path: root/test
2020-04-13Merge branch 'next'Tom Rini
Pull in changes that have been pending in our 'next' branch. This includes: - A large number of CI improvements including moving to gcc-9.2 for all platforms. - amlogic, xilinx, stm32, TI SoC updates - USB and i2c subsystem updtaes - Re-sync Kbuild/etc logic with v4.19 of the Linux kernel. - RSA key handling improvements
2020-04-10test/py: Allow using buildman to build U-BootSimon Glass
It is a pain to have to set the CROSS_COMPILE environment variable when using test.py's --build option. It is possible to get this using the -A option from buildman. But it seems better to just use buildman to do the build when it is available. However using buildman adds a new dependency to the test system which we want to avoid. So leave the default as is and add a flag to make it use buildman. Note that most of these changes relate to test.py and the parts of the travis/gitlab/azure scripts which relate to running test and building a suitable U-Boot to run the tests on. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-10test/py: Update u_boot_utils.find_ram_base to bypass the low 2MiB memoryBin Meng
On some RISC-V targets the low memory is protected that prevents S-mode U-Boot from access. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2020-04-09cmd: Add test and fix bugs for dm driversSean Anderson
Add a test for the dm drivers command. Also fix a null pointer dereference revealed by said test. Signed-off-by: Sean Anderson <seanga2@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-07Merge tag 'xilinx-for-v2020.07' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next Xilinx changes for v2020.07 common: - Align ENV_FAT_INTERFACE - Fix MAC address source print log - Improve based autodetection code xilinx: - Enable netconsole Microblaze: - Setup default ENV_OFFSET/ENV_SECT_SIZE Zynq: - Multiple DT updates/fixes - Use DEVICE_TREE environment variable for DTB selection - Switch to single zynq configuration - Enable NOR flash via DM - Minor SPL print removal - Enable i2c mux driver ZynqMP: - Print multiboot register - Enable cache commands in mini mtest - Multiple DT updates/fixes - Fix firmware probing when driver is not enabled - Specify 3rd backup RAM boot mode in SPL - Add SPL support for zcu102 v1.1 and zcu111 revA - Redesign debug uart enabling and psu_init delay - Enable full u-boot run from EL3 - Enable u-boot.itb generation without ATF with U-Boot in EL3 Versal: - Enable distro default - Enable others SPI flashes - Enable systems without DDR Drivers: - Gem: - Flush memory after freeing - Handle mdio bus separately - Watchdog: - Get rid of unused global data pointer - Enable window watchdog timer - Serial: - Change reinitialization logic in zynq serial driver Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-01test: vboot: Reduce fake kernel size to 500 bytesSimon Glass
We don't need 5KB to test things out. A smaller size makes it easier to look at the FIT with fdtdump. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-01test: vboot: Move key creation into a functionSimon Glass
This code is repeated so move it into a function with a parameter. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-01test: vboot: Fix pylint errorsSimon Glass
Fix various minor things noticed by pylint. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-01test: vboot: Tidy up the code a littleSimon Glass
Fix some long lines and comments. Use a distinct name for the 'required key' test. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-01test: vboot: Parameterise the testSimon Glass
This test is actually made up of five separate tests. Split them out so that they appear as separate tests. Unfortunately this restarts U-Boot multiple times which adds about a second to the already-long vboot test, about 8 seconds total on my machine. We could add a special 'teardown' test afterwards but if the tests are executed out of order that would not work. Changing test_vboot into a class causes it not to be discovered and makes it different from all other tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-01test: vboot: Add a test for a forged configurationSimon Glass
Add a check to make sure that it is not possible to add a new configuration and use the hashed nodes and hash of another configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-01test: vboot: Drop unnecessary parameter for fit_check_signSimon Glass
This tool only uses the last -k parameter provided. Drop the earlier one since it has no effect. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-03-31Merge branch 'next' of git://git.denx.de/u-boot-usb into nextTom Rini
2020-03-30test/py: test_efi_grub_net() requires OF_CONTROLHeinrich Schuchardt
With CONFIG_OF_CONTROL environment variable $fdtcontroladdr is not defined and test_efi_grub_net() fails. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-03-28test/py: UEFI helloworld requires OF_CONTROLHeinrich Schuchardt
With CONFIG_OF_CONTROL environment variable $fdtcontroladdr is not defined and test_efi_helloworld_net() fails. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-03-27test: typo decompressionHeinrich Schuchardt
%s/decopmression/decompression/ Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-03-27test/py: mmc: Fix 'mmc info' testcaseHarald Seiler
Commit 41e30dcf8796 ("cmd: mmc: Make Mode: printout consistent") fixed the layout of `mmc info` output. Reflect this change in the respective testcase. Also fix a typo in the documentation. Fixes: 41e30dcf8796 ("cmd: mmc: Make Mode: printout consistent") Signed-off-by: Harald Seiler <hws@denx.de> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-03-13cmd: gpio: Make `gpio input` return pin value againAlex Kiernan
4dbc107f4683 ("cmd: gpio: Correct do_gpio() return value") correctly changed the behaviour of the gpio command to return CMD_RET_SUCCESS or CMD_RET_FAILURE, but any existing script which expects the return value to be the pin value is broken by this change. Reinstate the legacy behaviour for `gpio input` only. Fixes: 4dbc107f4683 ("cmd: gpio: Correct do_gpio() return value") Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Signed-off-by: Alex Kiernan <alex.kiernan@hivehome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-03-12test: add rsa_verify() unit testAKASHI Takahiro
