Convert the CONFIG_UPDATE_TFTP and related symbols to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
config_fallbacks.h had some logic to automatically select
LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't
already selected. By migrating LIB_HW_RAND to Kconfig, we can
remove this check from config_fallbacks.h and put it into Kconfig
Reviewed-by: Lukasz Majewski <lukma@denx.de>
[trini: Turn into a choice, add NET_RANDOM_ETHADDR]
CONFIG_APBH_DMA
CONFIG_APBH_DMA_BURST
CONFIG_APBH_DMA_BURST8
Reviewed-by: Stefan Agner <stefan.agner@toradex.com>
[trini: Add in MMC as well]
The motivation for moving MX28 selection to Kconfig is to be able
to better handle NAND MXS selection through Kconfig.
This selection method also aligns with the way other i.MX SoCs are
selected in U-Boot.
The motivation for moving MX23 selection to Kconfig is to be able
selected in U-Boot.
CONFIG_MXC_GPIO
CONFIG_SYS_OMAP24_I2C_SLAVE
CONFIG_SYS_OMAP24_I2C_SPEED
Reviewed-by: Paul Kocialkowski <contact@paulk.fr>
CONFIG_SYS_DV_CLKMODE
CONFIG_SYS_DA850_PLL0_POSTDIV
CONFIG_SYS_DA850_PLL0_PLLDIV1
CONFIG_SYS_DA850_PLL0_PLLDIV2
CONFIG_SYS_DA850_PLL0_PLLDIV3
CONFIG_SYS_DA850_PLL0_PLLDIV4
CONFIG_SYS_DA850_PLL0_PLLDIV5
CONFIG_SYS_DA850_PLL0_PLLDIV6
CONFIG_SYS_DA850_PLL0_PLLDIV7
CONFIG_SYS_DA850_PLL1_POSTDIV
CONFIG_SYS_DA850_PLL1_PLLDIV1
CONFIG_SYS_DA850_PLL1_PLLDIV2
CONFIG_SYS_DA850_PLL1_PLLDIV3
CONFIG_SYS_BOOT_GET_CMDLINE
CONFIG_SYS_BOOT_GET_KBD
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
Recent GCC versions warn if the format string is not a literal
because the compiler cannot check the argument validity at compile
time.
Commit 192bc6948b02 ("Fix GCC format-security errors and convert
sprintfs.") blindly replaced sprintf() with strcpy(), including
many cases where the format parameter is a string literal.
For the kconfig change:
sprintf(header, " ");
..., here the format parameter is a string literal " ", so it is
definitely equivalent to:
strcpy(header, " ");
Of course, if the 'header' did not have enough length for containing
" ", it would be a security problem, but another problem. (in this
case, the 'header' is 4 byte length buffer, so it is not a problem at
all.)
The kconfig code is kept as synced with Linux as possible, but this
change made the code out-of-sync for nothing. Just reverting.
Setting config options using headers is deprecated. This patch converts
the BCM2835 Mini-UART to Kconfig.
We want to use Kconfig logic to depend on whether pl01x devices
are built in, so let's convert their inclusion selection to Kconfig.
This round goes to pl01x.
This round goes to pl011.
This round goes to pl010.
CONFIG_WALNUT was dropped in June 2017 in:
commit 98f705c9cefdfd ("powerpc: remove 4xx support")
While at it, the related CONFIG_MACH_SPECIFIC and the have_of
and _machine variables are unused as well, so drop them too.
All of these host tools are apparently written for Python2,
not Python3.
Use 'python2' in the shebang line according to PEP 394
(https://www.python.org/dev/peps/pep-0394/).
Convert these configuration options to Kconfig, update board defconfigs
and drop them from whitelist.
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Previous patches removed the last usages of this config variable, so
that it is now obsolete.
This patch removes it from the whitelist.
Reviewed-by: Jagan Teki <jagan@openedev.com>
Signed-off-by: Mario Six <mario.six@gdsys.cc>
0efc024 ("spi_flash: Add spi_flash_probe_fdt() to locate SPI by FDT
node") added a helper function spi_base_setup_slave_fdt to to set up a
SPI slave from a given FDT blob. The only user was the exynos SPI
driver.
But commit 73186c9 ("dm: exynos: Convert SPI to driver model") removed
the use of this function, hence rendering it obsolete.
Remove this function, as well as the CONFIG_OF_SPI option, which guarded
only this function.
CONFIG_SOC_DA8XX
CONFIG_SOC_DA850
CONFIG_DA850_LOWLEVEL
CONFIG_MACH_DAVINCI_DA850_EVM
CONFIG_SYS_DA850_PLL_INIT
CONFIG_SYS_DA850_DDR_INIT
Reviewed-by: David Lechner <david@lechnology.com>
[trini: Rework CONFIG_SYS_DA850_PLL_INIT so it's selected on SOC_DA8XX]
fat.h unconditionally defines CONFIG_SUPPORT_VFAT (and has done since
2003), so as a result VFAT support is always enabled regardless of
whether a board config defines it or not. Drop this unnecessary option.
