path: root/test/run
2016-07-14test: Add a simple script to run tests on sandboxSimon Glass
A common check before sending patches is to run all available tests on sandbox. But everytime I do this I have to look up the README. This presents quite a barrier to actually doing this. Add a shell script to help. To run the tests, type: test/run in the U-Boot directory, which should be easy to remember. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Teddy Reed <teddy.reed@gmail.com>
