path: root/scripts
2019-01-15kbuild: add .SECONDARY special target to scripts/Kbuild.includeMasahiro Yamada
Based on the following Linux commits: - 54a702f70589 ("kbuild: mark $(targets) as .SECONDARY and remove .PRECIOUS markers") - 8e9b61b293d9 ("kbuild: move .SECONDARY special target to Kbuild.include") GNU Make automatically deletes intermediate files that are updated in a chain of pattern rules. Example 1) %.dtb.o <- %.dtb.S <- %.dtb <- %.dts Example 2) %.o <- %.c <- %.c_shipped A couple of makefiles mark such targets as .PRECIOUS to prevent Make from deleting them, but the correct way is to use .SECONDARY. .SECONDARY Prerequisites of this special target are treated as intermediate files but are never automatically deleted. .PRECIOUS When make is interrupted during execution, it may delete the target file it is updating if the file was modified since make started. If you mark the file as precious, make will never delete the file if interrupted. Both can avoid deletion of intermediate files, but the difference is the behavior when Make is interrupted; .SECONDARY deletes the target, but .PRECIOUS does not. The use of .PRECIOUS is relatively rare since we do not want to keep partially constructed (possibly corrupted) targets. .SECONDARY with no prerequisites causes all targets to be treated as secondary. This agrees the policy of Kbuild. scripts/Kbuild.include seems a suitable place to add it because it is included from almost all sub-makes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-01-15kbuild: add .DELETE_ON_ERROR special targetMasahiro Yamada
Linux commit 9c2af1c7377a8a6ef86e5cabf80978f3dbbb25c0 If Make gets a fatal signal while a shell is executing, it may delete the target file that the recipe was supposed to update. This is needed to make sure that it is remade from scratch when Make is next run; if Make is interrupted after the recipe has begun to write the target file, it results in an incomplete file whose time stamp is newer than that of the prerequisites files. Make automatically deletes the incomplete file on interrupt unless the target is marked .PRECIOUS. The situation is just the same as when the shell fails for some reasons. Usually when a recipe line fails, if it has changed the target file at all, the file is corrupted, or at least it is not completely updated. Yet the file’s time stamp says that it is now up to date, so the next time Make runs, it will not try to update that file. However, Make does not cater to delete the incomplete target file in this case. We need to add .DELETE_ON_ERROR somewhere in the Makefile to request it. scripts/Kbuild.include seems a suitable place to add it because it is included from almost all sub-makes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-01-15pylibfdt: Use Python 2 in MakefileJosef Lusticky
pylibfdt needs Python 2 to build. Replace $(PYTHON) with $(PYTHON2) in pylibfdt Makefile to ensure Python 2 is used to build it. This fixes build on systems where Python 3 is the default version of the "python" interpreter. Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-10Kconfig: rename CONFIG_SPL_USB_GADGET_SUPPORT as CONFIG_SPL_USB_GADGETJean-Jacques Hiblot
The SPL option for USB gadget should be named after the option for u-boot (CONFIG_USB_GADGET) Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-26scripts/check-config.sh: Add usage()Andy Shevchenko
When arguments are not supplied the error message is misleading and doesn't tell what exactly has to be done. Fix this by adding usage() and call it if above circumstance occurs. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-12blk: Rework guard around part_init callTom Rini
The function part_init() will only be built when we have both CONFIG_PARTITIONS and CONFIG_HAVE_BLOCK_DEVICE set. Protect the call to this function with both of these tests now. Cc: Simon Glass <sjg@chromium.org> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Stefan Roese <sr@denx.de> Cc: Marek Behún <marek.behun@nic.cz> Cc: Vanessa Maegima <vanessa.maegima@nxp.com> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Adam Ford <aford173@gmail.com> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-05Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- Various MTD fixes from Boris - Zap various unused / legacy paths. - pxa3xx NAND update from Miquel Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-03Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-12-03 This release is fully packed with lots of glorious improvements in UEFI land again! - Make PE images more standards compliant - Improve sandbox support - Improve correctness - Fix RISC-V execution on virt model - Honor board defined top of ram (fixes a few boards) - Imply DM USB access when distro boot is available - Code cleanups
2018-12-03Kconfig: Migrate CONFIG_RTC_M41T62 define to KconfigLukasz Majewski
This patch moves the RTC M41T62 config define to Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-02efi_loader: Generate Microsoft PE format compliant imagesBin Meng
Per Microsoft PE Format documentation [1], PointerToSymbolTable and NumberOfSymbols should be zero for an image in the COFF file header. Currently U-Boot is generating *.efi images (eg: helloworld.efi) in which these two members are not zero. This updates the build rules to tell linker to remove the symbol table completely so that we can generate compliant *.efi images. [1] https://docs.microsoft.com/zh-cn/windows/desktop/Debug/pe-format Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-11-30rtc: rv3029: update to support DM and sync with Linux 4.17Philipp Tomsich
The "Flamingo" carrier-board for the RK3399-Q7 has a RV3029 populated and the application will use the off-module RV3029 RTC including the battery backed SRAM. To support this use case, this commit includes the following changes: * updates the rv3029 driver to use DM * implements the read8/write8 operations This syncs the implementation with the Linux code (based on 4.17), porting the trickle-charger support from there (with improvements to avoid unnecessary EEPROM updates) and adheres to the Linux DTS binding. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
