path: root/test
2018-12-03test: vboot: add padding pss for rsa signaturePhilippe Reynes
The padding pss is now supported for rsa signature. This add test with padding pss on vboot test. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-29dm: sandbox: i2c: Use new emulator parent uclassSimon Glass
Update the device tree, sandbox i2c driver and tests to use the new emulation parent to hold emulators. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-29dm: core: Add a few more specific child-finding functionsSimon Glass
Add two functions which can find a child device by uclass or by name. The first is useful with Multi-Function-Devices (MFDs) to find one of a particular type. The second is useful when only the name is known. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-29dm: core: Export uclass_find_device_by_phandle()Simon Glass
This function may be useful to code outside of the code driver-model implementation. Export it and add a test. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-29test: Add a 'make qcheck' target for quicker testingSimon Glass
At present tests are quite slow to run, over a minute on my machine. This presents a considerable barrier to bisecting for failures. The slowest tests are the filesystem ones and the buildman --fetch-arch test. Add a new 'qcheck' target that skips these tests. This reduces test time down to about 40 second, still too long, but bearable. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2018-11-26spl: Add support for passing handoff info to U-Boot properSimon Glass
There is some basic informaton that SPL normally wants to pass through to U-Boot, such as the SDRAM size and bank information. Mkae use of the new bloblist structure for this. Add a new 'handoff' blob which is set up in SPL and passed to U-Boot proper. Also adda test for sandbox_spl that checks that this works correctly and a new 'sb' command to show the information passed from SPL. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26sandbox: Drop the deprecated 'sb' commandSimon Glass
The old 'sb' command was deprecated in 2015 and replaced with 'host'. Remove the remaining users and the command, so that the name is available for other purposes. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26sandbox: Add an option to display of-platdata in SPLSimon Glass
At present we don't have a test that of-platdata can be accessed in SPL. Add this in as a command-line option to SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26test/py: Add a way to pass flags to sandboxSimon Glass
It is sometimes useful to restart sandbox with some particular flags to test certain functionality. Add a new method to ConsoleSandbox to handle this, without changing the existing APIs. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2018-11-26spl: Add a define for SPL_TPL_PROMPTSimon Glass
We should use a macro rather than hard-coding the SPL prompt to 'spl' since the code can be used by TPL too. Add a macro that works for both and use it in various places. This allows TPL to use the same code without printing confusing messages. Note that the string is lower case ('spl', 'tpl') which is a change from previously. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26test: Add a simple test for bloblistSimon Glass
Add a unit test for the bloblist functionality and enable bloblist for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26fs-test.sh: Update to use 'host' not 'sb'Tom Rini
For a long time now, 'sb' has been deprecated as a command in favor of using 'host' for the sandbox hostfs interface, switch. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-11-20sf: Add a method to obtain the block-protect settingSimon Glass
It is useful to obtain the block-protect setting of the SPI flash, so we know whether it is fully open or (perhaps partially) write-protected. Add a method for this. Update the sandbox driver to process this operation and add a test. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-20test: sf: Add a simple SPI flash testSimon Glass
The current test is a functional test, covering all the way from the command line to the sandbox SPI driver. This is useful, but it is easier to diagnose failures with a smaller test. Add a simple test which reads and writes data and checks that it is stored and retrieved correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-20misc: Update read() and write() methods to return bytes xferedSimon Glass
At present these functions return 0 on success. For some devices we want to know how many bytes were transferred. It seems useful to adjust the API to be more like the POSIX read() and write() functions. Update these two methods, a test and all users. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-11-20dm: core: Widen the dump tree to show more of the driver's name.Liviu Dudau
With drivers that have prefix names that are quite long (like 'versatile_') it is useful to have a wider column for the driver's name when dumping the device driver tree. Also update the tests to take into account the wider output format. Signed-off-by: Liviu Dudau <liviu.dudau@foss.arm.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-20dm: adc: add uclass's mask and conversion helpersFabrice Gasnier
Add two functions to ADC uclass's: - adc_raw_to_uV() to ease ADC raw value conversion to microvolts - adc_channel_mask() to get channels on consumer side Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-17dm: video: correctly set the cursor positionHeinrich Schuchardt
The terminal escape sequence ESC [ <x> ; <y> H is used to set the cursor position. According to the ECMA 48 standard the upper left corner in the escape sequences is [1, 1]. The video uclass uses [0, 0] as upper left corner. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-16test/py: test pinmux commandPatrice Chotard
