Convert SANDBOX_BITS_PER_LONG to Kconfig and assign it a correct
number depending on which host we are going to build and run.
MX6Q/QP IPU operates at 264MHz and MX6DL IPU at 198MHz.
When running a SPL target, which supports multiple MX6 variants we cannot
properly setup the IPU clock frequency via CONFIG_IPUV3_CLK option as
such decision is done in build-time currently.
Remove the CONFIG_IPUV3_CLK option and let the IPU clock frequency be
configured in run-time on mx6.
Reported-by: Eric Nelson <eric@nelint.com>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Eric Nelson <eric@nelint.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
[agust: fixed #endif in cgtqmx6eval.h]
The underlying implementation for ENV_AES has security complications and
is not recommended for use. Please see CVE-2017-3225 and CVE-2017-3226
for more details. Mark this as deprecated now and delete this in the
medium term if no one comes forward to re-work the support.
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
This is not a valid option. Drop it.
This is not used in U-Boot.
This is actually not used. Drop it.
This is not referenced anywhere. Drop it.
CONFIG_BCH
CONFIG_SPL_OMAP3_ID_NAND
SUNXI_GMAC was still used to configure the code where as the
same has been renamed and moved to Kconfig in below commit
"sunxi: Move SUNXI_GMAC to Kconfig"
(sha1: 4d43d065db3262f9a9918ba72457bf36dfb8e0bb)
Signed-off-by: Dave Prue <dave@prue.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Reviewed-by: Mark Kettenis <kettenis@openbsd.org>
Tested-by: Mark Kettenis <kettenis@openbsd.org>
[Tweek commit message, config_whitelist.txt, build-whitelist.sh]
Signed-off-by: Jagan Teki <jagan@openedev.com>
If the kernel is configured to be built with debug symbols, or
has bug tables, comparing files may not work if line numbers
change. This makes comparing object files with these options
harder to do. Let's strip out the debug info and drop the
__bug_table here so that we don't see false positives. There may
be other things to drop later, and it may be architecture
specific, but this works for me with my ARM64 build.
[ Import Linux commit: 65ba6fa439e7c3cbf97de9dce9e7a3390ae2638c ]
Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org>
Reviewed-by: Jason Cooper <jason@lakedaemon.net>
This converts CPU_INTEL_TURBO_NOT_PACKAGE_SCOPED to a Kconfig option.
This converts CONFIG_USB_EHCI_PCI to a Kconfig option, and updates
all boards that use it.
CONFIG_SYS_GENERIC_GLOBAL_DATA is no longer used by any board or
platform, so support for it can be dropped.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Reviewed-by: Vladimir Zapolskiy <vz@mleia.com>
On some systems `python` is `python3` (for instance, Archlinux). The
`PYTHON` variable can be used to point to `python2` to have a successful
build.
The use of `PYTHON` is currently limited in the Makefile and needs to be
extended in other places:
First, pylibfdt is required to be a Python 2 binding (binman imports
pylibfdt and is only compatible Python 2), so its setup.py needs to be
called accordingly. An alternative would be to change the libfdt
setup.py shebang to python2, but the binding is actually portable. Also,
it would break on system where there is no such thing as `python2`.
Secondly, the libfdt import checks need to be done against Python 2 as
well since the Python 2 compiled modules (in this case _libdft.so) can
not be imported from Python 3.
Note on the libfdt imports: "@if ! PYTHONPATH=tools $(PYTHON) -c 'import
libfdt'; then..." is probably simpler than the currently sub-optimal
pipe.
Reviewed-by: Jonathan Gray <jsg@jsg.id.au>
Sysam stmark2 board is a generic and fully (hw and sw) open board, with
a mcf54415 Coldfire CPU, 128MB of DDR2, 16MB of SPI flash and SD card
as non volatile memories, and a wifi module included on-board.
The board is actually used mainly for Coldfire custodian testing activity
related to the mcf5441x Coldfire family.
