path: root/spl
2014-05-12kbuild: allow null board for spl buildMasahiro Yamada
Commit 33a02da0 supported "<none>" for the board field of boards.cfg. But it missed to modify spl/Makefile. This commit provides the flexibility so we can use "<none>" board in SPL too.
2014-04-17mtd: Add a CONFIG_SPL_MTD_SUPPORT for a more full NAND subsystem in SPLTom Rini
This mainly converts the am335x_spl_bch driver to the "normal" format which means a slight change to nand_info within the driver. Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-04-11kbuild: fix a bug in regeneration of linker scriptsMasahiro Yamada
In some use cases, SPL linker script was not updated even when it should be. For instance, $ make tricoder_config all [ build complete ] ... modify include/configs/tricoder.h $ make spl/u-boot-spl.lds should be updated in this case, but it wasn't. To fix this problem, linker scripts generation should be handled by $(call if_changed_dep,...) rather than by $(call if_changed,...). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Andreas Bießmann <andreas.devel@googlemail.com> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-28kbuild: Rename UIMAGE to MKIMAGEMarek Vasut
U-Boot uses the 'mkimage' tool to produce various image types, not only uImage image type. Rename the invocation name from UIMAGE to MKIMAGE. The following command was used to do the replacement: git grep 'quiet_cmd_mkimage.* = UIMAGE' | cut -d : -f 1 | \ xargs -i sed -i "s@\(quiet_cmd_mkimage\)\(.*\) = UIMAGE @\1\2 = MKIMAGE@" {} Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: rename OBJTREE to objtreeMasahiro Yamada
Prior to Kbuild, $(OBJTREE) was used for pointing to the top of build directory with absolute path. In Kbuild style, $(objtree) is used instead. This commit renames OBJTREE to objtree and delete the defition of OBJTREE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: rename SRCTREE to srctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used for instead. This commit renames SRCTREE to srctree and deletes the defition of SRCTREE. Note that SRCTREE in scripts/kernel-doc, scripts/docproc.c, doc/DocBook/Makefile should be keep. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: rename TOPDIR to stctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used instead. This commit renames TOPDIR to srctree and delete the defition of TOPDIR. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-07kbuild: improve Kbuild speedMasahiro Yamada
Kbuild brought about many advantages for us but a significant performance regression was reported by Simon Glass. After some discussions and analysis, it turned out its main cause is in $(call cc-option,...). Historically, U-Boot parses all config.mk (arch/*/config.mk and board/*/config.mk) every time descending into subdirectories. That means cc-options are evaluated over and over again. $(call cc-option,...) is useful but costly. So we want to evaluate them only in ./Makefile and spl/Makefile and export compiler flags. This commit changes the build system as follows: - Modify scripts/Makefile.build to not include config.mk Instead, add $(PLATFORM_CPPFLAGS) to asflags-y, ccflags-y, cppflags-y. - Export many variables Going forward, Kbuild will not parse config.mk files when it descends into subdirectories. If we want to set variables in config.mk and use them in subdirectories, they must be exported. This is the list of variables to get exported: PLATFORM_CPPFLAGS CPUDIR BOARDDIR OBJCOPYFLAGS LDFLAGS LDFLAGS_FINAL (used in nand_spl/board/*/*/Makefile) CONFIG_STANDALONE_LOAD_ADDR (used in examples/standalone/Makefile) SYM_PREFIX (used in examples/standalone/Makefile) RELFLAGS (used in examples/standalone/Makefile) - Delete CPPFLAGS This variable has been replaced with PLATFORM_CPPFLAGS - Copy gcclibdir from example/standalone/Makefile to arch/sparc/config.mk The reference in CONFIG_STANDALONE_LOAD_ADDR must be resolved before it is exported. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> [on Sandbox] Tested-by: Stephen Warren <swarren@nvidia.com> [on Tegra]
