path: root/scripts
2018-09-28fdt: Add Python support for adding/removing nodesSimon Glass
Pull this support from these upstream commits: bfbfab0 pylibfdt: Add a means to add and delete notes 9005f41 pylibfdt: Allow delprop() to return errors Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-26Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-09-26 A lot of goodness in this release. We're *very* close to running the UEFI Shell and SCT natively. The only missing piece are HII protocols. - FAT write support (needed for SCT) - improved FAT directory support (needed for SCT) - RTC support with QEMU -M virt - Sandbox support (run UEFI binaries in Linux - yay) - Proper UTF-16 support - EFI_UNICODE_COLLATION_PROTOCOL support (for UEFI Shell) - EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL support (for UEFI Shell) - Fix window size determination - Fix Tegra by explicitly unmapping RAM - Clean up handle entanglement - Lots of generic code cleanup [trini: Fixup merge conflict in include/configs/qemu-arm.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-25configs: Drop CONFIG_SYS_SCSI_MAXDEVICETuomas Tynkkynen
This option has never been used for anything. Drop it. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-23rtc: pl031: convert the driver to driver modelAKASHI Takahiro
With this patch, PL031 driver is converted to driver-model-compliant driver. In addition, CONFIG_SYS_RTC_PL031_BASE is no longer valid. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-22MIPS: cache: remove config option CONFIG_SYS_MIPS_CACHE_MODEDaniel Schwierzeck
Caches should be configured to mode CONF_CM_CACHABLE_NONCOHERENT (or CONF_CM_CACHABLE_COW when a CM is available). There is no need to make this configurable. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-09-22MIPS: start.S: make boot config at offset 0x10 configurableDaniel Schwierzeck
Some MIPS systems store some board-specific boot configuration in the U-Boot binary at offset 0x10. This is used by Malta boards and by Lantiq/Intel SoC's when booting from parallel NOR flash. Convert the hard-coded values to Kconfig options to remove such board-specific stuff out of the generic start.S code. This also deprecates the config option CONFIG_SYS_XWAY_EBU_BOOTCFG. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-09-15sh: tmu: Clean up CONFIG_SYS_TMU_CLK_DIVMarek Vasut
This constant is always 4 , for all boards that exist. Define it once in arch/sh/lib/time.c and remove it from the configs. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-11armv8: K3: am654: Add support for generating build targetsLokesh Vutla
Update Makefile to generate - tispl.bin: First stage bootloader on ARMv8 core - u-boot.img: Second stage bootloader on ARMv8 core. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-09-10Remove CONFIG_USE_STDINTMasahiro Yamada
You do not need to use the typedefs provided by compiler. Our compilers are either IPL32 or LP64. Hence, U-Boot can/should always use int-ll64.h typedefs like Linux kernel, whatever the typedefs the compiler internally uses. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-08-17Convert CONFIG_SYS_I2C_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Removed unused references to CONFIG_SERIALxAdam Ford
After creating CONS_INDEX and migrating a bunch of boards to it, there are a bunch of defined references to CONFIG_SERIALx which are not referenced in any C code or #ifdef, so they can now be removed Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Convert CONFIG_TWL4030_LED et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_TWL4030_LED CONFIG_TWL4030_INPUT This also removes dead references to: CONFIG_TWL4030_KEYPAD Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Convert CONFIG_VIDEO_OMAP3 to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_VIDEO_OMAP3 Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-16CONFIG_SYS_GENERIC_BOARD: Finish migrationTom Rini
While we have long since migrated to CONFIG_SYS_GENERIC_BOARD being enabled, we had just a few places left that still referenced or defined it. Update. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-08-13configs: Resync with savedefconfigTom Rini
2018-08-10configs: omap: Remove dead config CONFIG_SYS_NAND_ADDRAdam Ford
CONFIG_SYS_NAND_ADDR is defined and never referenced. This patch removes the dead code. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-09Merge git://git.denx.de/u-boot-dmTom Rini
2018-08-08libfdt: Update to latest pylibfdt implementationSimon Glass
The enhanced pylibfdt support in U-Boot needed for binman was a placeholder while upstreaming of this work continued. This is now complete, so bring in the changes and update the tools as needed. There are quite a few changes since we decided to split the implementation into three fdt classes instead of two. The Fdt.del_node() method was unfortunately missed in this process and will be dealt with later. It exists in U-Boot but not upstream. Further syncing of libfdt probably needs to wait until we assess the code-size impact of all the new checking code on SPL and possibly provide a way to disable it. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-08-07configs: Resync with savedefconfigTom Rini
