path: root/test/env
2017-12-02test: Add a command function for test executionSimon Glass
The logic to either iterate through a list of tests or pick a named test is common to at lest two test suits. Move this logic into a new function and call it from the environment tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-21test: env: Add a test of the new regex behavior for attrsJoe Hershberger
The behavior of the env attrs depends on CONFIG_REGEX. Add an additional test if that variable is set. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-21test: env: Add test for verifying env attrsJoe Hershberger
Add a test of the env_attr_lookup() function. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-21test: env: Add test framework for envJoe Hershberger
Add a new "env" subcommand to the ut command. This will run unit tests on the env code. This should be targetable to any device that supports the env features needed for the tests. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
