path: root/test
2013-12-13sandbox: dumpimage: Test dumpimageGuilherme Maciel Ferreira
Add a test for dumpimage. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-11-01dts, api, test: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-03sandbox: add compression testsKees Cook
This adds the "test_compression" command when building the sandbox. This tests the existing compression and decompression routines for simple sanity and for buffer overflow conditions. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-26Add verified boot information and testSimon Glass
Add a description of how to implement verified boot using signed FIT images, and a simple test which verifies operation on sandbox. The test signs a FIT image and verifies it, then signs a FIT configuration and verifies it. Then it corrupts the signature to check that this is detected. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Add a simple test for sandbox traceSimon Glass
It is difficult to automatically test tracing on most architectures, but with sandbox it is easy enough to do a simple sanity check. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Show stdout on error in fit-testSimon Glass
When this test fails it is useful to see the output from U-Boot. Add printing of this information on failure. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-04sandbox: image: Create a test for loading FIT imagesSimon Glass
The image code is fairly complex with various different options. It would be useful to have comprehensive tests for this. As a start, create a script which tries out loading a kernel/ramdisk/fdt from a FIT and checks that the images appear in the right place in memory. This uses sandbox which now supports bootm and related features. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-08-09sandbox: Add basic test for command executionSimon Glass
Since run_command() and run_command_list() are important and a little confusing, add some basic tests to check that the behaviour is correct. Note: I am not sure that this should be committed, nor where it should go in the source tree. Comments welcome. To run the unit tests use the ut_cmd command available in sandbox: make sandbox_config make ./u-boot -c ut_cmd (To test both hush and built-in parsers, you need to manually change CONFIG_SYS_HUSH_PARSER in include/configs/sandbox.h and build/run again) Signed-off-by: Simon Glass <sjg@chromium.org>