2018-08-04Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2018-08-03docproc: RemoveTom Rini
Now that we have moved to Sphinx documentation we don't need the docproc app anymore, remove. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-31configs: sunxi: Drop CONFIG_SUNXI_USB_PHYSJagan Teki
Now number of PHY on Allwinner is handling via dt data, drivers at phy/allwinner/phy-sun4i-usb.c Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2018-07-26ARM: PSCI: Support PSCI v0.2Stephen Warren
Enhance the PSCI DT editing code to allow setting a PSCI v0.2 compatible value in the DT. The CONFIG_ option is added to the whitelist to match the existing PSCI_1_0 option. While not adding new options to Kconfig isn't ideal, I figure it's better to keep related options together. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2018-07-24Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2018-07-25kconfig: Avoid format overflow warning from GCC 8.1Luis Araneda
cherry-pick kernel commit 2ae89c7 (2018-06-05) to avoid warnings when compiling with GCC 8.1 In file included from scripts/kconfig/zconf.tab.c:2486: scripts/kconfig/confdata.c: In function ‘conf_write’: scripts/kconfig/confdata.c:771:22: warning: ‘%s’ directive writing likely 7 or more bytes into a region of size between 1 and 4097 [-Wformat-overflow=] sprintf(newname, "%s%s", dirname, basename); ^~ scripts/kconfig/confdata.c:771:19: note: assuming directive output of 7 bytes sprintf(newname, "%s%s", dirname, basename); ^~~~~~ scripts/kconfig/confdata.c:771:2: note: ‘sprintf’ output 1 or more bytes (assuming 4104) into a destination of size 4097 sprintf(newname, "%s%s", dirname, basename); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ scripts/kconfig/confdata.c:774:23: warning: ‘.tmpconfig.’ directive writing 11 bytes into a region of size between 1 and 4097 [-Wformat-overflow=] sprintf(tmpname, "%s.tmpconfig.%d", dirname, (int)getpid()); ^~~~~~~~~~~ scripts/kconfig/confdata.c:774:3: note: ‘sprintf’ output between 13 and 4119 bytes into a destination of size 4097 sprintf(tmpname, "%s.tmpconfig.%d", dirname, (int)getpid()); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Luis Araneda <luaraneda@gmail.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-07-24config: remove unused CONFIG_SPL_RELOC_STACK_SIZEHeinrich Schuchardt
Symbol CONFIG_SPL_RELOC_STACK_SIZE is not used anywhere. So remove it. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-23Convert CONFIG_DA8XX_GPIO to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DA8XX_GPIO Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-23doc: Replace DocBook with sphinx-based docsMario Six
The Linux kernel moved to sphinx-based documentation and got rid of the DocBook based documentation quite a while ago. Hence, the DocBook documentation for U-Boot should be converted as well. To achieve this, import the necessary files from Linux v4.17, and convert the current DocBook documentation (three files altogether) to sphinx/reStructuredText. For now, all old DocBook documentation was merged into a single handbook, tentatively named "U-Boot Hacker Manual". For some source files, the documentation style was changed to comply with kernel-doc; no functional changes were applied. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21configs: Convert CONFIG_USE_NAND to CONFIG_NANDAdam Ford
The DA850-EVM and OMAPL138_LCDK both use checks for CONFIG_USE_NAND. This patch changes these checks to CONFIG_NAND which is already defined in Kconfig. Since the OMAPL138_LCDK already had CONFIG_NAND defined in its defconfig, it can be deleted from configs/omapl138_lcdk.h. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_LPC32XX_SLC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_LPC32XX_SLC Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-19board/BuR: drop devicetree loading and lcd setup for linux-targetsHannes Schmelzer
This patch drops the lcd-screen setup, the summary screen and getting mac-addresses based on a previous loaded device-tree for linux targets. Selecting those linux target is simple, since we have only the brppt1. In detail we do: - drop the common lcd-setup code which relys on a fdt_blob - drop the common dtb loading mechanism - drop the now obsolete CONFIG_USE_FDT from board header and whitelist. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-10Merge git://git.denx.de/u-boot-dmTom Rini
2018-07-09configs: Resync with savedefconfigTom Rini
2018-07-09libfdt: Add get_property() and del_node()Simon Glass
