This is not used in U-Boot.
CONFIG_CMD_DISPLAY
CONFIG_CMD_DIAG
[trini: imply CMD_DIAG on some keymile configs]
This option is not used in U-Boot. Drop it.
CONFIG_CMD_DEKBLOB
Note: This option does not seem to actually be enabled by any board.
[trini: imply under SECURE_BOOT for mx5/6/7]
This option does not exist in U-Boot. Drop it.
CONFIG_CMD_CRAMFS
[trini: imply CMD_CRAMFS for keymile]
CONFIG_CMD_CLK
[trini: imply CMD_CLK on ARCH_ZYNQ]
CONFIG_CMD_CHIP_CONFIG
CONFIG_CMD_CBFS
[trini: imply CMD_CBFS on SYS_COREBOOT]
CONFIG_SYS_WHITE_ON_BLACK
[trini: Make this default y on various SoCs]
CONFIG_CMD_BSP
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
CONFIG_CMD_BMODE
[trini: Make this default y and depend on mx5/6/7]
CONFIG_CMD_BLOB
[trini: Add imply CMD_BLOB under CHAIN_OF_TRUST]
CONFIG_CMD_BEDBUG
CONFIG_CMD_BAT
This looks like a typo. Fix it.
CONFIG_CMD_AES
CONFIG_AES
[trini: Add select AES to CMD_AES]
This is only used by one board and should not be a CONFIG option. Instead
it should use the driver model pmic framework. For now, just move the
setting into the only board that uses it.
CONFIG_PMIC_AS3722
Before converting this to Kconfig, rename it to match the other PMICs.
These were reminders that somehow slipped through the cracks
or were erroneously introduced after previous clean-ups.
Getting rid of then once again. Hopefully for good now :)
Where missing and appropriate replace with CONFIG_CMDLINE_EDITING
which really enables shell history as of now.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Peter Griffin <peter.griffin@linaro.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Jon Mason <jon.mason@broadcom.com>
Cc: Stefan Roese <sr@denx.de>
Use CONFIG_ARCH_LS1021A instead.
Signed-off-by: York Sun <york.sun@nxp.com>
Use CONFIG_ARCH_LS1043A instead.
Use CONFIG_ARCH_LS2080A instead.
Rename CONFIG_FSL_DCU_FB to CONFIG_VIDEO_FSL_DCU_FB
and convert it to Kconfig.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Reviewed-by: Stefan Agner <stefan.agner@toradex.com>
Reviewed-by: Alison Wang <alison.wang@nxp.com>
Drop CONFIG_STACKSIZE from include/configs/imx6_logic.h
Since Binutils 1a9ccd70f9a7[1] u-boot will not link targets that set
CONFIG_SYS_TEXT_BASE=0 with the following error:
LD u-boot
arm-linux-gnueabi-ld.bfd: u-boot: Not enough room for program headers, try
linking with -N
arm-linux-gnueabi-ld.bfd: final link failed: Bad value
The issue can be reproduced with the bad binutils and the rock2_defconfig
target.
This issue was also encountered by the powerpc kernel[2], with the fix
being to pass --no-dynamic-linker for linkers newer than 2.26 when this
flag was introduced. The option tells ld that the PIE or shared lib does
not need loaded program headers.
Ubuntu Zesty's Binutils 2.27.51.20161202 hits this error.
[1] https://sourceware.org/git/gitweb.cgi?p=binutils-gdb.git;a=commit;h=1a9ccd70f9a7
[2] https://git.kernel.org/cgit/linux/kernel/git/powerpc/linux.git/commit/?h=next&id=ff45000fcb56b5b0f1a14a865d3541746d838a0a
Signed-off-by: Joel Stanley <joel@jms.id.au>
[AF: Apply to LDFLAGS_$(SPL_BIN) as well, suggested by Tom Rini]
Signed-off-by: Andreas Färber <afaerber@suse.de>
There is option which is not used:
CONFIG_ZBOOT_32
Remove it from default x86 config and from whitelist.
