path: root/test/Kconfig
2016-08-20tests: Introduce DT overlay testsMaxime Ripard
This adds a bunch of unit tests for the "fdt apply" command. They've all been run successfully in the sandbox. However, as you still require an out-of-tree dtc with overlay support, this is disabled by default. Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-05-21test: env: Add test framework for envJoe Hershberger
Add a new "env" subcommand to the ut command. This will run unit tests on the env code. This should be targetable to any device that supports the env features needed for the tests. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-21test: Move the unit tests to their own menuJoe Hershberger
Make all unit tests selectable as a menu of test suites instead of just sitting in the top-level menu individually. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-21test: dm: Move the time test over to the ut commandJoe Hershberger
Unify the command for running unit tests further by moving the "ut_time" command over to "ut time". Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-21test: Generalize the unit test frameworkJoe Hershberger
Separate the ability to define tests and assert status of test functions from the dm tests so they can be used more consistently throughout all tests. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-06test: Add a simple time testSimon Glass
Sometimes the time functions are incorrect due to bad time support on a board. Add a unit test which tries to detect this. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: test: Add a Kconfig fileSimon Glass
Add a file to control driver model test features. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
