path: root/test/dm/syscon-reset.c
2020-08-07dm: Rename DM test flags to make them more genericSimon Glass
The test flags used by driver model are currently not available to other tests. Rather than creating two sets of flags, make these flags generic by changing the DM_ prefix to UT_ and moving them to the test.h header. This will allow adding other test flags without confusion. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-07-01reset: Add generic reset driverSean Anderson
This patch adds a generic reset driver. It is designed to be useful when one has a register in a regmap which contains bits that reset other devices. I thought this seemed like a very generic use, so here is a generic driver. The overall structure has been modeled on the syscon-reboot driver. Signed-off-by: Sean Anderson <seanga2@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