Introduce a new sunxi-spl-with-ecc.bin image with already the right header,
ECC, randomizer and padding for the BROM to be able to read it.
It needs to be flashed using a raw access to the NAND so that the
controller doesn't change a thing to it, since we already have all the
right parameters.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
With d53ecad92f06 some unused interrupt related code was removed.
However all of these options are currently unused. Rather than migrate
some of these options to Kconfig we just remove the code in question.
The only related code changes here are that in some cases we use
CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename
and move the value local to the code in question.
Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi")
trini: Disable CONFIG_SPL_USE_ARCH_MEMSET on orangepi_2
At present we have SPL_ which can be used in Makefiles to select between
normal and SPL CONFIGs like this:
obj-$(CONFIG_$(SPL_)DM) += core/
When TPL is being built, SPL_ has the value 'SPL' which is generally a
good idea since they tend to follow each other. But in extreme situations
we may want to distinugish between SPL and TPL. For example we may not
want to enable CONFIG_DM with TPL.
Add a new SPL_TPL_ variable which is set to either empty (for U-Boot
proper), 'SPL' or 'TPL'. This may prove useful with TPL-specific options.
This is not used by any board. Drop it.
Clean up board_f sequence a little
This series tries to remove #ifdefs from the board_f init sequence. It
gets as far as I2C and then we need to discuss whether we can start to
remove the old I2C framework.
I think that ideally each entry in the init sequence should be enabled by
at most one CONFIG, which is in Kconfig and is not arch-specific.
END
Acked-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
The architecture is currently unmaintained, remove.
Cc: Benjamin Matthews <mben12@gmail.com>
Cc: Chong Huang <chuang@ucrobotics.com>
Cc: Dimitar Penev <dpn@switchfin.org>
Cc: Haitao Zhang <hzhang@ucrobotics.com>
Cc: I-SYST Micromodule <support@i-syst.com>
Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de>
Cc: Martin Strubel <strubel@section5.ch>
Cc: Peter Meerwald <devel@bct-electronic.com>
Cc: Sonic Zhang <sonic.adi@gmail.com>
Cc: Valentin Yakovenkov <yakovenkov@niistt.ru>
Cc: Wojtek Skulski <info@skutek.com>
Cc: Wojtek Skulski <skulski@pas.rochester.edu>
The board is now manufactured by Aries Embedded GmbH , rename it.
Many ARMv8 boards define a constant COUNTER_FREQUENCY to specify the
frequency of the ARM Generic Timer (aka. arch timer).
ARMv7 boards traditionally used CONFIG_TIMER_CLK_FREQ for the same
purpose. It seems useful to unify them.
Since there are less occurences of the latter version, lets convert all
users over to COUNTER_FREQUENCY.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
This includes support for rk3188 from Heiko Stübner and and rk3328 from
Kever Yang. Also included is SPL support for rk3399 and a fix for
rk3288 to get it booting again (spl_early_init()).
Boards with an apparent need for the md5sum command had the connected
config symbol defined in their board header file.
Move this over to the respective defconfig files now that md5sum is
configured via Kconfig.
(This is a manual effort, which differs from moveconfig.py, not sure
who is right here. Boards except sandbox loose the md5sum command with
moveconfig.py, though it was explicitly mentioned in their config.h's)
[trini: migrate stih410-b2260]
Right now the u-boot,dm-pre-reloc flag will make each marked node
always appear in both spl and tpl. But systems needing an additional
tpl might have special constraints for each, like the spl needing to
be very tiny.
So introduce two additional flags to mark nodes for only spl or tpl
environments and introduce a function dm_fdt_pre_reloc to automate
the necessary checks in code instances checking for pre-relocation
flags.
The behaviour of the original flag stays untouched and still marks
a node for both spl and tpl.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Kever Yang <kever.yang@rock-chips.com>
Xilinx changes for v2017.05
- Move to DM clk driver
- Add clk support for zynq_sdhci
Use Kconfig option instead of config macro in header file.
Clean up existing usage.
