Fix various misspellings of:
* deprecated
* partition
* preceding,preceded
* preparation
* its versus it's
* export
* existing
* scenario
* redundant
* remaining
* value
* architecture
Reviewed-by: Jagan Teki <jteki@openedev.com>
Traditionally the DFU support is available only
as part 2nd stage boot loader(u-boot) and DFU
is not supported in SPL.
The SPL-DFU feature is useful for boards which
does not have MMC/SD, ethernet boot mechanism
to boot the board and only has USB inteface.
This patch add DFU support in SPL with RAM
memory device support to load and execute u-boot.
And then leverage full functionality DFU in
u-boot to flash boot inital binary images to
factory or bare-metal boards to memory devices
like SPI, eMMC, MMC/SD card using USB interface.
This SPL-DFU support can be enabled through
Menuconfig->Boot Images->Enable SPL-DFU support
Signed-off-by: Ravi Babu <ravibabu@ti.com>
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
Prior to the previous patch, a freshly created .u-boot.cfg.cmd may not
correctly represent all dependencies for u-boot.cfg. The previous change
only solved this issue for fresh builds; when performing an incremental
build, the deficient .u-boot.cfg.cmd is already present, so u-boot.cfg
is not rebuilt, and hence .u-boot.cfg.cmd is not rebuilt with the correct
content.
Solve this by explicitly detecting when the dependency file .u-boot.cfg.d
has not been integrated into .u-boot.cfg.cmd, and force u-boot.cfg to be
rebuilt in this case by deleting it first. This is possible since
if_changed_dep will always delete .u-boot.cfg.d when it executes
successfully, so its presence means either that the previous build was
made by a source tree that contained a Makefile that didn't include the
previous patch, or that the build failed part way through executing
if_changed_dep for u-boot.cfg. Forcing a rebuild of u-boot.cfg is required
in the former case, and will cause no additional work in the latter case,
since the file would be rebuilt anyway for the same reason it was being
rebuilt by the previous build.
cmd_cpp_cfg generates a dependency output, but because it's invoked using
if_changed rather than if_changed_dep, that dependency file is ignored.
This results in Kbuild not knowing about which files u-boot.cfg depends
on, so it may not be rebuilt when required.
A practical result of this is that u-boot.cfg may continue to reference
CONFIG_ options that no longer exist in the source tree, and this can
cause the adhoc config options check to fail.
This change modifies Makefile to use if_changed_dep, which in turn causes
all dependencies to be known to the next make invocation.
There are a few boards that use CONFIG_ISO_STRING as part of a sanity
check during firmware update at run time. Move this string to Kconfig.
Convert CONFIG_MIP405T from SYS_EXTRA_OPTIONS to a real config
There are two boards, MIP405 and MIP405T that have a few differences.
Start by checking for CONFIG_TARGET_MIP405. Then introduce
CONFIG_TARGET_MIP405T and use that not CONFIG_MIP405T. Next, convert
also convert the usage of CONFIG_ISO_STRING to be based on Kconfig.
New CONFIG options should be added via Kconfig. To help prevent new ad-hoc
CONFIGs from being added, give a build error when these are detected.
Add a list of ad-hoc CONFIG options that don't use Kconfig. This can be used
to check that new ones are not being added.
At present TPL uses the same options as SPL support. In a few cases the board
config enables or disables the SPL options depending on whether
CONFIG_TPL_BUILD is defined.
With the move to Kconfig, options are determined for the whole build and
(without a hack like an #undef in a header file) cannot be controlled in this
way.
Create new TPL options for these and update users. This will allow Kconfig
conversion to proceed for these boards.
Having dashes as a separator in the DTB name is a quite common practice.
However, the current code to generate objects from DTBs assumes the
separator is an underscore, leading to a compilation error when building a
device tree with dashes.
Replace all the dashes in the DTB name to generate the symbols name, which
should solve this issue.
Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Many Ethernet drivers still use the legacy miiphy API to register their
mdio interface for access to the mdio commands.
This semantic patch will convert the drivers from the legacy adapter API
to the more modern alloc/register API.
When of-platdata is used in SPL we don't use the device tree. So there is no
point in attaching it. Adjust the Makefile to skip attaching the device tree
when of-platdata is enabled.
