Add test to check node name ignoring unit address.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Include emmc/nand suffix into bootmenu script names and fix leaking sleep
processes when asynchronously waiting for them. 'wait -n' is not provided
by /bin/sh, so run script under bash.
Signed-off-by: Pali Rohár <pali@kernel.org>
patman status subcommand to collect tags from Patchwork
patman showing email replies from Patchwork
sandbox poweroff command
minor fixes in binman, tests
This uclass is intended to provide a way to obtain information about a
U-Boot board. But the concept of a U-Boot 'board' is the whole system,
not just one circuit board, meaning that 'board' is something of a
misnomer for this uclass.
In addition, the name 'board' is a bit overused in U-Boot and we want to
use the same uclass to provide SMBIOS information.
The obvious name is 'system' but that is so vague as to be meaningless.
Use 'sysinfo' instead, since this uclass is aimed at providing information
on the system.
Rename everything accordingly.
Note: Due to the patch delta caused by the symbol renames, this patch
shows some renamed files as being deleted in one place and created in
another.
At present if SSDT and DSDT code is created, only the latter is retained
for examination by the 'acpi items' command. Fix this by only resetting
the list when explicitly requested.
Building U-Boot with unit tests on a non-sandbox systems fails:
ld.bfd: test/built-in.o: in function `compress_using_gzip':
test/compression.c:138: undefined reference to `gzip'
ld.bfd: test/built-in.o: in function `uncompress_using_bzip2':
test/compression.c:187: undefined reference to `BZ2_bzBuffToBuffDecompress'
ld.bfd: test/built-in.o: in function `uncompress_using_lzma':
test/compression.c:222: undefined reference to `lzmaBuffToBuffDecompress'
ld.bfd: test/built-in.o: in function `uncompress_using_lzo':
test/compression.c:257: undefined reference to `lzop_decompress'
ld.bfd: test/built-in.o: in function `uncompress_using_lz4':
test/compression.c:292: undefined reference to `ulz4fn
Add the missing dependencies.
Building test/bloblist.c fails for non sandbox devices:
test/bloblist.c:10:10: fatal error: asm/state.h: No such file or directory
#include <asm/state.h>
Build the test only on the sandbox.
As we have a working COLD_RESET on the sandbox the sysreset test has to be
adjusted.
It is the 'poweroff' and not the 'reset' command that should shut down the
sandbox.
Adjust the unit test accordingly
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2021-01-rc2 (2)
The series contains the following enhancements
* preparatory patches for UEFI capsule updates
* initialization of the emulated RTC using an environment variable
and a bug fix
* If DisconnectController() is called for a child controller that is the
only child of the driver, the driver must be disconnected.
https://gitlab.denx.de/u-boot/custodians/u-boot-dm
of-platdata and dtoc improvements
sandbox SPL tests
binman support for compressed sections
This exercises a few success and failure modes of the log filter-*
commands. log filter-list is not tested because it's purely informational.
I don't think there's a good way to test it except by testing if the output
of the command exactly matches a sample run.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
A few of these tests were inspired by those in glibc. The syntax for
invoking test_getopt is a bit funky, but it's necessary so that the CPP can
parse the arguments correctly.
This tests log filters matching on a minimum level.
This adds some tests for log filters which deny if they match.
Now that the log test command is no more, we can give the log tests proper
names.
When rebasing this series I had to renumber all my log tests because
someone made another log test in the meantime. This involved updaing a
number in several places (C and python), and it wasn't checked by the
compiler. So I though "how hard could it be to just rewrite in C?" And
though it wasn't hard, it *was* tedious. Tests are numbered the same as
before to allow for easier review.
A note that if a test fails, everything after it will probably also fail.
This is because that test won't clean up its filters. There's no easy way
to do the cleanup, except perhaps removing all filters in a wrapper
function.
Provide a unit test for function efi_create_indexed_name().
At present we use a 'node' pointer in the of-platadata phandle_n_arg
structs. This is a pointer to the struct driver_info for a particular
device, and we can use it to obtain the struct udevice pointer itself.
Since we don't know the struct udevice pointer until it is allocated in
memory, we have to fix up the phandle_n_arg.node at runtime. This is
annoying since it requires that SPL's data is writable and adds a small
amount of extra (generated) code in the dm_populate_phandle_data()
function.
Now that we can find a driver_info by its index, it is easier to put the
index in the phandle_n_arg structures.
Update dtoc to do this, add a new device_get_by_driver_info_idx() to look
up a device by drive_info index and update the tests to match.
Add a simple test that we can obtain the correct parent for an I2C
device. This requires updating the driver names to match the compatible
strings, adding them to the devicetree and enabling a few options.
At present we update the driver_info struct with a pointer to the device
that it created (i.e. caused to be bound). This works fine when U-Boot SPL
is stored in read-write memory. But on some platforms, such as Intel
Apollo Lake, it is not possible to update the data memory.
In any case, it is bad form to put this information in a structure that is
in the data region, since it expands the size of the binary.
Create a new driver_rt structure which holds runtime information about
drivers. Update the code to store the device pointer in this instead.
Also update the test check that this works.
We have a test in dtoc for this feature, but not one in U-Boot itself.
Add a simple test that checks that the information comes through
correctly.
With of-platdata, the driver_info struct is updated with the device
pointer when it is bound. This makes it easy for a device to be found by
its driver info with the device_get_by_driver_info() function.
