path: root/test/overlay/cmd_ut_overlay.c
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop image.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-07cmd_ut: add a parameter prefix to the function cmd_ut_categoryPhilippe Reynes
There is black magic in the file conftest.py that list all the test unit. Then, all those test unit are called in pytest. This call is done with the end of the name (for example checksum if the full name is bloblist_test_checksum). The result is that only test for dm are really executed. by pytest, all others tests are listed but never executed. This behaviour happens because the dm test unit only check the end of the name and others tests checks the full name. To fix this issue, I've added a prefix to the function cmd_ut_category, and this prefix is removed when looking for the unit test. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-12-12test: overlay: NULL passed as fdtHeinrich Schuchardt
The uts created in do_ut_overlay() is not the one used in cmd_ut_category(). Currently all tests are therefore called with uts->priv = NULL and fail. Using a static variable is the easiest fix here. Fixes: e93232e15ec9 ("test: overlay: Use cmd_ut_category()") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-10-22test: overlay: add missing includeHeinrich Schuchardt
Compiling the overlay unit test fails with odroid-c2_defconfig showing errors like: test/overlay/cmd_ut_overlay.c:29:8: error: unknown type name ‘fdt32_t’ Add the missing include. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-12-02test: overlay: Use cmd_ut_category()Simon Glass
Adjust the code to use the common test-execution function. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-10-06test/overlay: Fix various malloc/free leaksTom Rini
With the overlay tests now being built in sandbox Coverity has found a number of issues in the tests. In short, if malloc ever failed we would leak the previous mallocs, so we need to do the usual goto pattern to free each in turn. Finally, we always looked at the free()d location to see how many tests had failed for the return code. Reported-by: Coverity (CID: 167224, 167227, 167230, 167236) Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-15test: overlay: Add unit test for stacked overlayPantelis Antoniou
Verify that stacked overlays work. Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-09-15ut: fix fdt_getprop_u32() changePantelis Antoniou
fdt_getprop_u32 is not exported and it's different than what the unit test uses. Rename u32 prop access methods to something that's unit test specific. Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-20tests: Introduce DT overlay testsMaxime Ripard
This adds a bunch of unit tests for the "fdt apply" command. They've all been run successfully in the sandbox. However, as you still require an out-of-tree dtc with overlay support, this is disabled by default. Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
