- Bug fixes and updates on ls2088a,ls1028a, ls1046a, ls1043a, ls1012a
- lx2-watchdog support
- layerscape: pci-endpoint support, spin table relocation fixes and
cleanups
- fsl-crypto: RNG support and bug fixes
https://gitlab.denx.de/u-boot/custodians/u-boot-dm
binman support for FIT
new UCLASS_SOC
patman switch 'test' command
minor fdt fixes
patman usability improvements
The eSDHC adapter card identification and multiplexing configuration
through FPGA had been implemented in both common mmc driver and
fsl_esdhc driver. However it is proper to move these code to board
files and do it during board initialization. The FPGA registers are
also board specific.
This patch is to move eSDHC adapter card identification and
multiplexing configuration from mmc driver to specific board files.
And the option CONFIG_FSL_ESDHC_ADAPTER_IDENT is no longer needed.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
[Rebased, Removed T1040QDS change as board does not exist]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Add Kconfig entries for the dc2114x driver and convert various boards.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Ramon Fried <rfried.dev@gmail.com>
If the pylibfdt shared-object file is detected, then Python assumes that
the libfdt.py file exists also.
Sometimes when an incremental build aborts, the shared-object file is
built but the libfdt.py is not. The only way out at this point is to use
'make mkproper', or similar.
Fix this by removing the .so file before it is built. This seems to make
Python rebuild everything.
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing
changes made to 56d37f1c564107e27d873181d838571b7d7860e7.
Unfortunately this is causing CI failures:
https://travis-ci.org/github/trini/u-boot/jobs/711313649
This patch adds very basic support for the Octeon III SoCs. Only
CFI parallel NOR flash and UART is supported for now.
Please note that the basic Octeon port does not include the DDR3/4
initialization yet. This will be added in some follow-up patches
later. To still use U-Boot on with this port, the L2 cache (4MiB on
Octeon III CN73xx) is used as RAM. This way, U-Boot can boot to the
prompt on such boards.
Signed-off-by: Aaron Williams <awilliams@marvell.com>
When fixdep detects CONFIG_IS_ENABLED and other similar macros, it must
parse the macro parameter to determine which actual CONFIG_ option is
being referenced. This involves moving a pointer forward through the
entire CONFIG_ option "word". Currently, the code uses variable q to walk
through the word, but doesn't actually initialize it to point at the
parameter before doing so. Consequently, the walking process immediately
fails since it sees the macro invocatoins's ( rather than the expected
alpha-numeric characters in the macro parameter. Fix this by adding the
missing initialization.
Fixes: 67f2ee86ccbe ("kbuild: fixdep: Resync this with v4.17")
Fixes: 7012865e961c ("gpio: fix test.py for gpio label lookup")
Since commit 4b0bcfa7c4ec (Kconfig: Migrate CONFIG_BOOTM_* options),
the config_defaults.h file has been void of any actual content - and
these days, "sane defaults for everyone" is achieved by appropriate
default values in Kconfig. Remove it, and thus make every translation
unit process one less header file.
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
All configurations have been removed in 2016 by commit 7985cdf74b28
("arm64: Remove non-full-va map code").
CONFIG_ARMV7_PSCI_1_0
CONFIG_ARMV7_PSCI_0_2
There are two options that are currently whitelisted, but they
are redundant, because there are not necessary since Kconfig options
exist to basically state the same thing.
CONFIG_DIRECT_NOR_BOOT and CONFIG_USE_NOR are both set together and
only used by the da850 when booting from NOR, however the only time
CONFIG_MTD_NOR_FLASH is configured is when booting from NOR. Since
NOR doesn't need SPL, the options for SPL can be moved to a check for
building SPL instead of checking for NOR.
This patch removes the checks for these two config options and unifies
the checks around the Kconfig option of CONFIG_MTD_NOR_FLASH.
Since this board is the only board that uses these two config options,
they can be removed from the whitelist table.
- Enable DM_SPI on siemens omap boards (Jagan)
- Dropped some non-dm supported omap3 boards (Jagan)
- Dropped non-dm code in omap3 spi driver (Jagan)
- Dropped non-dm code in kirkwood spi driver (Bhargav)
of-platdata: better phandle and compatible-string support
patman support for Python3 on Ubuntu 14.04
new checkpatch check to avoid #ifdefs
Move ADDR_MAP related config options from include/configs/*.h to the
proper place in lib/Kconfig. This has been done using
./tools/moveconfig.py and manual inspection of the generated changes.
This is a preparation to use ADDR_MAP helper on ARM 32bit Raspberry Pi4
board for mapping the PCIe XHCI MMIO, which is above the 4GiB identity
mapping limit.
Drop the nondm code from kirkwood_spi.c since there
is no board or any other code using for it.
Signed-off-by: Bhargav Shah <bhargavshah1988@gmail.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
This warning should only be displayed for C files. Fix it and update the
test.
OF_CONTROL, DM_SPI and other driver model migration deadlines
are expired for this board.
Drop it.
Cc: Ash Charles <ash@gumstix.com>
Cc: Steve Sakoman <sakoman@gmail.com>
U-Boot does not have loadable modules, and nothing currently uses any
of the (CONFIG_)?IS_(BUILTIN|MODULE) macros - only
the (CONFIG_)?IS_ENABLED variants are ever used.