In this patch, a very simple test is added to verify that rsa_verify() using rsa_verify_with_pkey() work correctly. To keep the code simple, all the test data, either public key and verified binary data, are embedded in the source. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2020-02-13test: aes: fix memleakPhilippe Reynes
In the first version, the result of malloc is checked with ut_assertnonnull. But on a fail, this macro exit the function, so previously malloc are not freed. So to avoid a memleak, we don't use ut_assertnonnull, but simply check the return of malloc. If one has failed, we freed all the allocated memory and quit the function. Reported-by: Coverity (CID: 284403) Reported-by: Coverity (CID: 284404) Reported-by: Coverity (CID: 284405) Reported-by: Coverity (CID: 284406) Reported-by: Coverity (CID: 284407) Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2020-02-11Merge tag 'dm-pull-6feb20' of https://gitlab.denx.de/u-boot/custodians/u-boot-dmTom Rini
sandbox conversion to SDL2 TPM TEE driver Various minor sandbox video enhancements New driver model core utility functions
2020-02-10Merge https://gitlab.denx.de/u-boot/custodians/u-boot-x86Tom Rini
- Move P2SB from Apollo Lake to a more generic location - Add a function to find a device by drvdata in DM core - Enhancement of DM IRQ uclass driver - Add a clock driver for Intel devices - Add support for ACPI general-purpose events - Add a TPM driver for H1/Cr50 - Enable TPM on Google Chromebook Coral
2020-02-07dm: irq: Add support for requesting interruptsSimon Glass
At present driver model supports the IRQ uclass but there is no way to request a particular interrupt for a driver. Add a mechanism, similar to clock and reset, to read the interrupts required by a device from the device tree and to request those interrupts. U-Boot itself does not have interrupt-driven handlers, so just provide a means to read and clear an interrupt. This can be useful to handle peripherals which must use an interrupt to determine when data is available, for example. Bring over the basic binding file as well, from Linux v5.4. Note that the older binding is not supported in U-Boot; the newer 'special form' must be used. Add a simple test of the new functionality. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-02-07dm: irq: Add support for interrupt controller typesSimon Glass
There can be different types of interrupt controllers in a system and some drivers may need to distinguish between these. In general this can be handled using the device tree by adding the interrupt information to device nodes. However on x86 devices we have interrupt controllers which are not tied to any particular device and not really used in U-Boot. These still need to be inited, so a convenient method is to give each controller a type and allow a particular controller type to be probed. Add support for this in sandbox along with a test. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: remove the new bland line at EOF of test/dm/irq.c] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2020-02-07dm: core: Add a function to find a device by drvdataSimon Glass
It is sometimes useful to find a device in a uclass using only its driver data. The driver data often indicates the 'subtype' of the device, e,g, via its compatible string. Add a function to handle this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-02-07dm: core: Allow iterating devices without uclass_get()Simon Glass
At present we have uclass_foreach_dev() which requires that uclass_get() be called beforehand to find the uclass. This is good if we suspect that that function might fail, but often we know that the uclass is available. Add a new helper which does this uclass_get() automatically, so that only the uclass ID is needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Require users of devres to include the headerSimon Glass
At present devres.h is included in all files that include dm.h but few make use of it. Also this pulls in linux/compat which adds several more headers. Drop the automatic inclusion and require files to include devres themselves. This provides a good indication of which files use devres. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2020-02-05sound: Add a new stop_play() methodSimon Glass
At present there is no positive indication that U-Boot has finished sending sound data. This means that it is not possible to power down an audio codec, for example. Add a new method that is called once all sound data has been sent. Add a new method for this, called when the sound_play() call is done. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05test: Add a way to check each line of console outputSimon Glass
When writing tests to check the output from commands it is useful to be able to check the output line by line using an assertion. Add helper macros to support this and to check that there is no unexpected trailing data. Also some commands produce a dump using print_buffer(). Add a way to check that the correct number of bytes are dumped (ignoring the actual contents). Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05test: Enable console recording in testsSimon Glass
At present we reset the console buffer before each test but do not actually set the recording flag. Without this, the output is not recorded. Update the code to set the flag before the test and clear it afterwards. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05bloblist: Zero records when addingSimon Glass
It is convenient for bloblist to zero out the contents of a records when it is added. This saves the callers having to do it. Update the API accordingly. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05bloblist: Add a new function to add or check sizeSimon Glass
A common check is to see if a blob is present, create it if not and make sure that the size is large enough. Add a function to handle this. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Add a way to iterate through children, probing eachSimon Glass