Add pinmux test which test the following commands: - pinmux list - pinmux dev - pinmux status Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Mark some tests as sandbox-centric] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-11-14test: dm: virtio: Add test cases for virtio uclassBin Meng
Now that we have a sandbox virtio transport driver, add some test cases to test virtio uclass driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14test: dm: pci: Add cases for finding next PCI capability APIsBin Meng
Add test cases to cover the two newly added PCI APIs: dm_pci_find_next_capability() & dm_pci_find_next_ext_capability(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14test: dm: blk: Correct blk_base test caseBin Meng
The blk_base test case creates a USB mass storage block device with the Sandbox host block device as its parent. This does not make any sense and causes potential issue, for example if the test case tries to read/write anything on the USB mass storage block device it will definitely fail as its parent is not on USB bus at all. Correct the test case by creating another Sandbox host block device instead of the USB mass storage one and adjust the case accordingly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14test: dm: core: Add test case for uclass driver's child_post_probe()Bin Meng
Add test case to cover uclass driver's child_post_probe() method. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14test: regmap: Add test for regmap_{set, get}Mario Six
Add test for regmap_{set,get} functions. Reviewed-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-11-14test: regmap: Increase size of syscon0 memoryMario Six
The upcoming changes to the regmap interface will contain a proper check for plausibility when reading/writing from/to a register map. To still have the current tests pass, increase the size of the memory region for the syscon0 device, since one of the tests reads and writes beyond this range. Reviewed-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-11-14test: dm: core: Add a test case for driver marked with DM_FLAG_PRE_RELOC flagBin Meng
Now that we fixed the pre-relocation driver binding for driver marked with DM_FLAG_PRE_RELOC flag, add a test case to cover that scenario. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-01test: tee: fix resource leak in dm_test_tee()Jens Wiklander
Fixes possible resource leak in dm_test_tee() reported by Coverity. Reported-by: Coverity (CID: 184175) Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2018-10-22test: overlay: add missing includeHeinrich Schuchardt
Compiling the overlay unit test fails with odroid-c2_defconfig showing errors like: test/overlay/cmd_ut_overlay.c:29:8: error: unknown type name ‘fdt32_t’ Add the missing include. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-20test: Add test for PCI device without compat string and with DT nodeMarek Vasut
Add test which checks if a PCI device described in DT with an entry and reg = <...> property, but without compatible string results in a valid U-Boot PCI udevice with the udevice.node populated with reference to this DT node. Also check if the other PCI device without a DT node does not contain any bogus udevice.node. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-11Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2018-10-10net: Don't overwrite waiting packets with asynchronous repliesJoe Hershberger
Peter originally sent a fix, but it breaks a number of other things. This addresses the original reported issue in a different way. That report was: > U-Boot has 1 common buffer to send Ethernet frames, pointed to by > net_tx_packet. When sending to an IP address without knowing the MAC > address, U-Boot makes an ARP request (using the arp_tx_packet buffer) > to find out the MAC address of the IP addressr. When a matching ARP > reply is received, U-Boot continues sending the frame stored in the > net_tx_packet buffer. > > However, in the mean time, if U-Boot needs to send out any network > packets (e.g. replying ping packets or ARP requests for its own IP > address etc.), it will use the net_tx_packet buffer to prepare the > new packet. Thus this buffer is no longer the original packet meant > to be transmitted after the ARP reply. The original packet will be > lost. This instead uses the ARP tx buffer to send async replies in the case where we are actively waiting for an ARP reply. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Tran Tien Dat <peter.trantiendat@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-10test: eth: Add a test for the target being pingedJoe Hershberger
The target will respond to pings while doing other network handling. Make sure that the response happens and is correct. This currently corrupts the ongoing operation of the device if it happens to be awaiting an ARP reply of its own to whatever serverip it is attempting to communicate with. In the test, add an expectation that the user operation (ping, in this case) will fail. A later patch will address this problem. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-10test: eth: Add a test for ARP requestsJoe Hershberger
This tests that ARP requests made to this target's IP address are responded-to by the target when it is doing other networking operations. This currently corrupts the ongoing operation of the device if it happens to be awaiting an ARP reply of its own to whatever serverip it is attempting to communicate with. In the test, add an expectation that the user operation (ping, in this case) will fail. A later patch will address this problem. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-09sysreset: Add a way to find the last resetSimon Glass