For further information please see: http://sysam.it/cff_stmark2.html
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
Changes in v2:
- remove CMD_REGINFO
- add board information in commit message
About a quarter of the files in common/ relate to the environment. It
seems better to put these into their own subdirectory and remove the
prefix.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
Moving SPL_LDSCRIPT to Kconfig triggered an unfortunate attempt of
command substitution, as the sourced auto.conf may include $(ARCH)
which tries to execute a command 'ARCH'.
This showed up as a warning similar to the following:
include/config/auto.conf: line 209: ARCH: command not found
This change does no longer attempt to source auto.conf, but rather
passes it through awk to retrieve the values for CONFIG_LOCALVERSION
and CONFIG_LOCALVERSION_AUTO. This will also mitigate the risk of
unintended command substitution.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reported-by: Andy Yan <andy.yan@rock-chips.com>
Reviewed-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Reviewed-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com>
We can finally drop TPL_STACK, TPL_TEXT_BASE and TPL_MAX_SIZE off the
whitelist (this time it's really happening!) and migrate the setting
(only used on the RK3368-uQ7 so far) into Kconfig.
Now that we have split up SPL_LDSCRIPT into a SPL and TPL variant and
have started to use the TPL-variant for the RK3368, it's time to clean
up behind ourselves: move both variants into Kconfig and remove them
from the whitelist.
This adds the TPL_DRIVER_MISC_SUPPORT option to allow activation of
DRIVER_MISC_SUPPORT for devices that need it in the TPL stage.
For the bringup of the RK3368, we need to support TPL and SPL running
from different addresses... which requires both stages to use a
distinct TEXT_BASE.
This commit adds support for having a separate LDSCRIPT for TPL (which
is expected to make use of the TPL_MAX_SIZE define) and for having a
the option of defining TPL_TEXT_BASE and having the TPL stage linked
against this address.
Note that the handling of the TEXT_BASE is designed to not interfere
with the previous assumption that SPL_TEXT_BASE should be used for TPL
as well, unless TPL_TEXT_BASE is defined. For this reason, the test
in Makefile.spl uses the following (seemingly redundant checks):
1. looks for $(SPL_TPL_)TEXT_BASE
2. looks for SPL_TEXT_BASE (even when building in TPL)
To allow a TPL and SPL to run from different addresses/memories, we
need to split setup of the TPL and SPL stacks. To do so, we introduce
CONFIG_TPL_STACK (not listed in Kconfig) which can be used to override
the initial stack pointer for TPL.
To provide backward compatibility for existing boards, this is added
as an optional configuration item and the normal search order (i.e.
SPL_STACK, then SYS_STACK) apply if not defined.
For the RK3368, we want to use OF_PLATDATA in TPL, but full OF_CONTROL
in SPL: this requires the introduction of a new family of
configuration options to decouple SPL_OF_CONTROL and SPL_OF_PLATDATA
from TPL.
Consequently, Makefile.spl needs to be adjusted to test for these
configuration items through the $(SPL_TPL_) macro instead of
hard-coding the SPL variant.
CONFIG_NAND
[trini: Sync up a few more, add imply's]
CONFIG_CMD_ZFS
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_CMD_ZBOOT
CONFIG_CMD_UUID
CONFIG_CMD_UNIVERSE
Since no board uses this, perhaps we should drop this command?
CONFIG_CMD_TSI148
CONFIG_CMD_TRACE
CONFIG_CMD_THOR_DOWNLOAD
This is not a valid CONFIG option. Drop it.
CONFIG_CMD_TERMINAL
CONFIG_CMD_TCA642X
This driver is not used in U-Boot. Drop it and its associated CONFIG
options.
CONFIG_CMD_STRINGS
CONFIG_CMD_SPL_WRITE_SIZE
CONFIG_CMD_SPL_NAND_OFS
CONFIG_CMD_SPL
Note that trats does not actually use SPL, so this option can no-longer be
set.
CONFIG_CMD_SH_ZIMAGEBOOT
CONFIG_CMD_SF_TEST