2018-11-28tools: MediaTek: add MTK boot header generation to mkimageRyder Lee
This patch adds support for MTK boot image generation. Signed-off-by: Weijie Gao <weijie.gao@mediatek.com> Signed-off-by: Ryder Lee <ryder.lee@mediatek.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-27spi: Zap CONFIG_HARD_SPIJagan Teki
In legacy CONFIG_HARD_SPI initalizing spi_init code, which was removed during dm conversion cleanup. So remove the dead instances of CONFIG_HARD_SPI, and related code. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-11-26configs: Remove CONFIG_MARVELLChris Packham
This option is defined by a few boards but doesn't guard any code. Remove it from the boards and config_whitelist.txt. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2018-11-26Drop CONFIG_INIT_CRITICALBin Meng
This is now deprecated and no board is using it. Drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2018-11-16arm: at91: wdt: Convert watchdog driver to dm/dtPrasanthi Chellakumar
Convert the Watchdog driver for AT91SAM9x processors to support the driver model and device tree. Changes "CONFIG_AT91SAM9_WATCHDOG" to new "CONFIG_WDT_AT91" Kconfig option. Signed-off-by: Prasanthi Chellakumar <prasanthi.chellakumar@microchip.com>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-10-25Merge tag 'u-boot-imx-20181025' of git://git.denx.de/u-boot-imxTom Rini
Merged imx8 architecture, fix build for imx8 + warnings
2018-10-22Kconfig: Convert CONFIG_IMX_WATCHDOG to KconfigXiaoliang Yang
Move this option to Kconfig and tidy up the config file of eight boards which use it. Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com>
2018-10-19arm: lpc32xx: remove phantom CONFIG_LPC32XX_SDRAM_ config optionVladimir Zapolskiy
The option has never existed and config whitelist script accumulates it from a comment block, wipe it out from the source code. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2018-10-19work_92105: remove unused CONFIG_LPC32XX_SPL configuration optionVladimir Zapolskiy
The CONFIG_LPC32XX_SPL option from board include file has never been used, it is safe to remove it. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2018-10-09configs: mx7: Remove CONFIG_DBG_MONITORFabio Estevam
Remove all CONFIG_DBG_MONITOR references as it is not used anywhere. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2018-10-09fdt: Allow C++ comments in link scripts and DT filesSimon Glass
At present // in a device-tree file or link script causes a warning. But this is used in the standard license header. Update the compiler flags to use C99, which permits this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09Kconfig: Convert CONFIG_RTC_MC146818 to KconfigSimon Glass
Move this option to Kconfig and tidy up the two boards which use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09Makefile: Add a warning if SPL/TPL cannot be builtSimon Glass
At present the build fails in strange ways if CONFIG_SPL is defined by CONFIG_SUPPORT_SPL is not. Add a warning for this case as it can be very confusing to debug. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-06configs: drop CONFIG_SYS_EXTRA_ENV_RELOCSimon Goldschmidt
Instead of manually specifying CONFIG_SYS_EXTRA_ENV_RELOC for every board that needs it, it shouldn't hurt to let initr_reloc_global_data() always relocate gd->env_addr unless we know this pointer is outside the initial binary. To achieve this, the relocation is omitted if CONFIG_ENV_ADDR is defined (and ENV_IS_EMBEDDED is not). Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-09-30Merge git://git.denx.de/u-boot-dmTom Rini
2018-09-30kbuild: fix # escaping in appending U-Boot own DTMasahiro Yamada
The escape sequence '\#' does not work for the latest GNU Make from the git tree. Replace it with $(pound) as Linux did. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-09-30Kbuild: fix # escaping in .cmd files for future MakeRasmus Villemoes
[ commit 9564a8cf422d7b58f6e857e3546d346fa970191e in Linux ] I tried building using a freshly built Make (4.2.1-69-g8a731d1), but already the objtool build broke with orc_dump.c: In function ‘orc_dump’: orc_dump.c:106:2: error: ‘elf_getshnum’ is deprecated [-Werror=deprecated-declarations] if (elf_getshdrnum(elf, &nr_sections)) { Turns out that with that new Make, the backslash was not removed, so cpp didn't see a #include directive, grep found nothing, and -DLIBELF_USE_DEPRECATED was wrongly put in CFLAGS. Now, that new Make behaviour is documented in their NEWS file: * WARNING: Backward-incompatibility! Number signs (#) appearing inside a macro reference or function invocation no longer introduce comments and should not be escaped with backslashes: thus a call such as: foo := $(shell echo '#') is legal. Previously the number sign needed to be escaped, for example: foo := $(shell echo '\#') Now this latter will resolve to "\#". If you want to write makefiles portable to both versions, assign the number sign to a variable: C := \# foo := $(shell echo '$C') This was claimed to be fixed in 3.81, but wasn't, for some reason. To detect this change search for 'nocomment' in the .FEATURES variable. This also fixes up the two make-cmd instances to replace # with $(pound) rather than with \#. There might very well be other places that need similar fixup in preparation for whatever future Make release contains the above change, but at least this builds an x86_64 defconfig with the new make. Link: https://bugzilla.kernel.org/show_bug.cgi?id=197847 Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-09-29Merge tag 'fsl-qoriq-for-v2018.11-rc1' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
Switch to driver model for eSDHC on Layerscape SoCs including LS1021A, LS1043A, LS1046A, LS1088A, LS2088A. Switch to driver model for SATA on LS1021A and LS1043A. Add support for LS1012AFRWY rev C board. Enable SMMU for LS1043A.
