path: root/test
2018-02-03log: Add tests for the new log featuresSimon Glass
Add a test of the 'log format' and 'log rec' commands. This also covers things like log_get_cat_by_name(), since they are used by these commands. Fix a style nit in the tests also. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-02-03log: Update log_console to honour the log formatSimon Glass
At present this just outputs the message. Update it to output whatever the format requests. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-02-03dm: core: Add a function to look up a uclass by nameSimon Glass
Each uclass has a driver name which we can use to look up the uclass. This is useful for logging, where the uclass ID is used as the category. Add a function to handle this, as well as a test. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-28vsprintf.c: correct printing of a NULL device pathHeinrich Schuchardt
When printing '%pD' with a value of NULL we want to output '<NULL>'. But this requires copying to buf. Leave this to string16. A unit test is supplied which relies on EFI support in the sandbox. The development for EFI support in the sandbox is currently in branch u-boot-dm/efi-working. The branch lacks commit 6ea8b580f06b ("efi_loader: correct DeviceNodeToText for media types"). Ater rebasing the aforementioned branch on U-Boot v2018.01 and adding 256060e4257a2 and this patch the test is executed successfully. Fixes: 256060e4257a2 (vsprintf.c: add EFI device path printing) Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28host-tools: use python2 explicitly for shebangMasahiro Yamada
All of these host tools are apparently written for Python2, not Python3. Use 'python2' in the shebang line according to PEP 394 (https://www.python.org/dev/peps/pep-0394/). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-22vsprintf.c: add EFI device path printingHeinrich Schuchardt
For debugging efi_loader we need the capability to print EFI device paths. With this patch we can write: debug("device path: %pD", dp); A possible output would be device path: /MemoryMapped(0x0,0x3ff93a82,0x3ff93a82) This enhancement is not available when building without EFI support and neither in the SPL nor in the API example. A test is provided. It can be executed in the sandbox with command ut_print. The development for EFI support in the sandbox is currently in branch u-boot-dm/efi-working. The branch currently lacks commit 6ea8b580f06b ("efi_loader: correct DeviceNodeToText for media types"). Ater rebasing the aforementioned branch on U-Boot v2018.01 the test is executed successfully. Without EFI support in the sandbox the test is simply skipped. Suggested-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-15test: Set the DTC environment variableSimon Glass
Set this to our own device-tree compiler since we know it is new enough to run the tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-15binman: Run code coverage testsSimon Glass
Binman has 100% test coverage for the code as it is at present. To encourage it to stay that way, run the code-coverage test as part of the normal U-Boot tests. This is RFC because it requires the Python code coverage tools to be available. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-15test: Run dtoc testsSimon Glass
Update the test script to run the dtoc tests also. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-15test: Run buildman testsSimon Glass
Update the test script to run the buildman tests also. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-15test: Run patman testsSimon Glass
Update the test script to run the patman tests also. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-15test: Run binman testsSimon Glass
Update the test script to run the binman tests also. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-01-15dm: core: parse chosen nodeRob Clark
This is the node that would contain, for example, the framebuffer setup by an earlier stage. Signed-off-by: Rob Clark <robdclark@gmail.com>
2017-12-18Merge tag 'xilinx-for-v2018.01-rc2-v2' of ↵Tom Rini
git://www.denx.de/git/u-boot-microblaze Xilinx changes for v2018.01-rc2-v2 fpga: - Enable loading bitstream via fit image for !xilinx platforms zynq: - Fix SPL SD boot mode zynqmp: - Not not reset in panic - Do not use simple allocator because of fat changes - Various dt chagnes - modeboot variable setup - Fix fpga loading on automotive devices - Fix coverity issues test: - Fix env test for !hush case - Stephen's patch
2017-12-18test/py: Setup variables based on HUSH selectionStephen Warren
After adding our small zynq uboot which has hush parser off same variable tests start to failed. Use quotes only when hush is enabled. Reported-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2017-12-14Merge git://git.denx.de/u-boot-dmTom Rini
2017-12-12power: extend prefix match to regulator-name propertyFelix Brack
This patch extends pmic_bind_children prefix matching. In addition to the node name the property regulator-name is used while trying to match prefixes. This allows assigning different drivers to regulator nodes named regulator@1 and regulator@10 for example. I have discarded the idea of using other properties then regulator-name as I do not see any benefit in using property compatible or even regulator-compatible. Of course I am open to change this if there are good reasons to do so. Signed-off-by: Felix Brack <fb@ltec.ch> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-12-12test: py: Add an option to skip sleep testMichal Simek
