path: root/test/py
2019-05-09test/py: don't use mmc_rd config for other mmc testsStephen Warren
Fix test_mmc_dev(), test_mmc_rescan(), test_mmc_info() not to use the same configuration data that test_mmc_rd() does. Doing so causes the following issues: * The new code uncondtionally expects certain keys to exist in the configuration data. These keys do not exist in existing configuration data since they were not previously required, and there was no notification re: a requirement to add these new keys. This causes test failures due to thrown exceptions when accessing the non-existent keys. * The new tests logically operate on different objects. test_mmc_rd() operates on ranges of sectors on an MMC device (which may be the entire set of sectors of a device, or a part of a device), whereas all the new tests operate solely on entire devices. These are separate things, and it's entirely likely that the user will wish to runs the two types of tests on different sets of data; see the example configuration data that this commit adds. Ideally, the new tests would have been added to a separate Python file, since they aren' closely related to the existing tests. FIXME: Marek, can you please replace the "???" in this patch with some reasonable looking data? Thanks. Cc: Marek Vasut <marek.vasut@gmail.com> Fixes: 4ffec8cdf512 ("test/py: mmc: Add 'mmc info' test") Fixes: ce4b2cafa79c ("test/py: mmc: Add 'mmc rescan' test") Fixes: 86dfd152c917 ("test/py: mmc: Add 'mmc dev' test") Signed-off-by: Stephen Warren <swarren@nvidia.com>
2019-04-26avb: add support for named persistent valuesIgor Opaniuk
AVB 2.0 spec. revision 1.1 introduces support for named persistent values that must be tamper evident and allows AVB to store arbitrary key-value pairs [1]. Introduce implementation of two additional AVB operations read_persistent_value()/write_persistent_value() for retrieving/storing named persistent values. Correspondent pull request in the OP-TEE OS project repo [2]. [1]: https://android.googlesource.com/platform/external/avb/+/android-9.0.0_r22 [2]: https://github.com/OP-TEE/optee_os/pull/2699 Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org> Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
2019-04-23efi_selftest: do not run FDT test with ACPI table.Heinrich Schuchardt
The EBBR specification prescribes that we should have either an ACPI table or a device tree but not both. So do not run the device tree unit test on boards with an ACPI table. Hence there is no need any longer to make it 'on request' only. Do not pass $fdtcontroladdr to `bootefi selftest`. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-04-23test/py: pytest.mark.notbuildconfigspec()Heinrich Schuchardt
We already can let a Python test depend on a build option being set via @pytest.mark.buildconfigspec(). It may be necessary to let a test depend on a build option *not* being set. So let's introduce @pytest.mark.notbuildconfigspec for this purpose. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-04-16test: py: Extend fpga test with fit image with external dataMichal Simek
Images are created mkimage -f fit.its -E download-fit-external.ub and test expects these entries. env__fpga_under_test = { ... "mkimage_fit_external": download-fit-external.ub", "mkimage_fit_external_size": xxxxx, ... } Test download file and loads it to fpga. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-04-10test.py: Disable fsck for FAT tests for nowTom Rini
Currently enabling fsck on FAT16/FAT32 exposes that we have problems with: TestFsBasic.test_fs13[fat16] TestFsBasic.test_fs11[fat32] TestFsBasic.test_fs12[fat32] TestFsBasic.test_fs13[fat32] TestFsExt.test_fs_ext1[fat32] TestFsExt.test_fs_ext2[fat32] TestFsExt.test_fs_ext3[fat32] TestFsExt.test_fs_ext4[fat32] TestFsExt.test_fs_ext5[fat32] TestFsExt.test_fs_ext6[fat32] TestFsExt.test_fs_ext7[fat32] TestFsExt.test_fs_ext8[fat32] TestFsExt.test_fs_ext9[fat32] TestMkdir.test_mkdir6[fat16] TestMkdir.test_mkdir1[fat32] TestMkdir.test_mkdir2[fat32] TestMkdir.test_mkdir3[fat32] TestMkdir.test_mkdir4[fat32] TestMkdir.test_mkdir5[fat32] TestMkdir.test_mkdir6[fat32] TestUnlink.test_unlink1[fat16] TestUnlink.test_unlink2[fat16] TestUnlink.test_unlink3[fat16] TestUnlink.test_unlink4[fat16] TestUnlink.test_unlink5[fat16] TestUnlink.test_unlink6[fat16] TestUnlink.test_unlink7[fat16] TestUnlink.test_unlink1[fat32] TestUnlink.test_unlink2[fat32] TestUnlink.test_unlink3[fat32] TestUnlink.test_unlink4[fat32] TestUnlink.test_unlink5[fat32] TestUnlink.test_unlink6[fat32] TestUnlink.test_unlink7[fat32] This is because we don't update the "information sector" on FAT32. While in the future we should resolve this problem and include that feature, we should enable fsck for ext4 to ensure that things remain in good shape there. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-09test/py: mmc: Add 'mmc read' performance checkMarek Vasut