Add a Python version of the libfdt library which contains enough features to
support the dtoc tool. This is only a very bare-bones implementation. It
requires the 'swig' to build.
Update the Makefile to call dtoc to create the C header and source files,
then build these into the image.
Overriding the final link rule is possible with U-Boot proper. It us used to
create a sandbox image links with host libraries. To build a sandbox SPL
image we need the same feature for SPL.
To support this, update the SPL link rule so sandbox can override it.
Fix boot.bin generation for Zynq and ZynqMP.
ASL files may include various U-Boot header files, but IASL compiler
does not understand any C language embedded in these header files.
To reuse those header files for ASL compiling, use __ASSEMBLY__ in
the header files to exclude everything that is not liked by IASL.
Add support for the zynqmpimage to mkimage.
Only basic functionality is supported without encryption and register
initialization with one partition which is filled by U-Boot SPL.
For more detail information look at Xilinx ZynqMP TRM.
Coverity has recently added a check that will find when we don't check
the return code from fstat(2). Copy/paste the checking logic that
print_deps() has with an appropriate re-wording of the perror() message.
[ Linux commit : 46fe94ad18aa7ce6b3dad8c035fb538942020f2b ]
Signed-off-by: Michal Marek <mmarek@suse.com>
IASL compiler does not provide a command line option to turn off
its non-warning message. To quieten the output when 'make -s',
redirect its output to /dev/null.
Remove -va option when invoking IASL compiler so that we can see
errors/warnings/remarks in the build log.
Tested-by: Stefan Roese <sr@denx.de>
It will be much easier if we split the whole dsdt.asl file into
multiple smaller ASL parts and have access to U-Boot include files.
Currently the make rule for dsdt.c uses a wildcard, as below:
$(obj)/%.c: $(src)/%.asl
To avoid any side effect, explicitly mention dsdt.c as this is
the file we intend to use for ACPI DSDT AML generation.
Currently when compiling U-Boot with ASL file, the build log says:
ASL board/intel/bayleybay/dsdt.c
This looks odd as ASL compiler's input is ASL file, not C file.
Change the make rule to use $< instead.
dtb is already included in binary that's why there is no need to replace
u-boot-spl.bin with u-boot-spl-dtb.bin. This is only needed for
OF_SEPARATE is enabled. Only copy -nodtb.bin version which is straight
output from objcopy -O binary.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
It is useful to automate the process of converting code from coreboot a
little. Add a sed script which performs some common transformations.
Acked-by: Bin Meng <bmeng.cn@gmail.com>
The build command of u-boot-spl.dtb is not constant, but dependent
on CONFIG_OF_SPL_REMOVE_PROPS. Use $(call if_changed,...) so that
the change of CONFIG_OF_SPL_REMOVE_PROPS is detected.
Also, add tools/fdtgrep to the dependency to make sure u-boot-spl.dtb
is generated by the up-to-date fdtgrep in case the tool is modified.
FORCE is needed for $(call if_changed,...) to be evaluated every time.
Otherwise, the command is not executed when the command line has
changed but any prerequisite has not been updated.
These rules are only used for SOCFPGA, SUNXI, but no need to hide
them from other SoCs.
Correct spelling of "U-Boot" shall be used in all written text
(documentation, comments in source files etc.).
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
We don't need the -dtb suffix anymore, so drop it.
At present u-boot-spl.bin holds the plain SPL binary without the device
tree. This is somewhat annoying since you need either u-boot-spl.bin or
u-boot-spl-dtb.bin depending on whether device tree is used.
Adjust the build such that u-boot-spl.bin includes a device tree
(if enabled), and the plain binary is in u-boot-spl-nodtb.bin. For now
u-boot-spl-dtb.bin remains the same.
Add rules to allow TrueType files to be compiled into U-Boot for use on
the video console.
Adapted from:
>From 5631d9c429857194bd55d7bcd8fa5bdd1a9899a3 Mon Sep 17 00:00:00 2001
Date: Wed, 19 Aug 2015 17:36:41 +0200
Subject: [PATCH 1/1] kbuild: Fix clang detection
We cannot detect clang before including the arch Makefile, because that
can set the default cross compiler. We also cannot detect clang after
including the arch Makefile, because powerpc wants to know about clang.
