named unused.itb.
mkimage -f auto-conf -d /dev/null -k /folder/with/key-files \
-g keyname -o sha256,rsa4096 -K u-boot.dtb -r unused.itb
Signed-off-by: Massimo Pegorer <massimo.pegorer@vimar.com>
Add a way to record the bootdevs used when scanning for bootflows. This is
useful for testing.
Enable this only with BOOTSTD_FULL and do the same for the progress
reporting.
Re-enable and update the affected tests now that we have this feature.
For bootdev_test_order_default() there is no-longer any support for using
the bootdev aliases to specify an ordering, so drop that part of the test.
This function is not used outside tests. Drop it and rename
bootflow_scan_dev() since it is how we start a scan now.
We want to support scanning a single label, like 'mmc' or 'usb0'. Add
this feature by plumbing the label through to the iterator, setting a
flag to indicate that only siblings of the initial device should be used.
This means that scanning a bootdev by its name is not supported anymore.
That feature doesn't seem very useful in practice, so it is no great loss.
Add a test for bootdev_find_by_any() while we are here.
At present we set up the bootdev order at the start, then scan the
bootdevs one by one.
However this approach cannot be used with hunters, since the bootdevs may
not exist until the hunter is used. Nor can we just run all the hunters at
the start, since that violate's U-Boot's 'lazy init' requirement. It also
increases boot time.
So we need to adjust the algorithm to scan by labels instead. As a first
step, drop the dev_order[] array in favour of a list of labels. Update the
name of bootdev_setup_iter_order() to better reflect what it does.
Update some related comments and log messages. Also disable a few tests
until a later commit where we can use them.
This needs to run before any bootdev is used, so add a hunter for it.
Add a function which moves to the next priority to be processed.
This works by storing the current priority in the bootflow iterator. The
logic to set this up is included in a subsequent commit.
Add a function which moves to the next label in a list of labels. This
allows processing the boot_targets environment variable.
This works using a new label list in the bootflow iterator. The logic to
Add a function to hunt for a bootdev label and find the bootdev produced
by the hunter (or already present).
Add a few extra flags so that we can distinguish between "mmc1", "mmc" and
"1" which all need to be handled differently.
We need extensions to be set up before we start trying to boot any of the
bootdevs. Add a new priority before all the others for tht sort of thing.
Also add a 'none' option, so that the first one is not 0.
While we are here, comment enum bootdev_prio_t fully and expand the test
for the 'bootdev hunt' command.
Add a way to run the hunter function for a particular priority, so that
new bootdevs can be found.
These are associated with the ethernet boot device but do not match its
uclass name, so handle them as special cases.
Provide a way to pass flags through with the bootdev so that we know
how to process it. The flags are checked by the bootmeths, to ensure that
only the selected bootmeth is used.
While these both use the network device, they work quite differently. It
is common to run only one of these, or to run PXE before DHCP. Provide
bootflow flags to control which methods are used. Check these in the two
bootmeths so that only the chosen one is used.
Add a bootdev for SPI flash so that these devices can be used with
standard boot. It only supports loading a script.
Add a special case for the label, since we want to use "spi", not
"spi_flash".
Enable the new bootdev on sandbox.
Most tests don't want these and they can create a lot of noise. Add a way
to disable them. Use that in tests, with a flag provided to enable them
for tests that need this feature.
