path: root/test/fs
2015-11-18test: fat: add error-checking to non-contig testStephen Warren
Check the result code of all command that are executed. Without this, if the fallocate invocation fails (this feature is not supported on ext3 filesystems for example) then a zero-length output file will be created, and subsequent the mkfs and mount invocations will fail, which will cause the subsequent dd invocation to attempt to fill up the host's entire free disk space. That's not a nice user experience! Related, if fallocate does fail, try to create the test disk image using dd instead. That should work everywhere. Fixes: 4a28274227d0 ("test: fat: add test of non-contiguous file reads") Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-10-24fs-test.sh: fix pre-requisite detectionStephen Warren
In the following snippet: if [ ! -x `which $prereq` ]; then When $prereq does not exist, `which $prereq` evaluates to the empty string, which results in *no* argument being passed to the -x operator, which then evaluates to true, which is the equivalent of the prereq having been found. In order for this to fail as expected, we must pass an empty argument, which then causes -x to fail. Do this by wrapping the `` in quotes so there's always an argument to -x, even if the value of the argument is zero-length. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-10-24test: fat: add test of non-contiguous file readsStephen Warren
In my patch series to replace fs/fat with "ff.c", I enhanced ff.c to optimize file reading, so that reads of contiguous clusters are submitted to the IO device as a single read. This test attempts to torture-test edge-cases of that enhancement. BTW, the only way I found to validate that this script actually does create non-contiguous files was to manually inspect the FAT bitmap in a hex dump of the FAT image. hdparm --fibmap doesn't work on loop-mounted filesystems. filefrag -v -e seems to lie about files being contiguous when they aren't. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-10-11test/fs/fs-test.sh: Update expected results and TC10 logicTom Rini
With the changes in 7a3e70c we now get read(2) behavior so trying to read 2MB with 1MB left in the file results in 1MB read and a warning. We update the test logic here to make sure we read back 1MB as expected. This change however changes the overall summary as while EXT4 continues to not have offset support the test now fails when expected to pass rather than fails when expected to fail (and we report that as pass). Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-18fs-test.sh: minor fixesStephen Warren
- Re-direct stderr into the log files, so any errors U-Boot emits are visible in the logs. This is relevant if the "reset" shell command attempts to report that it's not supported on the sandbox board. - Fix test_fs_nonfs() to name the files it created differently for each invocation. Otherwise, the logs from different tests overwrite each-other. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Suriyan Ramasami <suriyan.r@gmail.com>
2014-11-23sandbox: script for testing sandbox/ext4/fat/fs commandsSuriyan Ramasami
Test size/read/write commands in a sandbox environment. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