While I understand the desire to keep this somewhat synchronized with
linux, we've already departed by the introduction of the
CONFIG_IS_ENABLED extra logic, and deleting these makes the next patch
much simpler, since I won't have to duplicate a lot of logic for no
real gain (as there are no users).
While commit 048a648298b1 ("checkpatch.pl: Update to v5.7") largely
re-syncs us with checkpatch.pl from v5.7 there are a number of things
missing still. Re-copy the script and again take care to keep our
allowed debug prints and now localized checks intact.
Fixes: 048a648298b1 ("checkpatch.pl: Update to v5.7")
As part of re-syncing our Kconfig logic up to v4.19, we had missed
adding this new file that includes helper macros. To quote the upstream
commit e1cfdc0e72fc ("kconfig: add basic helper macros to scripts/Kconfig.include"):
Kconfig got text processing tools like we see in Make. Add Kconfig
helper macros to scripts/Kconfig.include like we collect Makefile
macros in scripts/Kbuild.include.
Move CONFIG_PXA_MMC_GENERIC to Kconfig.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next
Xilinx changes for v2020.10
Versal:
- xspi bootmode fix
- Removing one clock from clk driver
- Align u-boot memory setting with OS by default
- Map TCM and OCM by default
ZynqMP:
- Minor DT improvements
- Reduce console buffer for mini configurations
- Add fix for AMS
- Add support for XDP platform
Zynq:
- Support for AES engine
- Enable bigger memory test by default
- Extend documentation for SD preparation
- Use different freq for Topic miami board
mmc:
- minor GD pointer removal
net:
- Support fixed-link cases by zynq gem
- Fix phy looking loop in axi enet driver
spi:
- Cleanup global macros for xilinx spi drivers
firmware:
- Add support for pmufw reloading
fpga:
- Improve error status reporting
common:
- Remove 4kB addition space for FDT allocation
Remove below config options and convert them to macros. They have never
been configured to different values than default one. And also it makes
sense to reduce the config_whitelist.
CONFIG_SYS_ZYNQ_SPI_WAIT
CONFIG_SYS_ZYNQ_QSPI_WAIT
CONFIG_XILINX_SPI_IDLE_VAL
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
into next
- Convert pcnet and eepro100 ethernet drivers to DM
- Convert fsl_espi to driver model (Chuanhua)
- Enable am335x baltos to DM_SPI (Jagan)
- Drop few powerpc board which doesn't have DM enabled (Jagan)
Add Kconfig entries for the eepro100 driver and convert various boards.
This code is never enabled, last board that used it was ELPPC which
was removed some 5 years ago, so just remove this code altogether.
The symbol path already ends with a NUL character (something which is
actually checked by the code) and this NUL is included in
rel_path_len, so there is no need to add a second one.
This change fixes incorrect display in "fdt list /__symbols" after
applying an overlay with symbols.
Signed-off-by: Marcus Comstedt <marcus@mc.pp.se>
Drop CONFIG_SYS_SPI_WRITE_TOUT there is no code usage.
Cc: Wenyou Yang <wenyou.yang@atmel.com>
All of our cmds have a Kconfig entry. Making enabling a CMD via the
config file an error to checkpatch.pl.
There is a lot of use of #ifdefs in U-Boot. In an effort reduce this,
suggest using the compile-time construct.
This request is made with nearly every new command. Point to some docs
on how to do it.
We want people to use the livetree API, so request it.
A common problem when submitting a new uclass is to forget to add sandbox
tests. Add a warning for this.
Of course tests should always be added for new code, but this one seems to
be missed by nearly every new contributor.
Add an option to indicate that U-Boot-specific checks should be enabled.
Add a function to house the code that will be added.
Keep the U-Boot changes to $logFunctions
[trini: Resync with v5.7 release which changed the default max line
length, update commit to reflect]
The symbol "CONFIG_ARM_DCC" is used to control building
drivers/serial/arm_dcc.c. Provide a simple Kconfig entry for this.
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Tom McLeod <tom.mcleod@opalkelly.com>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
Move the CONFIG_GZIP_COMPRESSED from a config.h macro to a Kconfig menu
item. It is not selectable by a user because there is no reason to do
so. Instead it will be automatically selected by the stuff which uses
gzip(), like the zip command.
Remove it from the config_whitelist.txt. Also remove
CONFIG_GZIP_COMPRESS_DEF_SZ as this was never used on any board. The
default seems to be sane, otherwise it should be added as a Kconfig
option.
Signed-off-by: Michael Walle <michael@walle.cc>
Convert ENV_ACCESS_IGNORE_FORCE to Kconfig, no functional change.
Convert CONFIG_KS8851_MLL and CONFIG_KS8851_MLL_BASEADDR to Kconfig
Cc: Eugen Hristev <eugen.hristev@microchip.com>
- Enable -ffunction-sections / -fdata-sections --gc-sections to SH
- RCar Gen3 updates
This function is useful to merge a subset of DT into another DT, for
example if some prior-stage firmware passes a DT fragment to U-Boot
and U-Boot needs to merge it into its own DT. Export this function
to permit implementing such functionality.
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
the mpc83xxx suvd3 variant is not longer used, so
remove it.
Signed-off-by: Holger Brunck <holger.brunck@ch.abb.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
This converts ad-hoc CONFIG_DELAY_ENVIRONMENT to Kconfig.
Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