2018-09-29Convert CONFIG_DISABLE_CONSOLE to KconfigChristian Gmeiner
This converts the following to Kconfig: CONFIG_DISABLE_CONSOLE Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2018-09-28fdt: Add Python support for adding/removing nodesSimon Glass
Pull this support from these upstream commits: bfbfab0 pylibfdt: Add a means to add and delete notes 9005f41 pylibfdt: Allow delprop() to return errors Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-27drivers: qe: Move CONFIG_U_QE to KconfigRan Wang
Signed-off-by: Ran Wang <ran.wang_1@nxp.com> [York S: revised subject line and removed commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-26Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-09-26 A lot of goodness in this release. We're *very* close to running the UEFI Shell and SCT natively. The only missing piece are HII protocols. - FAT write support (needed for SCT) - improved FAT directory support (needed for SCT) - RTC support with QEMU -M virt - Sandbox support (run UEFI binaries in Linux - yay) - Proper UTF-16 support - EFI_UNICODE_COLLATION_PROTOCOL support (for UEFI Shell) - EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL support (for UEFI Shell) - Fix window size determination - Fix Tegra by explicitly unmapping RAM - Clean up handle entanglement - Lots of generic code cleanup [trini: Fixup merge conflict in include/configs/qemu-arm.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-25configs: Drop CONFIG_SYS_SCSI_MAXDEVICETuomas Tynkkynen
This option has never been used for anything. Drop it. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-23rtc: pl031: convert the driver to driver modelAKASHI Takahiro
With this patch, PL031 driver is converted to driver-model-compliant driver. In addition, CONFIG_SYS_RTC_PL031_BASE is no longer valid. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-22MIPS: cache: remove config option CONFIG_SYS_MIPS_CACHE_MODEDaniel Schwierzeck
Caches should be configured to mode CONF_CM_CACHABLE_NONCOHERENT (or CONF_CM_CACHABLE_COW when a CM is available). There is no need to make this configurable. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-09-22MIPS: start.S: make boot config at offset 0x10 configurableDaniel Schwierzeck
Some MIPS systems store some board-specific boot configuration in the U-Boot binary at offset 0x10. This is used by Malta boards and by Lantiq/Intel SoC's when booting from parallel NOR flash. Convert the hard-coded values to Kconfig options to remove such board-specific stuff out of the generic start.S code. This also deprecates the config option CONFIG_SYS_XWAY_EBU_BOOTCFG. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-09-15sh: tmu: Clean up CONFIG_SYS_TMU_CLK_DIVMarek Vasut
This constant is always 4 , for all boards that exist. Define it once in arch/sh/lib/time.c and remove it from the configs. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-11armv8: K3: am654: Add support for generating build targetsLokesh Vutla
Update Makefile to generate - tispl.bin: First stage bootloader on ARMv8 core - u-boot.img: Second stage bootloader on ARMv8 core. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-10Remove CONFIG_USE_STDINTMasahiro Yamada
You do not need to use the typedefs provided by compiler. Our compilers are either IPL32 or LP64. Hence, U-Boot can/should always use int-ll64.h typedefs like Linux kernel, whatever the typedefs the compiler internally uses. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-08-17Convert CONFIG_SYS_I2C_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Removed unused references to CONFIG_SERIALxAdam Ford
After creating CONS_INDEX and migrating a bunch of boards to it, there are a bunch of defined references to CONFIG_SERIALx which are not referenced in any C code or #ifdef, so they can now be removed Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Convert CONFIG_TWL4030_LED et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_TWL4030_LED CONFIG_TWL4030_INPUT This also removes dead references to: CONFIG_TWL4030_KEYPAD Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Convert CONFIG_VIDEO_OMAP3 to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_VIDEO_OMAP3 Signed-off-by: Adam Ford <aford173@gmail.com>