Add a test that all devices (except the root device) have such an entry.
Fix a bug that the function does not set *devp to NULL on failure, which
the documentation asserts.
At present properties are tested in a roundabout way. The driver's probe()
method writes out the values of the properties and the Python test checks
the output from U-Boot SPL.
Add a C test which checks these values more directly.
Now that we have a C version of this test, drop the Python implementation.
Use the new -k option to select the test to run.
Update the 'run' script to include SPL unit tests.
Add a new test_spl fixture to handle running SPL unit tests.
At present we have a pytest that covers of-platadata. Add a very simple
unit test that just checks that a device can be found. This shows the
ability to write these tests in C.
Add a -u flag for U-Boot SPL which requests that unit tests be run. To
make this work, export dm_test_main() and update it to skip test features
that are not used with of-platdata.
To run the tests:
$ spl/u-boot-spl -u
U-Boot SPL 2020.10-rc5 (Oct 01 2020 - 07:35:39 -0600)
Running 0 driver model tests
Failures: 0
At present there are no SPL unit tests.
Note that there is one wrinkle with these tests. SPL has limited memory
available for allocation. Also malloc_simple does not free memory
(free() is a nop) and running tests repeatedly causes driver-model to
reinit multiple times and allocate memory. Therefore it is not possible
to run more than a few tests at a time. One solution is to increase the
amount of malloc space in sandbox_spl. This is not a problem for pytest,
since it runs each test individually, so for now this is left as is.
At present DM tests assume that a devicetree is available. This is not the
case with of-platadata.
Update the code to add this condition.
We want to run unit tests in SPL. Add a new Kconfig to control this and
enable it for sandbox_spl
At present an integer is converted to bytes incorrectly. The whole 32-bit
integer is inserted as the first element of the byte array, and the other
three bytes are skipped. This was not noticed because the unit test did
not check it, and the functional test was checking for wrong values.
Update the code to handle this as a special case. Add one more test to
cover all code paths.
Tests are easier to run in U-Boot proper. Running them in SPL does not add
test coverage in most cases. Also some tests use features that are not
available in SPL.
Update the build rules to disable these tests in SPL. We still need
test-main to be able to actually run SPL tests.
At present we always include test/dm from the main Makefile. We have a
CONFIG_UNIT_TEST that should control whether the test/ directory is built,
so rely on that instead.
At present most of the tests in test/Makefile are dependent on
CONFIG_SANDBOX. But this is not ideal since they rely on commands being
available and SPL does not support commands.
Use CONFIG_COMMAND instead. This has the dual purpose of allowing these
tests to be used on other boards and allowing SPL to skip them.
Move everything into alphabetical order.
At present this option results in a number of #ifdefs due to the presence
or absence of the global_data of_root member.
Add a few macros to global_data.h to work around this. Update the code
accordingly.
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx changes for v2021.01-v2
common:
- Add support for 64bit loadables from SPL
xilinx:
- Update documentation and record ownership
- Enable eeprom board detection based legacy and fru formats
- Add support for FRU format
microblaze:
- Optimize low level ASM code
- Enable SPI/I2C
- Enable distro boot
zynq:
- Add support for Zturn V5
zynqmp:
- Improve silicon detection code
- Enable several kconfig options
- Align DT with the latest state
- Enabling security commands
- Enable and support FPGA loading from SPL
- Optimize xilinx_pm_request() calling
versal:
- Some DTs/Kconfig/defconfig alignments
- Add binding header for clock and power
zynq-sdhci:
- Add support for tap delay programming
zynq-spi/zynq-qspi:
- Use clock framework for getting clocks
xilinx-spi:
- Fix some code issues (unused variables)
serial:
- Check return value from clock functions in pl01x
Tests tests run the three mux subcommands: list, select, and deselect,
and verify that the commands do what we expect.
Signed-off-by: Pratyush Yadav <p.yadav@ti.com>
Provide tests to check the behavior of the multiplexer framework.
Two sets of tests are added. One is using an emulated multiplexer driver
that can be used to test basic functionality like select, deselect, etc.
The other is using the mmio mux which adds tests specific to it.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Provide a unit test checking that a continuation message will use the same
log level and log category as the previous message.
Add support for getting a node/property from aliases.
The similar functionality is provided for chosen node and this
implemenatation is copy of it.
do_save() function defined in fs.c also supports FAT file system
re-use the same for fatwrite command.
Also fix the FAT test script to match the expected output.
Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com>
Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com>
Provide unit tests for functions print_freq() and print_size().
The sandbox is built with the SDL2 library with invokes the X11 library
which in turn calls getc(). But getc() in glibc is defined as
int getc(FILE *)
This does not match our definition.
int getc(void)
The sandbox crashes when called with parameter -l.
Rename our library symbol getc() to getchar().
For levels equal to the maximum value, the duty cycle must be equal to
the period.
Signed-off-by: Dario Binacchi <dariobin@libero.it>
syslog_test.h is in test/log/, not include/
Fixes: 52d3df7fef ("log: Allow LOG_DEBUG to always enable log output")
To make the button command useful in a shell script it should return the
status of the button:
* 0 (true) - pressed, on
* 1 (false) - not pressed, off
The button command takes only one argument. Correct maxargs.
Adjust the Python unit test.
Reviewed-by: Philippe Reynes <philippe.reynes@softathome.com>
Using different strings for the device tree node labels and the label
property of buttons sharpens the button label unit test.
