Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL
framework, enable on all of the previously using boards. We move the
spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave
the NAND one in-place as we plan to replace it later in this series.
We use common/spl to avoid linker problems with respect to merging
constant strings in objects. Otherwise all strings in common/ will be
linked in and kept which grows SPL in size too much.
Remove linker command line options from the SPL makefile
that force the inclusion of unreferenced command code from
linked object files. As commands are not used in the SPL,
these options resulted in an unnecessary increase in the
image size, in addition to introducing the possibility of
tricky link errors in the case where the command code
contained symbols that were not resolved by linking in the
limited objects compiled in the SPL build.
Signed-off-by: Tyler Olmstead <tyler.j.olmstead@gmail.com>
Acked-by: Tom Rini <trini@ti.com>
This fixes the SPL build to link with the SPL version of libgcc if
USE_PRIVATE_LIBGCC is set to "yes". Previously it was linking with
the libgcc from the normal u-boot build because it gets set in
PLATFORM_LIBS and passed down the to the SPL build.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Tested-by: Thierry Reding <thierry.reding@avionic-design.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
In preparation for splitting out the armv4t code from tegra20, move
the tegra20 SoC code to arch/arm/cpu/tegra20-common. This code will
be compiled armv4t for the arm7tdmi and armv7 for the cortex A9.
Commit 8b5a02640adf77301f943e8754992c50df004e8a ("Makefile: cosmetic:
optimize usage of LIBS-y") broke the build of boards that have a board
vendor "common" directory, by introducing a space between "LIBS-" and
"y".
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Most link scripts differ only in the directory containing the start.o
file. Make this a #define to remove this last difference.
(Note that if start.o were disallowed outside the CPU start directory then
we wouldn't even need this. But that is a separate discussion.)
The Makefile for a CPU is in arch/($ARCH)/cpu/$(CPU). We want to support
having an .lds file in arch/$(ARCH)/cpu without requiring an additional
Makefile there. This change makes it clear that we expect a Makefile in
the same directory as the link script except in this case.
This patch is added to support SPL feature on AM335X
platform. In this patch, MMC1 is configured as boot
device for SPL and support for other devices will be
added in the next patch series.
Signed-off-by: Chandan Nath <chandan.nath@ti.com>
This patch adds the minimal support for OMAP5. The platform and machine
specific headers and sources updated for OMAP5430.
OMAP5430 is Texas Instrument's SOC based on ARM Cortex-A15 SMP architecture.
It's a dual core SOC with GIC used for interrupt handling and SCU for cache
coherency.
Also moved some part of code from the basic platform support that can be made
common for OMAP4/5. Rest is kept out seperately. The same approach is followed
for clocks and emif support in the subsequent patches.
Signed-off-by: sricharan <r.sricharan@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
This introduces small OneNAND loader, fitting into 1kB of space (smallest
possible OneNAND RAM size). Some devices equipped with such crappy chips will
use this.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Scott Wood <scottwood@freescale.com>
V2: Introduce spl_onenand_load_image() to load data from OneNAND in SPL
V3: Cleanup, align with nand_spl. Skip whole blocks.
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Sergei Shtylyov <sshtylyov@mvista.com>
On some hosts using relative paths will cause the build to fail. This
patch sets absolute paths for the tools directory
Get rid of MSDOS style excecutable extension
Signed-off-by: Angus Ainslie <angus.ainslie@linaro.org>
Adding a DMA library to the SPL. It is used if CONFIG_SPL_DMA_SUPPORT is
defined.
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
Introduce CONFIG_SPL_START_S_PATH to configure path to start.S file. It's not
always fitting to use CPU's start.S .
Adds power library to the new spl
Adds NAND library to SPL.
Acked-by: Scott Wood <scottwood@freescale.com>
Adds mmc boot support.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
- Add mkimage support for OMAP boot image
- Add support for OMAP boot image(MLO) generation in the new
SPL framework
Signed-off-by: John Rigby <john.rigby@linaro.org>
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