Add option to the mmc rd test to check the duration of the execution of the mmc read command. This allows intercepting read performance regressions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-04-09test/py: mmc: Add 'mmc info' testMarek Vasut
Add test for 'mmc info' subcommand. This tests whether the card information is obtained correctly and verifies the device, bus speed, bus mode and bus width. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-04-09test/py: mmc: Add 'mmc rescan' testMarek Vasut
Add test for 'mmc rescan' subcommand. This tests whether the system can switch to a specific card and then rescan the card. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-04-09test/py: mmc: Add 'mmc dev' testMarek Vasut
Add separate test for 'mmc dev' subcommand. This tests whether the system can switch to a specific card. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-04-09test/py: mmc: Factor out device selectionMarek Vasut
Factor out the 'mmc dev' call so it can be recycled by other tests. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-04-09test: fs: Added tests for symlinksJean-Jacques Hiblot
Test cases are: 1) basic link creation, verify it can be followed 2) chained links, verify it can be followed 3) replace exiting file a with a link, and a link with a link. verify it can be followed 4) create a broken link, verify it can't be followed Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-09test: fs: Add filesystem integrity checksJean-Jacques Hiblot
We need to make sure that file writes,file creation, etc. are properly performed and do not corrupt the filesystem. To help with this, introduce the assert_fs_integrity() function that executes the appropriate fsck tool. It should be called at the end of any test that modify the content/organization of the filesystem. Currently only supports FATs and EXT4. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-09test: fs: disable the metadata checksums on ext4 filesystemsJean-Jacques Hiblot
If the metadata checksums are enabled, all write operations will fail. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-07efi_loader: correct CTRL-A - CTRL-Z console inputHeinrich Schuchardt
In the extended text input protocol CTRL-A - CTRL-Z have to be signaled as Unicode characters a-z or A-Z depending on the shift state and not as 0x01 to 0x1a. Update Python unit test. This patch is required for using the EFI shell `edit` command. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-19test: let use gdbserver for all sandbox targetsIgor Opaniuk
Enable usage of gdbserver for all sandbox targets (sandbox, sandbox_flattree etc.). Signed-off-by: Igor Opaniuk <igor.opaniuk@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-02-12test/py: use default load address for tftpHeinrich Schuchardt
On x86_64 the size of the file u-boot loaded by the tftp test has grown in size such that when loading the file to 0x200000 it overwrites a memory area reserved for PCI. If no load address is specified for tftp do not use the ram base address (or if zero 0x200000) but the default address. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-01-15Merge tag 'dm-pull-15jan19' of git://git.denx.de/u-boot-dmTom Rini
Fix recent changes to serial API for driver model Buildman clang support and a few fixes Small fixes to 'dm tree' and regmap test Improve sandbox build compatibility A few other minor fixes
2019-01-15test: Use single quote consistentlySimon Glass
Some tests have ended up using double quotes where single quotes could be used. Adjust this for consistency with the rest of U-Boot's Python code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-01-14dm: Tidy up 'dm tree' output when there are many devicesSimon Glass
At present the 'Index' column assumes there is only one digit. But on some devices (e.g. snow) there are a lot of regulators and GPIO banks. Adjust the output to allow for two digits without messing up the display. Also capatalise the heading to match. Fixes: 5197dafc42 (dm: core: Widen the dump tree to show more of the driver's name.) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Liviu Dudau <liviu.dudau@foss.arm.com>
2018-12-07spl/tpl: change banner into upper caseHeiko Schocher
commit d6330064634a ("spl: Add a define for SPL_TPL_PROMPT") changes the SPL/TPL banner from upper case into lower case. As SPL and TPL are three-letter acronyms and they are written in upper case, change it back to upper case. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-03Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-12-03 This release is fully packed with lots of glorious improvements in UEFI land again! - Make PE images more standards compliant - Improve sandbox support - Improve correctness - Fix RISC-V execution on virt model - Honor board defined top of ram (fixes a few boards) - Imply DM USB access when distro boot is available - Code cleanups