2014-03-07kbuild: add CONFIG_ prefix to USE_PRIVATE_LIBGCCMasahiro Yamada
Before this commit, USE_PRIVATE_LIBGCC was defined in arch-specific config.mk and referenced in arch/$(ARCH)/lib/Makefile. We are not happy about parsing config.mk again and again. We have to keep the same behavior with a different way. By adding "CONFIG_" prefix, this macro appears in include/autoconf.mk, include/spl-autoconf.mk. (And treating USE_PRIVATE_LIBGCC as CONFIG macro is reasonable enough.) Tegra SoC family defined USE_PRIVATE_LIBGCC as "yes" in arch/arm/cpu/arm720t/tegra*/config.mk, whereas did not define it in arch/arm/cpu/armv7/tegra*/config.mk. It means Tegra enables PRIVATE_LIBGCC only for SPL. We can describe the same behavior by adding #ifdef CONFIG_SPL_BUILD # define CONFIG_USE_PRIVATE_LIBGCC #endif to include/configs/tegra-common.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-03-04kbuild: consolidate PLATFORM_LIBSMasahiro Yamada
We had switched to Kbuild so now we can specify PLATFORM_LIBS/PLATFORM_LIBGCC with relative path. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-02-25kbuild: refactor more IMX image rulesMasahiro Yamada
This commit avoids generating ./SPL twice. - Fist time descending to spl/ - Second time as a prerequisite of u-boot-with-spl.imx, u-boot-with-nand-spl.imx. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-25kbuild: use shorten logs for IMX imagesMasahiro Yamada
2014-02-25kbuild: use shorten logs for misc targetsMasahiro Yamada
2014-02-25kbuild: use shorten logs for mkimage rulesMasahiro Yamada
2014-02-25kbuild: use shorten logs objcopy rulesMasahiro Yamada
2014-02-25kbuild: Add $(Q) when descending into subdirectoriesMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-25kbuild: rename OBJCFLAGS to OBJCOPYFLAGSMasahiro Yamada
Rename OBJCFLAGS to OBJCOPYFLAGS beforehand to use "cmd_objcopy" in scripts/Makefile.lib in an upcoming commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-24kbuild: fix SPL link bug when USE_PRIVATE_LIBGCC is "yes"Masahiro Yamada
Commit 6825a95 (kbuild: use Linux Kernel build scripts) changed the behavior of linkage when USE_PRIAVATE_LIBGCC is defined as "yes". (It dropped arch/arm/lib/eabi_compat.o from the target library.) Affected boards are all Tegra boards. This commit gets back the same behavior as before Kbuild series. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Tom Rini <trini@ti.com>
2014-02-19kbuild: refactor Makefile and spl/Makefile moreMasahiro Yamada
This commit refactors rules of directory descending and defines u-boot-dirs and u-boot-all-dirs. (We will need u-boot-all-dirs when using scripts/Makefile.clean) Additionally, rename LIBS-y to libs-y. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: generate {spl, tpl}-autoconf.mk only when it is necessaryMasahiro Yamada
Before this commit, {spl,tpl}-autoconf.mk was always generated at the top Makefile even if SPL(TPL) build was not selected. This commit moves the build rule of {spl,tpl}-autoconf.mk from the top Makefile to spl/Makefile. It prevents unnecessary {spl,tpl}-autoconf.mk from being generated. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: move include directives of board configuration filesMasahiro Yamada
This commit changes the location of include directives of board configuration files. The purpose of this change is: - Slim down $(TOPDIR)/config.mk - Prevent $(TOPDIR)/Makefile from including the same configuration file twice - Do not include include/config.mk multiple times because ARCH, CPU, BOARD, VENDOR, SOC are exported Before this commit: - include/autoconf.mk was included from $(TOPDIR)/Makefile and $(TOPDIR)/config.mk (This means $(TOPDIR)/Makefile included include/autoconf.mk twice) - include/{spl,tpl}-autoconf.mk was included from $(TOPDIR)/config.mk - include/config.mk was included from $(TOPDIR)/Makefile and $(TOPDIR)/config.mk (This means $(TOPDIR)/Makefile included include/config.mk twice) After this commit: - include/autoconf.mk is included from $(TOPDIR)/Makefile and $(TOPDIR)/scripts/Makefile.build - include/{spl,tpl}-autoconf.mk is included from $(TOPDIR)/spl/Makefile and $(TOPDIR)/scripts/Makefile.build - include/config.mk is included from $(TOPDIR)/config.mk and $(TOPDIR)/spl/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19Makefile: move some flags to spl/MakefileMasahiro Yamada
