The GPIO tests require the sandbox GPIO driver, so cannot be run on other
platforms. Similarly for the 'dm test' command.
This command is not required for driver model operation, but can be useful
for testing. It provides simple dumps of internal data structures.
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com>
Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
Add some tests of driver model functionality. Coverage includes:
- basic init
- binding of drivers to devices using platform_data
- automatic probing of devices when referenced
- availability of platform data to devices
- lifecycle from bind to probe to remove to unbind
- renumbering within a uclass when devices are probed/removed
- calling driver-defined operations
- deactivation of drivers when removed
- memory leak across creation and destruction of drivers/uclasses
- uclass init/destroy methods
- automatic probe/remove of children/parents when needed
This function is enabled for sandbox, using CONFIG_DM_TEST.