Some QEMUs have a problem with time setup that's why sleep test is failing. Introduce env__sleep_accurate boardenv variable to have an option to skip sleep test. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2017-12-12test/py: gpt: update size of gpt partitionPatrick Delaunay
- avoid disturbing 0MiB partition size (in fact < 1MiB) - test overlap limit between part1 and part2 - test gpt write with data with modifier 'M' for MiB Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2017-12-07log: test: Add a pytest for loggingSimon Glass
Add a test which tries out various filters and options to make sure that logging works as expected. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-07log: Add a test commandSimon Glass
Add a command which exercises the logging system. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-05Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2017-12-05 Highlights for this release: - Dynamic EFI object creation (lists instead of static arrays) - EFI selftest improvements - Minor fixes
2017-12-04test: compression: Convert to unit test frameworkSimon Glass
Adjust this test to use the unit test framework. Drop the two existing commands for running the tests and replace them with a single 'ut compression' command, with sub-commands. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Continue to have ret = run_test_internal(...) in run_test so ret is always initialized] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-02test/py: Allow any unit test suite to be foundSimon Glass
The u-boot.sym file is scanned to find unit test suites for execution. At present it only finds those whose names start with 'dm' or 'env'. This code is buried in the bowels of the test code so when adding a new suite it is not easy to discover why it is ignored by the test framework. There seems to be no need to make this restriction. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2017-12-02test: compression: Put test variables in a structSimon Glass
At present the test setup is somewhat mixed with the test itself. But if the test setup fails (which it should not) then the test is actually invalid. Put all the test buffers and sizes in a struct and separate out the core code into a function. This will make it easier to move the code to use the unit test framework. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-02test: overlay: Use cmd_ut_category()Simon Glass
Adjust the code to use the common test-execution function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-02test: Add a command function for test executionSimon Glass
The logic to either iterate through a list of tests or pick a named test is common to at lest two test suits. Move this logic into a new function and call it from the environment tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-01test/py: check return code of helloworldHeinrich Schuchardt
Check that helloworld.efi returns EFI_SUCCESS. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-01test/py: fix typo in test_efi_loader.pyHeinrich Schuchardt
Make a comment line easier to read. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-01test/py: test reboot by EFI watchdogHeinrich Schuchardt
Clear environment variable efi_selftest before executing the default tests. Provide a test verifying that the EFI watchdog reboots the system upon timeout. The test depends on CONFIG_CMD_EFI_SELFTEST=y. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-11-27test: Correct operation when tests passSimon Glass
When tests pass an error message is printed because of a variable that is not initialised. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-22test/run: Report and return failureSimon Glass
This script runs the tests but does not report failure. Also it always returns an exit code of 0 even on failure. Fix these problems by checking the result of each test. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-17test/py: add timestamps to logStephen Warren
It can be useful to record how long tests take; this can help debug slow running test systems or track changes in performance over time. Enhance the test system to record timestamps while running test: - Whenever a new log file section is started. - After U-Boot is started and communication has been established. - After each host or U-Boot command is executed. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2017-11-06test/py: regenerate persistent GPT image if code changesStephen Warren
test_gpt generates a persistent disk image which can be re-used across multiple test runs. Currently, if the Python code that generates the disk image change, the image is not regenerated, which could cause test failures e.g. if a test was updated to expect some new partition name or size, yet the persistent disk image contained the old name or size. This change introduces functionality to regenerate the disk image if the instructions to generate the image have changed. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2017-10-23test/py: fix typos in README.mdMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2017-10-23cmd: gpt: solve issue for swap and rename commandPatrick Delaunay