2018-12-03test: vboot: clean its filePhilippe Reynes
This update the its file used in vboot test to respect the new node style name defined in doc/uImage.FIT (for example: replace kernel@1 by kernel and fdt@1 by fdt-1) Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-03test: vboot: add padding pss for rsa signaturePhilippe Reynes
The padding pss is now supported for rsa signature. This add test with padding pss on vboot test. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-02efi_selftest: check fdt is marked as runtime dataHeinrich Schuchardt
Check that the memory area containing the device tree is marked as runtime data. Update the Python test to pass ${fdtcontroladdr} to bootefi. Update the description of the Python test. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-11-29test: Add a 'make qcheck' target for quicker testingSimon Glass
At present tests are quite slow to run, over a minute on my machine. This presents a considerable barrier to bisecting for failures. The slowest tests are the filesystem ones and the buildman --fetch-arch test. Add a new 'qcheck' target that skips these tests. This reduces test time down to about 40 second, still too long, but bearable. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26spl: Add support for passing handoff info to U-Boot properSimon Glass
There is some basic informaton that SPL normally wants to pass through to U-Boot, such as the SDRAM size and bank information. Mkae use of the new bloblist structure for this. Add a new 'handoff' blob which is set up in SPL and passed to U-Boot proper. Also adda test for sandbox_spl that checks that this works correctly and a new 'sb' command to show the information passed from SPL. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26sandbox: Drop the deprecated 'sb' commandSimon Glass
The old 'sb' command was deprecated in 2015 and replaced with 'host'. Remove the remaining users and the command, so that the name is available for other purposes. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26sandbox: Add an option to display of-platdata in SPLSimon Glass
At present we don't have a test that of-platdata can be accessed in SPL. Add this in as a command-line option to SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26test/py: Add a way to pass flags to sandboxSimon Glass
It is sometimes useful to restart sandbox with some particular flags to test certain functionality. Add a new method to ConsoleSandbox to handle this, without changing the existing APIs. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2018-11-26spl: Add a define for SPL_TPL_PROMPTSimon Glass
We should use a macro rather than hard-coding the SPL prompt to 'spl' since the code can be used by TPL too. Add a macro that works for both and use it in various places. This allows TPL to use the same code without printing confusing messages. Note that the string is lower case ('spl', 'tpl') which is a change from previously. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-20dm: core: Widen the dump tree to show more of the driver's name.Liviu Dudau
With drivers that have prefix names that are quite long (like 'versatile_') it is useful to have a wider column for the driver's name when dumping the device driver tree. Also update the tests to take into account the wider output format. Signed-off-by: Liviu Dudau <liviu.dudau@foss.arm.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-16test/py: test pinmux commandPatrice Chotard
Add pinmux test which test the following commands: - pinmux list - pinmux dev - pinmux status Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Mark some tests as sandbox-centric] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-10-09log: Add helpers for common log levelsSimon Glass
At present to output a log message you need something like: log(UCLASS_SPI, LOCL_INFO, "message1"); log(UCLASS_SPI, LOCL_INFO, "message2"); but many files use the same category throughout. Also it is helpful to shorten the length of log names, providing helpers for common logging levels. Add some macros so that it is possible to do: (top of file, before #includes) #define LOG_CATEGORY UCLASS_SPI (later in the file) log_info("message1"); log_debug("message2"); log_err("message3"); Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08binman: Run tests concurrentlySimon Glass
At present the tests run one after the other using a single CPU. This is not very efficient. Bring in the concurrencytest module and run the tests concurrently, using one process for each CPU by default. A -P option allows this to be overridden, which is necessary for code-coverage to function correctly. This requires fixing a few tests which are currently not fully independent. At some point we might consider doing this across all pytests in U-Boot. There is a pytest version that supports specifying the number of processes to use, but it did not work for me. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08test/py: Fix unicode handling for log filteringSimon Glass
At present the unicode filtering seems to get confused at times with this error: UnicodeDecodeError: 'ascii' codec can't decode byte 0x80 in position 32: ordinal not in range(128) It seems to be due to self._nonprint being interpreted as UTF-8. Fix it by using ordinals instead of characters, changing the string to set. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Michal Simek <michal.simek@xilinx.com>
2018-10-07test_avb: Update pymark.buildconfigspec information for the AVB testsJens Wiklander
Update the pymark.buildconfigspec to depend on 'cmd_mmc' in addition to 'cmd_avb' for those tests that needs more a more complete MMC implementation or the "mmc" command. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2018-10-06test/py: test_fs: add docstring comments to helper functionsAkashi Takahiro
After Siomon's comment, add a descriptive comment (docstring) to each of helper functions in conftest.py. No functionality changed. Signed-off-by: Akashi Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-06test/py: test_fs: remove fs_type argument from umount_fs()Akashi Takahiro
Since there is no use of fs_type in umount_fs(), just remove it. Signed-off-by: Akashi Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-06test/py: ignore console read exceptions after test failureStephen Warren
After a test has failed, test/py drains the U-Boot console log to ensure that any relevant output is captured. At this point, we don't care about detecting any additional errors, since the test is already known to have failed, and U-Boot will be restarted. To ensure that the test cleanup code is not interrupted, and can correctly terminate the log sections for the failed test, ignore any exception that occurs while reading the U-Boot console output during this limited period of time. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2018-09-23efi_selftest: test key notification functionsHeinrich Schuchardt
Use a key notification function to leave the EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL test. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23test/py: test EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOLHeinrich Schuchardt
Add a unit test for the EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23test/py: rework test_efi_selftest_text_input()Heinrich Schuchardt
Use more precise regular expressions. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23test/py: Unicode w/ EFI_SIMPLE_TEXT_INPUT_PROTOCOLHeinrich Schuchardt
Test that the Euro sign is correctly retrieved from the console via the EFI_SIMPLE_TEXT_INPUT_PROTOCOL. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23test/py: fs: add fstest/unlink testAkashi, Takahiro
In this commit, test cases for unlink interfaces are added as part of "test_fs" test suite. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23test/py: fs: add fstest/mkdir testAKASHI Takahiro
In this commit, test cases for mkdir interfaces are added as part of "test_fs" test suite. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23test/py: fs: add extended write operation testAKASHI Takahiro
In this commit and the following, test scripts for new filesystem functionalities introduced by my patch set, "fs: fat: extend FAT write operations," are provided. In particular, this patch adds test cases for sub-directory write and write with non-zero offset. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23test/py: convert fs-test.sh to pytestAKASHI Takahiro
In this commit, the same set of test cases as in test/fs/fs-test.sh is provided using pytest framework. Actually, fs-test.sh provides three variants:"sb" (sb command), "nonfs" (fatxx and etc.) and "fs" (hostfs), and this patch currently supports only "nonfs" variant; So it is not a replacement of fs-test.sh for now. Simple usage: $ py.test test/py/tests/test_fs [<other options>] You may also specify filesystem types to be tested: $ py.test test/py/tests/test_fs --fs-type fat32 [<other options>] Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23test/py: typo occuredHeinrich Schuchardt
%s/occured/occurred/ Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23test/py: test EFI_SIMPLE_TEXT_INPUT_PROTOCOLHeinrich Schuchardt
Execute the EFI selftest for the EFI_SIMPLE_TEXT_INPUT_PROTOCOL. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
