path: root/test/cmd_ut.c
2017-12-04test: compression: Convert to unit test frameworkSimon Glass
Adjust this test to use the unit test framework. Drop the two existing commands for running the tests and replace them with a single 'ut compression' command, with sub-commands. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Continue to have ret = run_test_internal(...) in run_test so ret is always initialized] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-02test: Add a command function for test executionSimon Glass
The logic to either iterate through a list of tests or pick a named test is common to at lest two test suits. Move this logic into a new function and call it from the environment tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-20tests: Introduce DT overlay testsMaxime Ripard
This adds a bunch of unit tests for the "fdt apply" command. They've all been run successfully in the sandbox. However, as you still require an out-of-tree dtc with overlay support, this is disabled by default. Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-05-21test: env: Add test framework for envJoe Hershberger
Add a new "env" subcommand to the ut command. This will run unit tests on the env code. This should be targetable to any device that supports the env features needed for the tests. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-21test: dm: Move the time test over to the ut commandJoe Hershberger
Unify the command for running unit tests further by moving the "ut_time" command over to "ut time". Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-21test: dm: Move the dm tests over to the ut commandJoe Hershberger
Unify the command for running unit tests further by moving the "dm test" command over to "ut dm". Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-21test: Add a common unit test commandJoe Hershberger
Add a command that all other unit tests should be a sub-command of. Also include a command that will run all tests. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
