We use 'priv' for private data but often use 'platdata' for platform data.
We can't really use 'pdata' since that is ambiguous (it could mean private
or platform data).
Rename some of the latter variables to end with 'plat' for consistency.
The test flags used by driver model are currently not available to other
tests. Rather than creating two sets of flags, make these flags generic
by changing the DM_ prefix to UT_ and moving them to the test.h header.
This will allow adding other test flags without confusion.
These header file should not be included in other header files. Remove
them and add to each individual file. Add test/test.h to test/ui.h since
that is a reasonable place.
Move this header out of the common header.
support parse regulator standard property:
regulator-off-in-suspend;
regulator-init-microvolt;
regulator-suspend-microvolt:
regulator_get_suspend_enable
regulator_set_suspend_enable
regulator_get_suspend_value
regulator_set_suspend_value
Signed-off-by: Joseph Chen <chenjh@rock-chips.com>
Signed-off-by: Elaine Zhang <zhangqing@rock-chips.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
regulator_set_enable() api throws an error in the following three cases:
- when requested to disable an always-on regulator
- when set_enable() ops not provided by regulator driver
- when enabling is actually failed.(Error returned by the regulator driver)
Sometimes consumer drivers doesn't want to track the first two scenarios
and just need to worry about the case where enabling is actually failed.
But it is also a good practice to have an error value returned in the
first two cases.
So introduce an api regulator_set_enable_if_allowed() which ignores the
first two error cases and returns an error as given by regulator driver.
Consumer drivers can use this api need not worry about the first two
error conditions.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
This patch extends pmic_bind_children prefix matching. In addition to
the node name the property regulator-name is used while trying to match
prefixes. This allows assigning different drivers to regulator nodes
named regulator@1 and regulator@10 for example.
I have discarded the idea of using other properties then regulator-name
as I do not see any benefit in using property compatible or even
regulator-compatible. Of course I am open to change this if there are
good reasons to do so.
Signed-off-by: Felix Brack <fb@ltec.ch>
The regulator_autoset() function mixes printf() output and PMIC adjustment
code. It provides a boolean to control the output. It is better to avoid
missing logic and output, and this permits a smaller SPL code size. So
split the output into a separate function.
Also rename the function to have a by_name() suffix, since we would like
to be able to pass a device when we know it, and thus avoid the name
search.
Tested-by: Przemyslaw Marczak <p.marczak@samsung.com>
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
Separate the ability to define tests and assert status of test functions
from the dm tests so they can be used more consistently throughout all
tests.
This change adds new file to sandbox driver model test environment.
The file is: test/dm/power.c, and it includes tests for PMIC framework,
which includes PMIC uclass and REGULATOR uclass.
All tests are based od Sandbox PMIC emulated device. Some test constants for
this device are defined in the header: include/power/sandbox_pmic.h
PMIC tests includes:
- pmic get - tests, that pmic_get() returns the requested device
- pmic I/O - tests I/O by writing and reading some values to PMIC's registers
and then compares, that the write/read values are equal.
The regulator tests includes:
- Regulator get by devname/platname
- Voltage set/get
- Current set/get
- Enable set/get
- Mode set/get
- Autoset
- List autoset
For the regulator 'get' test, the returned device pointers are compared,
and their names are also compared to the requested one.
Every other test, first sets the given attribute and next try to get it.
The test pass, when the set/get values are equal.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Tested on sandbox:
