path: root/test/dm/serial.c
2022-04-14test: serial: Add test for putc/putsSean Anderson
This adds a test to ensure that puts is equivalent to putc called in a loop. We don't verify the contents of the message to avoid having to record console output a second time (though that could be added in the future). The globals are initialized to non-zero values to avoid a warning; in particular, the character count is off-by-one (but we always make relative measurements). Signed-off-by: Sean Anderson <sean.anderson@seco.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-08-07dm: Rename DM test flags to make them more genericSimon Glass
The test flags used by driver model are currently not available to other tests. Rather than creating two sets of flags, make these flags generic by changing the DM_ prefix to UT_ and moving them to the test.h header. This will allow adding other test flags without confusion. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-08-03dm: core: Drop header files from dm/test.hSimon Glass
These header file should not be included in other header files. Remove them and add to each individual file. Add test/test.h to test/ui.h since that is a reasonable place. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-16dm: serial: Add clock member to struct serial_device_infoAndy Shevchenko
Some callers of serial_getinfo() would like to know the UART base clock speed in order to make decision what to pass to OS in some cases. In particular, ACPI SPCR table expects only certain base clock speed and thus we have to act accordingly. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-01-14dm: serial: Adjust serial_getinfo() to use proper APISimon Glass
All driver-model functions should have a device as the first parameter. Update this function accordingly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
2019-01-14dm: serial: Adjust serial_setconfig() to use proper APISimon Glass
2019-01-14dm: serial: Adjust serial_getconfig() to use proper APISimon Glass
2018-12-05dm: serial: Introduce ->getinfo() callbackAndy Shevchenko
New callback will give a necessary information to fill up ACPI SPCR table, for example. Maybe used later for other purposes. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Change ADR_SPACE_SYSTEM_IO to SERIAL_ADDRESS_SPACE_IO to fix build error: Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-05dm: serial: Add ->getconfig() callbackAndy Shevchenko
In some cases it would be good to know the settings, such as parity, of current serial console. One example might be an ACPI SPCR table to generate using these parameters. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-10sandbox: Add serial testPatrice Chotard
Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