don't use prettyprint_part_size() in create_gpt_partitions_list() that avoid to align offset and size to 1 MiB and increase precision for start and size. This patch avoid the risk to change partition size and lost data during rename or swap. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2017-10-23test/py: gpt: test start LBA for sub-command rename and swapPatrick Delaunay
Add test of first and last LBA in gpt for rename and swap. Only the name is expected to change, so test 3 columns for part command 1: first LBA (start) 2: last LBA (end) 3: partition name After rename, the last LBA change and it is a error in current U-Boot code + "first" = 0x7ff : invalid value (<start) + "second" = 0x17ff => size increasing ! Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-10-23test/py: gpt: add test for sub-command writePatrick Delaunay
+ test write for one partition on all the device (size=0) + test write with disk uuid and 2 partitions Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-10-23test/py: gpt: add test for sub-command read and verifyPatrick Delaunay
add sandbox test for some gpt sub-command - gpt read / part list : read the gpt partition created by sgdisk on host test start, size, LBA and name output - gpt verify : verify the gpt partition create by sgdisk on host PS: persistent data test_gpt_disk_image.bin are udpated Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-10-23test/py: gpt: copy persistent filePatrick Delaunay
copy the persistent gpt binary file as it can be modified during the test that avoid issue if the test fail: the test always restart with clean file Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2017-10-16test/py/tests/test_sleep.py: test time approximatelyHeinrich Schuchardt
On qemu errors like assert 2.999650001525879 >= 3 occur. According to the comment in the code the test is meant to be approximate. So we should accept some milliseconds less. Cc: Stephen Warren <swarren@nvidia.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2017-10-09Merge git://git.denx.de/u-boot-dmTom Rini
2017-10-09Merge git://git.denx.de/u-boot-videoTom Rini
2017-10-08test: print_ut: Add test for %ls stringsRob Clark
Add a simple test for long strings. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-06test/dm: Fix string handling issues in the eth testTom Rini
Coverity scan has identified potential buffer overruns in these tests. Correct this by zeroing our buffer and using strncpy not strcpy. Reported-by: Coverity (CID: 155462, 155463) Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2017-10-06test/overlay: Fix various malloc/free leaksTom Rini
With the overlay tests now being built in sandbox Coverity has found a number of issues in the tests. In short, if malloc ever failed we would leak the previous mallocs, so we need to do the usual goto pattern to free each in turn. Finally, we always looked at the free()d location to see how many tests had failed for the return code. Reported-by: Coverity (CID: 167224, 167227, 167230, 167236) Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06fs-test: Add test for a filename using '..' to go back to the rootTuomas Tynkkynen
The previous commit fixed a problem in FAT code where going back to the root directory using '..' wouldn't work correctly on FAT12 or FAT16. Add a test to exercise this case (which was once fixed in commit 18a10d46f26 "fat: handle paths that include ../" but reintroduced due to the directory iterator refactoring). This test only very barely catches the problem - without the fix the size command still gives valid output but the additional spurious "Invalid FAT entry" error message makes it not get caught in the 'egrep -A3 ' output. I tried to make a proper test that grows the root directory to two clusters lots of with dummy files but that causes the write tests to crash the sandbox totally... Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-10-06fs-test: Add FAT16 supportTuomas Tynkkynen
Currently we can only test FAT32 which is the default FAT version that mkfs.vfat creates by default. Instead make it explicitly create either a FAT16 or a FAT32 volume. This allows us to exercise more code, for instance the root directory handling is done differently in FAT32 than the older FATs. Adding FAT12 support is a much bigger job since the test creates a 2.5GB file and the FAT12 maximum partition size is way smaller than that. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-10-01Merge git://git.denx.de/u-boot-usbTom Rini
2017-10-01test: dm: usb: Update test cases for USBBin Meng
Now that we have changed to remove all devices under the root hub in usb_stop(), and corrected the USB emulator select logic, it makes no sense to do various tests based on 'usb tree' output since the order of devices is no longer fixed. Remove these USB test cases related to 'usb tree'. For the USB remove test, ideally we should remove an emulator device node from the device tree, but this is so far not working. Change to test the 'usb stop' only. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