Some flags are used for SPL (and TPL) build only. This commit moves them from config.mk to spl/Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: Use Kbuild.includeMasahiro Yamada
This commit adjusts some files to use Kbuild.include. - Use cc-option defined in Kbuild.include (Delete cc-option in config.mk) - Use cc-version defined in (Delete cc-version in config.mk) - Move binutils-version and dtc-version to Kbuild.include by analogy to cc-version This commit also adds srctree (same as SRCTREE) to use Kbuild scripts. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19board: samsung: refactor host programsMasahiro Yamada
Some Samsung boards have their own tools under board/samsung/<board>/tools/. This commit refactor more makefiles with "hostprogs-y". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19tools: convert makefiles to kbuild styleMasahiro Yamada
Before this commit, makefiles under tools/ directory were implemented with their own way. This commit refactors them by using "hostprogs-y" variable. Several C sources have been added to wrap other C sources to simplify Makefile. For example, tools/crc32.c includes lib/crc32.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19common: spl: Add spl sata boot supportDan Murphy
Add spl_sata to read a fat partition from a bootable SATA drive. Signed-off-by: Dan Murphy <dmurphy@ti.com> Reviewed-by: Roger Quadros <rogerq@ti.com>
2014-01-24spl: common: Support for USB MSD FAT image loadingDan Murphy
Add SPL support to be able to detect a USB Mass Storage device connected to a USB host. Once a USB Mass storage device is detected the SPL will load the u-boot.img from a FAT partition to target address. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2014-01-21powerpc:mpc85xx: Add ifc nand boot support for TPL/SPLPo Liu
Using the TPL method for nand boot by sram was already supported. Here add some code for mpc85xx ifc nand boot. - For ifc, elbc, esdhc, espi, all need the SPL without section .resetvec. - Use a clear function name for nand spl boot. - Add CONFIG_SPL_DRIVERS_MISC_SUPPORT to compile the fsl_ifc.c in spl/Makefile; Signed-off-by: Po Liu <Po.Liu@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-14arm: put .hash, .got.plt and .machine_param back in binariesAlbert ARIBAUD
Some targets will build fine but not boot if sections .hash and .got.plt are not present in the binary. Add them back. Also, Exynos machines require .machine_param section in SPL. Add it. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com>
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2013-12-30SPL: EXYNOS: Prepare for variable size SPL supportRajeshwari Birje
When variable size SPL is used, the BL1 expects the SPL to be encapsulated differently: instead of putting the checksum at a fixed offset in the SPL blob, prepend the blob with a header including the size and the checksum. The enhancements include - adding a command line option, '--vs' to indicate the need for the variable size encapsulation - padding the fixed size encapsulated blob with 0xff instead of random memory contents - do not silently truncate the input file, report error instead - no need to explicitly closing files/freeing memory, this all happens on exit; removing cleanups it makes code clearer - profuse commenting - modify Makefile to allow enabling the new feature per board Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-16Makefile: Select objects by CONFIG_ rather than $(ARCH) or $(CPU)Masahiro Yamada
Convert like follows: CPU mpc83xx -> CONFIG_MPC83xx CPU mpc85xx -> CONFIG_MPC85xx CPU mpc86xx -> CONFIG_MPC86xx CPU mpc5xxx -> CONFIG_MPC5xxx CPU mpc8xx -> CONFIG_8xx CPU mpc8260 -> CONFIG_8260 CPU ppc4xx -> CONFIG_4xx CPU x86 -> CONFIG_X86 ARCH x86 -> CONFIG_X86 ARCH powerpc -> CONFIG_PPC Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13drivers/mtd: descend into sub directories only when it is necessaryMasahiro Yamada