We have a method to return the last reset as a string for humans, but not a method that allows it to be used programmatically. Add a new method that returns the last reset as an enum. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09sysreset: Tidy up a few comments and loggingSimon Glass
Some comments are incorrect or missing pieces. Fix these and use logging to print the error. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09panel: Expand the backlight supportSimon Glass
At present the panel can be turned on but not off, and the brightness cannot be controlled at run-time. Add a new API function to both the panel and backlight uclasses to handle this. Enhance the PWM backlight driver to deal with custom levels properly and allow the backlight to be turned on and off. Update the test to cover thes new features. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09test: panel: Add a test for the panel uclassSimon Glass
At present this uclass has no tests. Add a simple one which checks the PWM configuration, regulator and GPIO. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09dm: core: Update ofnode to read binman-style flash entrySimon Glass
At present ofnode_read_fmap_entry() reads a flash map entry in a format which is not supported by binman. To allow use to use binman-format descriptions, update this function. Also add a simple test. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09dm: core: Add a function to find the first inactive childSimon Glass
Some devices have children and want to press an existing inactive child into service when needed. Add a function to help with this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09sandbox: video: Speed up video outputSimon Glass
At present there are many situations where sandbox syncs the display to the SDL frame buffer. This is a very expensive operation but is only needed every now and then. Update video_sync() so that we can specify whether this operation is really needed. At present this flag is not used on other architectures. It could also be used for reducing writeback-cache flushes but the benefit of that would need to be investigated. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2018-10-09log: Add helpers for common log levelsSimon Glass
At present to output a log message you need something like: log(UCLASS_SPI, LOCL_INFO, "message1"); log(UCLASS_SPI, LOCL_INFO, "message2"); but many files use the same category throughout. Also it is helpful to shorten the length of log names, providing helpers for common logging levels. Add some macros so that it is possible to do: (top of file, before #includes) #define LOG_CATEGORY UCLASS_SPI (later in the file) log_info("message1"); log_debug("message2"); log_err("message3"); Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08binman: Run tests concurrentlySimon Glass
At present the tests run one after the other using a single CPU. This is not very efficient. Bring in the concurrencytest module and run the tests concurrently, using one process for each CPU by default. A -P option allows this to be overridden, which is necessary for code-coverage to function correctly. This requires fixing a few tests which are currently not fully independent. At some point we might consider doing this across all pytests in U-Boot. There is a pytest version that supports specifying the number of processes to use, but it did not work for me. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08test: Reduce the number of tests run with sandbox_flattreeSimon Glass
We only need to run driver-model tests with this config, since this is the only thing that is different when CONFIG_OF_LIVE is not defined. Filter out the other tests to same time. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08test: Tidy up comments and variable nameSimon Glass
The 'result' variable counts the number of failures in running the tests. Rename it to 'failures' to make this more obvious. Also tidy up a few comments. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08test: Print the name of each test before running itSimon Glass
At present the tests are run without any indication of what is running. For the tests which start with a build this is pretty obvious, but for tools it is not. Add a name for each test we run, and print it before starting the test. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08test: Simplify the PATH setupSimon Glass
Use 'export' to avoid repeating the path setup for each command. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08test/py: Fix unicode handling for log filteringSimon Glass
At present the unicode filtering seems to get confused at times with this error: UnicodeDecodeError: 'ascii' codec can't decode byte 0x80 in position 32: ordinal not in range(128) It seems to be due to self._nonprint being interpreted as UTF-8. Fix it by using ordinals instead of characters, changing the string to set. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Michal Simek <michal.simek@xilinx.com>
2018-10-08sandbox: Unprotect DATA regions in bus testsSimon Glass
On my Ubuntu 18.04.1 machine two driver-model bus tests have started failing recently. The problem appears to be that the DATA region of the executable is protected. This does not seem correct, but perhaps there is a reason. To work around it, unprotect the regions in these tests before accessing them. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-07test_avb: Update pymark.buildconfigspec information for the AVB testsJens Wiklander
Update the pymark.buildconfigspec to depend on 'cmd_mmc' in addition to 'cmd_avb' for those tests that needs more a more complete MMC implementation or the "mmc" command. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
