path: root/test/dfu/README
2014-08-09test:dfu: README file updateLukasz Majewski
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2014-08-09test: dfu: script enhancementsStephen Warren
Various misc enhancements to dfu_gadget_test.sh: * After every write (download), perform a write to a different file with different data. This ensures that the DFU buffer's content is replaced, so that if the read (upload) succeeds, we know that the correct data was actually read from the storage device, rather than simply being left over in the DFU buffer. This requires two alt setting names to be passed to the script, and a dummy data file to be generated by dfu_gadget_test_init.sh. * Fix the assumption that dfu_gadget_test.sh is run from the directory that contains it, by cd'ing to that directory before invoking ./dfu_gadget_test_init.sh. * Use $DIR$RCV_DIR consistently, rather than using plain $RCV_DIR in some places. * Add 959, 961 test file sizes, to be consistent with having one more than and one less than all the other "round" sizes 64, 128, and 4096. * Remove references to $BKP_DIR from dfu_gadget_test_init.sh, since it isn't used. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-08-09test:dfu: Add test scripts for testing DFU regressionLukasz Majewski
This commit adds test scripts for testing if any commit has introduced regression to the DFU subsystem. It uses md5 to test if sent and received file is correct. The test detailed description is available at README file. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