2013-12-13.gitignore: ignore spl/ and tpl/ directories except spl/MakefileMasahiro Yamada
Before this commit, output files under tpl/ directry were not ignored. This commit fixes this problem. And we have only one source file under spl/ directory: spl/Makefile So, we can describe .gitignore more simply. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13spl/Makefile: merge LIBS-y += arch/$(ARCH)/imx-commonMasahiro Yamada
2013-12-13Makefile: use two double-quotations as a pairMasahiro Yamada
Some editors such as Emacs can highlight source files. But their parser algorithm is not perfect. If you use one double-quotation alone, some editor cannot handle it nicely and mark source lines as a string by mistake. It is preferable to use two double-quotations as a pair. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-17Makefile: move fs/fat/ entry to drivers/MakefileMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-11-17Makefile: refactor a littleMasahiro Yamada
2013-11-17Makefile: rename all libraries to built-in.oMasahiro Yamada
2013-11-17powerpc: move mpc8xxx entry under arch/powerpc/cpu/Masahiro Yamada
2013-11-01Makefile: convert makefiles to Kbuild style and delete grep switchMasahiro Yamada
We have converted all makefiles needed to build $(LIBS). Until this commit we used to grep switch so that U-Boot style and Kbuild style makefiles coexist. But we do not need any more. Goint forward, use always Kbuild style Makefile when adding a new Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-31ARM: s5pc, exynos: move Samsung ARM SoC specific code under arch/arm/Masahiro Yamada
This patch moves S5PC, EXYNOS specific directory entries from the toplevel Makefile to arch/arm/cpu/armv7/Makefile using Kbuild descending feature. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2013-10-31ARM: omap: move OMAP specific code under arch/arm/Masahiro Yamada
This patch moves OMAP specific directory entries from the toplevel Makefile and spl/Makefile to arch/arm/cpu/armv7/Makefile using Kbuild descending feature. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2013-10-31ARM: tegra: move Tegra specific code under arch/arm/Masahiro Yamada
This patch moves Tegra specific directory entries from the toplevel Makefile and spl/Makefile to arch/arm/cpu/*/Makefile using Kbuild descending feature. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Warren <TWarren@nvidia.com>
2013-10-31ARM: imx-common: convert makefiles to Kbuild styleMasahiro Yamada
Multiple targets are included in arch/arm/imx-common/Makefile In order to refactor it, we need to tweak Makefile and spl/Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-31Makefile: prepare for using Kbuild-style MakefileMasahiro Yamada
Every makefile in sub directories has common lines at the top and the bottom. This commit pushes the common parts into script/Makefile.build. Going forward sub-makefiles only need to describe this part: COBJS := ... COBJS += ... SOBJS := ... But using obj-y is preferable to prepare for switching to Kbuild. The conventional (non-Kbuild) Makefile style is still supported. This is achieved by greping the Makefile before entering into it. U-Boot conventional sub makefiles always include some other makefiles. So the build system searches a line beginning with "include" keyword in the makefile in order to distinguish which style it is. If the Makefile include a "include" line, we assume it is a conventional U-Boot style. Otherwise, it is treated as a Kbuild-style makefile. With this tweak, we can switch sub-makefiles from U-Boot style to Kbuild style little by little. obj-y := foo/ syntax (descending into the sub directory) is not supportd yet. It will be implemented in the upcomming commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com>
2013-09-20spl/Makefile: Add drivers/power/pmic/libpmic to CONFIG_SPL_POWER_SUPPORTTom Rini
We may need to access the PMIC code in SPL, when we have power set. Signed-off-by: Tom Rini <trini@ti.com>
