path: root/test/dm/ofnode.c
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-02test: dm: add test item for ofnode_get_child_count()Chunfeng Yun
Add a test item for ofnode_get_child_count() Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com> Signed-off-by: Frank Wunderlich <frank-w@public-files.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Weijie Gao <weijie.gao@mediatek.com>
2020-02-05dm: core: Add ofnode_get_chosen_prop()Simon Glass
Add a function to read a property from the chosen node, providing access to its length. Update ofnode_get_chosen_string() to make use of it. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Add ofnode_read_prop()Simon Glass
Add a new function to read a property that supports reading the length as well. Reimplement ofnode_read_string() using it and fix its comment. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Rename ofnode_get_chosen_prop()Simon Glass
This function is actually intended to read a string rather than a property. All of its current callers use it that way. Also there is no way to return the length of the property from this function. Rename it to better indicate its purpose, using ofnode_read as the prefix since this matches most other functions. Also add some tests which are missing for these functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09dm: core: Update ofnode to read binman-style flash entrySimon Glass
At present ofnode_read_fmap_entry() reads a flash map entry in a format which is not supported by binman. To allow use to use binman-format descriptions, update this function. Also add a simple test. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-18test: ofnode: test ofnode_by_prop_value()Jens Wiklander
Test ofnode_by_prop_value() Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-07test: ofnode: test ofnode_device_is_compatible()Masahiro Yamada
Test ofnode_device_is_compatible(), and also ofnode_path(). Requested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
