path: root/test/print_ut.c
2019-06-07lib/vsprintf: allow printing upper case GUIDsHeinrich Schuchardt
In the UEFI context GUIDs are expected to be rendered in upper case. The patch uses the formerly unused bit 1 of the parameter str_format of function uuid_bin_to_str() to indicate if we need upper or lower case output. Function uuid_string() in vsprint.c is adjusted to correctly set the bit depending on the print format code. %pUb: 01020304-0506-0708-090a-0b0c0d0e0f10 %pUB: 01020304-0506-0708-090A-0B0C0D0E0F10 %pUl: 04030201-0605-0807-090a-0b0c0d0e0f10 %pUL: 04030201-0605-0807-090A-0B0C0D0E0F10 Up to this point only a diagnostic message in mount_ubifs() using '%pUB' is concerned by the change. Further patches are needed to adjust the UEFI subsystem. A unit test is provided inside the ut_print command. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-05lib/display_options: avoid illegal memory accessHeinrich Schuchardt
display_options_get_banner_priv() overwrites bytes before the start of the buffer if the buffer size is less then 3. This case occurs in the Sandbox when executing the `ut_print` command. Correctly handle small buffer sizes. Adjust the print unit test to catch when bytes before the buffer are overwritten. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-23test: print_ut.c use #if CONFIG_IS_ENABLED(EFI_LOADER)Heinrich Schuchardt
Using CONFIG_IS_ENABLED(EFI_LOADER) allows to simply the #if statements. Suggested-by: Alexander Graf <agraf@suse.de> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28vsprintf.c: correct printing of a NULL device pathHeinrich Schuchardt
When printing '%pD' with a value of NULL we want to output '<NULL>'. But this requires copying to buf. Leave this to string16. A unit test is supplied which relies on EFI support in the sandbox. The development for EFI support in the sandbox is currently in branch u-boot-dm/efi-working. The branch lacks commit 6ea8b580f06b ("efi_loader: correct DeviceNodeToText for media types"). Ater rebasing the aforementioned branch on U-Boot v2018.01 and adding 256060e4257a2 and this patch the test is executed successfully. Fixes: 256060e4257a2 (vsprintf.c: add EFI device path printing) Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-22vsprintf.c: add EFI device path printingHeinrich Schuchardt
For debugging efi_loader we need the capability to print EFI device paths. With this patch we can write: debug("device path: %pD", dp); A possible output would be device path: /MemoryMapped(0x0,0x3ff93a82,0x3ff93a82) This enhancement is not available when building without EFI support and neither in the SPL nor in the API example. A test is provided. It can be executed in the sandbox with command ut_print. The development for EFI support in the sandbox is currently in branch u-boot-dm/efi-working. The branch currently lacks commit 6ea8b580f06b ("efi_loader: correct DeviceNodeToText for media types"). Ater rebasing the aforementioned branch on U-Boot v2018.01 the test is executed successfully. Without EFI support in the sandbox the test is simply skipped. Suggested-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-10-08test: print_ut: Add test for %ls stringsRob Clark
Add a simple test for long strings. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-11test: Add a test for snprintf() and the banner/versionSimon Glass
Add a simple test to make sure that these functions obey the buffer size passed into them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
