We will need ti-gpmc driver for SPL. Allow memory drivers
do be built for SPL.
Signed-off-by: Roger Quadros <rogerq@kernel.org>
CONFIG_SYS_DFU_MAX_FILE_SIZE to Kconfig
Currently the config options CONFIG_SYS_DFU_DATA_BUF_SIZE and
CONFIG_SYS_DFU_MAX_FILE_SIZE are being set in include/configs/<board>.h
files and also in <board_name>_defconfig files without a Kconfig option. It
is easier for users to set these configs in defconfig files than in config
header files as they are a part of the source code.
Add Kconfig symbols, and update the defconfigs by using tools/moveconfig.py
script.
Suggested-by: Pratyush Yadav <p.yadav@ti.com>
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
This option is obsolete since 2009 and can be removed globally.
CC: Stefan Roese <sr@denx.de>
Signed-off-by: Holger Brunck <holger.brunck@hitachi-powergrids.com>
CONFIG_SYS_FDT_SIZE is not use anywhere that's why remove it.
This is a combination of upstream libfdt commits to fix warnings about
comparing signed and unsigned integers:
scripts/dtc/libfdt/fdt.c: In function ‘fdt_offset_ptr’:
scripts/dtc/libfdt/fdt.c:137:18: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if ((absoffset < offset)
For a detailed description of the fixes, see the dtc repo:
https://git.kernel.org/pub/scm/utils/dtc/dtc.git/log/?id=73e0f143b73d808
For this patch the commits between 73e0f143b73d8088 and ca19c3db2bf62000
have been combined and adjusted for the slight differences in U-Boot's
libfdt code base.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
CONFIG_NEEDS_MANUAL_RELOC macro was out of Kconfig. Move it there to be
able to use compile-time checks to reduce the number of build paths.
Fixes: f9a882438966 ("dm: core: Convert #ifdef to if() in root.c") for Microblaze
Add a rule to generate u-boot-spl.sym so that pytest can discover the
available unit tests.
We want to run unit tests in SPL. Add a new Kconfig to control this and
enable it for sandbox_spl
Remove CONFIG_VIDEO dependency to fix board removal warnings.
Cc: Jens Scharsig <esw@bus-elektronik.de>
add Kconfig option for pcf8563 driver and
run tools/moveconfig.py
Done with:
./tools/moveconfig.py BMP_16BPP BMP_24BPP BMP_32BPP
Done with:
./tools/moveconfig.py VIDEO_BMP_RLE8
Done with:
./tools/moveconfig.py VIDEO_BMP_GZIP
The 3 suspicious migration because CMD_BMP and SPLASH_SCREEN
are not activated in these defconfigs:
- trats_defconfig
- s5pc210_universal_defconfig
- trats2_defconfig
There're no users left.
Signed-off-by: Andre Heider <a.heider@gmail.com>
CONFIG_IS_ENABLED() takes the kconfig name without the CONFIG_ prefix,
e.g. CONFIG_IS_ENABLED(CLK) for CONFIG_CLK. Make including the prefix
an error in checkpatch.pl so calls in the wrong format aren't
accidentally reintroduced.
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
At present the Python sequential-write interface can produce an error when
it calls fdt_finish(), since this needs to add a terminating tag to the
end of the struct section.
Fix this by automatically expanding the buffer if needed.
The linux changes since v3.16 are
78283edf2c01 kbuild: setlocalversion: print error to STDERR
b24413180f56 License cleanup: add SPDX GPL-2.0 license identifier to files with no license
6147b1cf1965 scripts/setlocalversion: git: Make -dirty check more robust
8ef14c2c41d9 Revert "scripts/setlocalversion: git: Make -dirty check more robust"
ff64dd485730 scripts/setlocalversion: Improve -dirty check with git-status --no-optional-locks
7a82e3fa28f1 scripts/setlocalversion: clear local variable to make it work for sh
991b78fbd223 scripts: setlocalversion: fix a bashism
3c96bdd0ebfa scripts: setlocalversion: replace backquote to dollar parenthesis
and it's ff64dd485730 that is the motivation for this sync. It fixes
false positive "-dirty" added to the version string when building with
Yocto
(https://lists.openembedded.org/g/openembedded-core/message/137702).
There has been one U-Boot specific patch since this was synced with
linux 3.16: 81630a3b38c2 (scripts: setlocalversion: safely extract
variables from auto.conf using awk). Keep these changes applied.
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
[trini: Re-add 81630a3b38c2 and reword message]
Entirely disabling relocation of the device tree or initrd is almost
never the right answer. Doing this by default leads to hard to diagnose
run-time failures.
CONFIG_SYS_DEVICE_NULLDEV
CONFIG_SPLASH_SCREEN
CONFIG_SPLASH_SCREEN_ALIGN
CONFIG_SPLASHIMAGE_GUARD
CONFIG_SPLASH_SOURCE
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
Remove ad-hoc CONFIG_SYS_SRAM_START and use CONFIG_SYS_SRAM_BASE instead.
Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
This converts ad-hoc CONFIG_SYS_SRAM_SIZE to Kconfig.
This converts ad-hoc CONFIG_SYS_SRAM_BASE to Kconfig.
The commit 47818e23a228 ("Makefile.lib: include /__symbols__ in dtb if
SPL_LOAD_FIT_APPLY_OVERLAY is enabled") enables DT building as overlays
based on symbols which depends on SPL. But there is already an option to
apply overlays in full U-Boot too.
And there are platforms which are not using SPL and there is no option to
build DTs with -@ parameter.
That's why change dependency on OF_LIBFDT_OVERLAY which is already symbol
which is selected when SPL_LOAD_FIT_APPLY_OVERLAY is enabled but also
adding support for platforms which don't enable SPL and want to work with
overlays on U-Boot prompt.
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Remove a double space introduced by my previous fixdep fix.
Fixes: 76ae74d348a0 ("fixdep: fix CONFIG_IS_ENABLED etc. handling")
These headers should not be included in other header files. Add a
checkpatch rule and test for this.
When binman is in use, most of the targets built by the Makefile are
inputs to binman. We then need a final rule to run binman to produce the
final outputs.
Rename the variable to indicate this, and add a new 'inputs' target.
Done with:
./tools/moveconfig.py -S SPL_LOAD_FIT_ADDRESS
./tools/moveconfig.py -S SPL_LOAD_FIT_ADDRESS -H
Signed-off-by: Peng Fan <peng.fan@nxp.com>
[trini: A few more migrations]
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
BOOTP_DEFAULT is defined in several boards, but this config
option is never checked or used.
This patch removes this config option from config files and
the whitelist.txt
CONFIG_BOOTP_SEND_HOSTNAME
CONFIG_DRIVER_TI_EMAC_USE_RMII
CONFIG_SPL_NAND_BASE
CONFIG_SPL_NAND_IDENT
CONFIG_SPL_NAND_DRIVERS
CONFIG_SPL_NAND_ECC
CONFIG_SPL_NAND_SIMPLE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
- Bug fixes and updates on ls2088a,ls1028a, ls1046a, ls1043a, ls1012a
- lx2-watchdog support
- layerscape: pci-endpoint support, spin table relocation fixes and
cleanups
- fsl-crypto: RNG support and bug fixes
https://gitlab.denx.de/u-boot/custodians/u-boot-dm
binman support for FIT
new UCLASS_SOC
patman switch 'test' command
minor fdt fixes
patman usability improvements
The eSDHC adapter card identification and multiplexing configuration
through FPGA had been implemented in both common mmc driver and
fsl_esdhc driver. However it is proper to move these code to board
files and do it during board initialization. The FPGA registers are
also board specific.
This patch is to move eSDHC adapter card identification and
multiplexing configuration from mmc driver to specific board files.
And the option CONFIG_FSL_ESDHC_ADAPTER_IDENT is no longer needed.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
[Rebased, Removed T1040QDS change as board does not exist]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Add Kconfig entries for the dc2114x driver and convert various boards.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Ramon Fried <rfried.dev@gmail.com>
If the pylibfdt shared-object file is detected, then Python assumes that
the libfdt.py file exists also.
Sometimes when an incremental build aborts, the shared-object file is
built but the libfdt.py is not. The only way out at this point is to use
'make mkproper', or similar.
Fix this by removing the .so file before it is built. This seems to make
Python rebuild everything.
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing
changes made to 56d37f1c564107e27d873181d838571b7d7860e7.
Unfortunately this is causing CI failures:
https://travis-ci.org/github/trini/u-boot/jobs/711313649
This patch adds very basic support for the Octeon III SoCs. Only
CFI parallel NOR flash and UART is supported for now.
Please note that the basic Octeon port does not include the DDR3/4
initialization yet. This will be added in some follow-up patches
later. To still use U-Boot on with this port, the L2 cache (4MiB on
Octeon III CN73xx) is used as RAM. This way, U-Boot can boot to the
prompt on such boards.
Signed-off-by: Aaron Williams <awilliams@marvell.com>
When fixdep detects CONFIG_IS_ENABLED and other similar macros, it must
parse the macro parameter to determine which actual CONFIG_ option is
being referenced. This involves moving a pointer forward through the
entire CONFIG_ option "word". Currently, the code uses variable q to walk
through the word, but doesn't actually initialize it to point at the
parameter before doing so. Consequently, the walking process immediately
fails since it sees the macro invocatoins's ( rather than the expected
alpha-numeric characters in the macro parameter. Fix this by adding the
missing initialization.
Fixes: 67f2ee86ccbe ("kbuild: fixdep: Resync this with v4.17")
Fixes: 7012865e961c ("gpio: fix test.py for gpio label lookup")