Solve this by using an deferred variable. This costs us a few shell
invocations, but this is only a constant number.
Reported-by: Behan Webster <behanw@converseincode.com>
Reported-by: Anton Blanchard <anton@samba.org>
in the Linux kernel.
This will allow us to make better decisions about when to run tests
later on for gcc features.
There are a lot of unrelated files in common, including all of the commands.
Moving them into their own directory makes them easier to find and is more
logical.
Some commands include non-command code, such as cmd_scsi.c. This should be
sorted out at some point so that the function can be enabled with or without
the associated command.
Unfortunately, with m68k I get this error:
m68k: + M5329AFEE
+arch/m68k/cpu/mcf532x/start.o: In function `_start':
+arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o
I hope someone can shed some light on what this means. I hope it isn't
depending on the position of code in the image.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
In a number of places we had wordings of the GPL (or LGPL in a few
cases) license text that were split in such a way that it wasn't caught
previously. Convert all of these to the correct SPDX-License-Identifier
tag.
A general best practice for SPDX is that Makefiles should have an
identifier, add these as everything else is currently covered.
With format-security errors turned on, GCC picks up the use of sprintf with
a format parameter not being a string literal.
Simple uses of sprintf are also converted to use strcpy.
Signed-off-by: Ben Whitten <ben.whitten@gmail.com>
Acked-by: Wolfgang Denk <wd@denx.de>
from linux commit ce8155f7a3d5:
Perl 5.22 emits a deprecated message when "\C" is used in a regex. Perl
5.24 will disallow it altogether.
Fix it by using [A-Z] instead of \C.
>From linux adapted to U-Boot by:
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
using checkpatch with Perl 5.22.0 generates a warning,
this is fixed in linux through commit:
commit 4e5d56bdf892e18832a6540b63ebf709966bce2a
Author: Eddie Kovsky <ewk@edkovsky.org>
Date: Wed Sep 9 15:37:52 2015 -0700
checkpatch: fix left brace warning
Using checkpatch.pl with Perl 5.22.0 generates the following warning:
Unescaped left brace in regex is deprecated, passed through in regex;
This patch fixes the warnings by escaping occurrences of the left brace
inside the regular expression.
Adapt it for U-Boot.
Add a build target to generate 'boot.bin' which includes SPL. This is
used by the platforms BootROM to load SPL directly.
This change also conditionally changes what the 'boot.bin' target
generates depending on the SoC. Leaving the behaviour unchanged for the
AT91 targets.
Signed-off-by: Nathan Rossi <nathan@nathanrossi.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
CONFIG_OF_EMBED=y is the option which is here only for testing purpose
and shouldn't be enabled by default as is describe at:
"dts: Add a comment about CONFIG_OF_EMBED being for local use"
(sha1: 3d3f60cb7a6bb6c338e00a9769fa918a8536096c)
But still enabling this option locally shouldn't end up with compilation
error when you build SPL. This patch fix it.
Compilation error:
lib/built-in.o: In function `fdtdec_setup':
/mnt/disk/u-boot/lib/fdtdec.c:1246: undefined reference to
`__dtb_dt_begin'
Reported-by: Tom Rini <trini@konsulko.com>
Looks like one spot got missed. Probably due to the backslash.
Signed-off-by: Andy Fleming <afleming@gmail.com>
After consulting with some of the SPDX team, the conclusion is that
Makefiles are worth adding SPDX-License-Identifier tags too, and most of
ours have one. This adds tags to ones that lack them and converts a few
that had full (or in one case, very partial) license blobs into the
equivalent tag.
Cc: Kate Stewart <kstewart@linuxfoundation.org>
At present this file is generated even when device tree is not enabled in
SPL. Avoid this, since this file serves no purpose in that case.
This function will be used by both SPL and U-Boot proper. So move it into
a common place. Also change the #ifdef so that the early malloc() area is
not set up in SPL if CONFIG_SYS_SPL_MALLOC_START is defined. In that case
it would never actually be used, and just chews up stack space.
The clear_config() is called just once at the beginning of this
program, but the global variable hashtab[] is already zero-filled
at the start-up.
[ Linux commit: d179e22762fd38414c4108acedd5feca4cf7e0d8 ]