Add support for these functions in the Python binding. This patch stands in for a pending upstream change. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09libfdt: Fix the Python pack() functionSimon Glass
This currently fails to reduce the device-tree bytearray size. Fix this. This stands in for a pending upstream change. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09libfdt: Bring in proposed pylibfdt changesSimon Glass
This provides various patches sent to the devicetree-compiler mailing list to enhance the Python bindings. A final version of this patch may be created once upstreaming is complete, but if it takes too long, this can act as a placeholder. New pylibfdt features: - Support for most remaining, relevant libfdt functions - Support for sequential-write functions Changes are applied to existing U-Boot tools as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-27spl, nand: add option CONFIG_SPL_NAND_IDENT to lookup for supported NAND chipsJörg Krause
Add the config option `CONFIG_SPL_NAND_IDENT` for using the NAND chip ID list to identify the NAND flash in SPL. Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks>
2018-06-15Merge tag 'xilinx-for-v2018.07-rc2' of git://git.denx.de/u-boot-microblazeTom Rini
Xilinx fixes for v2018.07-rc2 Zynq: - Fix missing watchdog header - DT fixes ZynqMP: - emmc configuration split - Enable SPD - Fix PMUFW_INIT_FILE logic - Coverity fixes in SoC code timer - Add timer_get_boot_us mmc: - Fix MMC HS200 tuning command serial: - Fix scrabled chars with OF_LIVE
2018-06-15arm64: zynqmp: accept an absolute path for PMUFW_INIT_FILELuca Ceresoli
The value of PMUFW_INIT_FILE is prefixed with "$(srctree)/", thus forcing it to be a relative path inside the U-Boot source tree. Since the PMUFW is a binary file generated outside of U-Boot, the PMUFW binary must be copied inside the U-Boot source tree before the build. This generates a few problems: * if the source tree is shared among different out-of-tree builds, they will pollute (and potentially corrupt) each other * the source tree cannot be read-only * any buildsystem must add a command to copy the PMUFW binary * putting an externally-generated binary in the source tree is ugly as hell Avoid these problems by accepting an absolute path for PMUFW_INIT_FILE. This would be as simple as removing the "$(srctree)/" prefix, but in order to keep backward compatibility we rather use the shell and readlink to get the absolute path even when starting from a relative path. Since 'readlink -f' produces an empty string if the file does not exist, we also add a check to ensure the file configured in PMUFW_INIT_FILE exists. Otherwise the build would exit successfully, but produce a boot.bin without PMUFW as if PMUFW_INIT_FILE were empty. Tested in the 12 possible combinations of: - PMUFW_INIT_FILE empty, relative, absolute, non-existing - building in-tree, in subdir, in other directory Signed-off-by: Luca Ceresoli <luca@lucaceresoli.net> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: Emmanuel Vadot <manu@bidouilliste.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-06-14Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-06-14 A few minor fixes for the release: - Compile fixes - HI20 relocations for RISC-V - Fix bootefi without load path - Fix Runtime Services with certain compilers
2018-06-14efi_loader: avoid make race conditionHeinrich Schuchardt
When U-Boot is built with 'make -j' there is not guarantee that targets in directory arch/ are built before targets in directory lib/. The current build instruction for EFI binaries in lib/ rely on dependencies in arch/. If $(EFI_CRT0) or $(EFI_RELOC) is not yet built before trying to build %.efi an error *** No rule to make target '%.efi' occurs. With the patch separate copies of $(EFI_CRT0) and $(EFI_RELOC) named efi_crt0.o and efi_reloc.o are built in lib/efi_loader and lib/efi_selftest. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-06-13x86: ivybridge: Drop CONFIG_USBDEBUGBin Meng
This is not used anywhere. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-13x86: acpi: Adopt new version of iASL compilerAndy Shevchenko
The commit f9a88a4c1cd0 ("iASL: Enhance the -tc option (create AML hex file in C)") in ACPICA project changed a template of the variable that is used in the generated C-file. Now, instead of hard coded "AmlCode" the "%s_aml_code" is in use, where the prefix is a lowered case base name of the output file. In our case it will be "dsdt" producing a name as "dsdt_aml_code". The quick solution is to call sed which replaces new name by the old one to keep compatibility with old version of iASL. The long term solution would be to modify code to use the new name because it is more scalable. Cc: Robert Moore <robert.moore@intel.com> Cc: Sami Mujawar <sami.mujawar@arm.com> Cc: Evan Lloyd <evan.lloyd@arm.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: fixed two sentences in the commit message] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
