path: root/sh_config.mk
2009-07-21Move architecture specific config.mk files into subdirsPeter Tyser
This cleans up U-Boot's toplevel directory a bit and makes the architecture 'config.mk' file naming and location similar to board and cpu 'config.mk' files Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-19push CROSS_COMPILE out to $(ARCH)_config.mkMike Frysinger
Each arch should handle setting a proper default CROSS_COMPILE value in their own config.mk file rather than having to maintain a large ugly list in the Makefile. By using conditional assignment, we don't have to worry about the variable already being set (env/cmdline/etc...). The common config.mk file takes care of exporting CROSS_COMPILE already, and while a few variables (toolchain ones) utilize CROSS_COMPILE before including the arch config.mk, they do so with deferred assignment. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-08sh: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all sh boards use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk tested on r2dplus Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh: make the linker scripts more genericJean-Christophe PLAGNIOL-VILLARD
currently we need to sync the linker script enty and TEXT_BASE manualy and the reloc_dst is based on it instead provide it now from the ldflags tested on r2dplus Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2007-09-23sh: Update core code of SuperH.Nobuhiro Iwamatsu
