Signed-off-by: Brandon Maier <brandon.maier@collins.com>
We move the existing CONFIG_POST_* functionality over to CFG_POST and
then introduce CONFIG_POST to Kconfig.
The macros in this file are a little confusing and we currently have no
tests to check that they work as expected.
Add some tests which check the macros in C code. Add a few tests which
check that the build errors are generated correctly too, using buildman's
-a option.
Tighten up symbol dependencies in a number of places. Ensure that a SPL
specific option has at least a direct dependency on SPL. In places
where it's clear that we depend on something more specific, use that
dependency instead. This means in a very small number of places we can
drop redundant dependencies.
Reported-by: Pali Rohár <pali@kernel.org>
lib/charset.c is not optional for
EFI_APP || EFI_LOADER || UFS || UT_UNICODE.
These must select CONFIG_CHARSET.
Fixes: 726cd9836db0 ("efi: Make unicode printf available to the app")
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Add the basic functionality required to support the standard crypt
format.
The files crypt-sha256.c and crypt-sha512.c originate from libxcrypt and
their formatting is therefor retained.
The integration is done via a crypt_compare() function in crypt.c.
libxcrypt $ git describe --long --always --all
tags/v4.4.17-0-g6b110bc
Signed-off-by: Steffen Jaeckel <jaeckel-floss@eyet-services.de>
Building U-Boot with unit tests on a non-sandbox systems fails:
ld.bfd: test/built-in.o: in function `compress_using_gzip':
test/compression.c:138: undefined reference to `gzip'
ld.bfd: test/built-in.o: in function `uncompress_using_bzip2':
test/compression.c:187: undefined reference to `BZ2_bzBuffToBuffDecompress'
ld.bfd: test/built-in.o: in function `uncompress_using_lzma':
test/compression.c:222: undefined reference to `lzmaBuffToBuffDecompress'
ld.bfd: test/built-in.o: in function `uncompress_using_lzo':
test/compression.c:257: undefined reference to `lzop_decompress'
ld.bfd: test/built-in.o: in function `uncompress_using_lz4':
test/compression.c:292: undefined reference to `ulz4fn
Add the missing dependencies.
We want to run unit tests in SPL. Add a new Kconfig to control this and
enable it for sandbox_spl
If CONFIG_LOG=n, we still expect output for log_err(), log_warning(),
log_notice(), log_info() and in case of DEBUG=1 also for log_debug().
Provide unit tests verifying this.
The tests depend on:
CONFIG_CONSOLE_RECORD=y
CONFIG_LOG=n
CONFIG_UT_LOG=y
It may be necessary to increase the value of CONFIG_SYS_MALLOC_F_LEN to
accommodate CONFIG_CONSOLE_RECORD=y.
In this patch, a very simple test is added to verify that rsa_verify()
using rsa_verify_with_pkey() work correctly.
To keep the code simple, all the test data, either public key and
verified binary data, are embedded in the source.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
This test will exercise asn1 compiler as well as asn1 decoder functions
via various parsers.
OP-TEE can get supplied with a devicetree and will then insert
its firmware node and reserved-memory sections into it.
As this devicetree often is not the one supplied to a later
loaded kernel, a previous commit added functionality to transfer
these nodes onto that new devicetree.
To make sure this functionality stays intact, also add a test
for the transfer functionality.
Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com>
Memory functions may have architecture specific implementations. These
should be tested.
Provide unit tests for memset(), memcpy(), memmove().
Provide a 'ut lib' sub-command to execute the tests.
Provide unit tests for Unicode functions.
This adds a bunch of unit tests for the "fdt apply" command.
They've all been run successfully in the sandbox. However, as you still
require an out-of-tree dtc with overlay support, this is disabled by
default.
Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Add a new "env" subcommand to the ut command.
This will run unit tests on the env code. This should be targetable to
any device that supports the env features needed for the tests.
Make all unit tests selectable as a menu of test suites instead of just
sitting in the top-level menu individually.
Unify the command for running unit tests further by moving the "ut_time"
command over to "ut time".
Separate the ability to define tests and assert status of test functions
from the dm tests so they can be used more consistently throughout all
tests.
Sometimes the time functions are incorrect due to bad time support on a
board. Add a unit test which tries to detect this.
Add a file to control driver model test features.
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