Migrate the following symbols to Kconfig:
CONFIG_FS_EXT4
CONFIG_EXT4_WRITE
The definitions in config_fallbacks.h can now be expressed in Kconfig.
CONFIG_ROCKCHIP_USB2_PHY
CONFIG_OMAP_USB_PHY
CONFIG_TWL4030_USB
CONFIG_DAVINCI_SPI
CONFIG_USB_MUSB_HCD
CONFIG_USB_MUSB_UDC
CONFIG_USB_DAVINCI
CONFIG_USB_OMAP3
CONFIG_USB_DA8XX
CONFIG_USB_AM35X
CONFIG_USB_MUSB_OMAP2PLUS
CONFIG_USB_MUSB_AM35X
CONFIG_USB_MUSB_DSPS
CONFIG_USB_MUSB_PIO_ONLY
The following config symbols are only defined once and never referenced
anywhere else:
CONFIG_CYRUS
CONFIG_IDS8313
CONFIG_MPC8308_P1M
CONFIG_MPC8308RDB
CONFIG_MPC8349EMDS
CONFIG_MPC8349ITXGP
CONFIG_SBC8349
CONFIG_SBC8548
CONFIG_SBC8641D
CONFIG_TQM834X
CONFIG_VE8313
CONFIG_XPEDITE5140
CONFIG_XPEDITE5200
CONFIG_XPEDITE550X
Most of them are config symbols named after the respective boards which
seems to have been a standard practice at some point.
Acked-by: Mario Six <mario.six@gdsys.cc>
anywhere else:
CONFIG_AMCORE
CONFIG_ASTRO5373L
CONFIG_M52277EVB
CONFIG_M5253DEMO
CONFIG_M5253EVBE
CONFIG_M5275EVB
CONFIG_M54418TWR
CONFIG_STMARK2
Seems to be again one of those CONFIG_ symbols named after a board, with
nothing referencing it.
Last users of the following macros (for n = 0..7) were removed in
commit 5b8e76c35ec312a ("powerpc, 8xx: remove support for 8xx"):
CONFIG_SYS_PCMCIA_PBRn
CONFIG_SYS_PCMCIA_PORn
This adds SH_ETHER to drivers/net/Kconfig and convert to Kconfig.
anywhere else:
CONFIG_AP325RXA
CONFIG_AP_SH4A_4A
CONFIG_CPU_SH_TYPE_R
CONFIG_ECOVEC
CONFIG_ESPT
CONFIG_MIGO_R
CONFIG_MPR2
CONFIG_MS7720SE
CONFIG_MS7722SE
CONFIG_MS7750SE
CONFIG_R0P7734
CONFIG_R2DPLUS
CONFIG_RSK7203
CONFIG_RSK7264
CONFIG_RSK7269
CONFIG_SH7752EVB
CONFIG_SH7753EVB
CONFIG_SH7757LCR
CONFIG_SH7763RDP
CONFIG_SH7785LCR
These macros are all defined once and never checked or used anywhere:
CONFIG_MACH_ASPENITE
CONFIG_MACH_DAVINCI_CALIMAIN
CONFIG_MACH_DOCKSTAR
CONFIG_MACH_EDMINIV2
CONFIG_MACH_GOFLEXHOME
CONFIG_MACH_GONI
CONFIG_MACH_GURUPLUG
CONFIG_MACH_KM_KIRKWOOD
CONFIG_MACH_OPENRD_BASE
CONFIG_MACH_SHEEVAPLUG
Almost all of them were only used for the mach_is_foo() logic in
arch/arm/asm/mach-types.h that were dropped in
commit f9dadaef8b75fa ("arm: Re-sync asm/mach-types.h with
Linux Kernel v4.9")
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
This is a virtual "board" that uses configuration files and
Kconfig to define the memory layout used by a real board during
the board bring-up process.
It generates an SPL image that can be loaded using imx_usb or
SB_LOADER.exe.
When run, it will generate a set of calibration constants for
use in either or both a DCD configuration file for boards that
use u-boot.imx or struct mx6_mmdc_calibration for boards that
boot via SPL.
In essence, it is a configurable, open-source variant of the
Freescale ddr-stress tool.
https://community.nxp.com/docs/DOC-105652
File mx6memcal_defconfig configures the board for use with
mx6sabresd or mx6qsabreauto.
Signed-off-by: Eric Nelson <eric@nelint.com>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
These ifdefs are protecting #include statements for files that have
never existed. AFAICT this hardware.h has been copied from the kernel
and the ifdefs have never served a role in U-Boot, so delete them.
This symbol enables some library code used by various SATA drivers,
so make this a non-user-visible symbol select'ed by the respective
drivers, and let moveconfig handle the rest.
And use 'imply' liberally.
Use 'imply' here liberally to avoid the combinatorial explosion of
defconfig changes in the PowerPC boards.
This does not appear to be used by any boards. Before introducing a new
log system, remove this old one.