It is sometimes useful to process all children, making sure they are probed first. Add functions to help with this and a macro to make it more convenient. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Add a way to read platdata for all child devicesSimon Glass
When generating ACPI tables we need to make sure that all devices have read their platform data, so that they can generate the tables correctly. Rather than adding this code in ACPI, create a core function to handle it. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Add ofnode_get_chosen_prop()Simon Glass
Add a function to read a property from the chosen node, providing access to its length. Update ofnode_get_chosen_string() to make use of it. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Add ofnode_read_prop()Simon Glass
Add a new function to read a property that supports reading the length as well. Reimplement ofnode_read_string() using it and fix its comment. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Rename ofnode_get_chosen_prop()Simon Glass
This function is actually intended to read a string rather than a property. All of its current callers use it that way. Also there is no way to return the length of the property from this function. Rename it to better indicate its purpose, using ofnode_read as the prefix since this matches most other functions. Also add some tests which are missing for these functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05test: efi_selftest: fix pylint warningsHeinrich Schuchardt
Fix pylint warnings: * add missing module and function documentation * correct indentation Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-02-05test: test_efi_fit: fix pylint warningsHeinrich Schuchardt
Fix warnings issued by pylint: * naming of variables * usage of commas and semicolons * indentation * placement of module description Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-02-04test/py: android: Add test for abootimgSam Protsenko
Unit test for 'abootimg' command. Right now it covers dtb/dtbo functionality in Android Boot Image v2, which was added recently. Running test: $ ./test/py/test.py --bd sandbox --build -k test_abootimg shows that 1/1 tests passes successfully. Signed-off-by: Sam Protsenko <joe.skb7@gmail.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-02-04doc: android: Convert to Sphinx formatSam Protsenko
Convert Android documentation from regular txt format to Sphinx (RST). Also add Android index.rst file and reference it in root index.rst, so that Android documentation is visible. Test: $ make htmldocs $ xdg-open doc/output/index.html Signed-off-by: Sam Protsenko <joe.skb7@gmail.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-30Consistently use nproc for counting the CPUsHeinrich Schuchardt
Coreutils command nproc can be used on Linux and BSD to count the number of available CPU cores. Use this instead of relying on the parsing of the Linux specific proc file system. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-27test: dm: spi: Fix sandbox dm_test_spi_find()Bin Meng
Per sandbox_cs_info(), sandbox spi controller only supports chip select 0. Current test case tries to locate devices on chip select 1, and any call to spi_get_bus_and_cs() or spi_cs_info() with cs number 1 should not return 0. This updates the test case to handle it correctly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2020-01-17aes: add test unit for aes196 and aes256Philippe Reynes
This commit add test unit for aes196 and aes256. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-17aes: add test unit for aes128Philippe Reynes
This commit add test unit for aes128. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-16Merge tag 'xilinx-for-v2020.04' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze Xilinx/FPGA changes for v2020.04 ARM64: - Add INIT_SPL_RELATIVE dependency SPL: - FIT image fix - Enable customization of bl2_plat_get_bl31_params() Pytest: - Add test for octal/hex conversions Microblaze: - Fix manual relocation for one SPI instance Nand: - Convert zynq/zynqmp drivers to DM Xilinx: - Enable boot script location via Kconfig - Support OF_SEPARATE in board FDT selection - Remove low level uart setup it is done later by code - Add support for DEVICE_TREE variable passing for SPL Zynq: - Enable jtag boot mode via distro boot - Removing unused baseaddresses from hardware.h - DT fixups ZynqMP: - Fix emmc boot sequence - Simplify spl logic around bss and board_init_r() - Support psu_post_config_data() calling - Tune mini-nand DTS - Fix psu wiring for a2197 boards - Add runtime MMC device boot order filling in spl - Clear ATF handoff handling with custom bl2_plat_get_bl31_params() - Add support u-boot.its generation - Use single image configuration for all platforms - Enable PANIC_HANG via Kconfig - DT fixups - Firmware fixes - Add support for zcu208 and zcu1285 Versal: - Fix emmc boot sequence - Enable board_late_init() by default
2020-01-15test/py: use valid device tree in test_fit.pyHeinrich Schuchardt
The device tree compiler expects that a node with a unit-address has a reg property. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-14test/py: hush_if_test: Add tests to cover octal/hex valuesMichal Simek
Extend test suite to cover also automatic octal/hex converstions which haven't been implemented in past. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2020-01-10test/cmd_ut.c: fix cmd_ut_categoryPhilippe Reynes
In the function cmd_ut_category, the prefix is used with the function strncmp to know if the prefix should be removed from the test name, even if the prefix is NULL. To avoid this issue, we consider that a prefix NULL mean no prefix. So we only try to remove the prefix from the test_name if the prefix is not NULL, then we avoid to call the function strncmp with a NULL prefix. Reported-by: Coverity CID 281110 Fixes: 4ad4edfe ("cmd_ut: add a parameter prefix to the function cmd_ut_category") Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
