path: root/scripts
2018-02-14configs: Resync with savedefconfigTom Rini
2018-02-14spl: unbreak CONFIG_SPL_MULTI_DTB_FIT after fixing CONFIG_OF_EMBEDSimon Goldschmidt
With commit 9bd76b807636 ("spl: make CONFIG_OF_EMBED pass dts through fdtgrep"), CONFIG_SPL_MULTI_DTB_FIT has been broken because cmd_fdtgrep was now unknown in scripts/Makefile.spl after moving it to dts/Makefile. This bug has been introduced with v2018.01. This patch moves cmd_fdtgrep from dts/Makefile to scripts/Makefile.lib and includes scripts/Makefile.lib in scripts/Makefile.spl. Fixes: 9bd76b807636 ("spl: make CONFIG_OF_EMBED pass dts through fdtgrep") Reported-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-02-14configs: Drop unused CONFIG_SPL_MMC_MINIMALTom Rini
The option CONFIG_SPL_MMC_MINIMAL is unused in code, drop it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-13spi: Migrate CONFIG_CF_SPI to KconfigTuomas Tynkkynen
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2018-02-13spi: Migrate CONFIG_LPC32XX_SSP to KconfigTuomas Tynkkynen
2018-02-13spi: Migrate CONFIG_MPC8XXX_SPI to KconfigTuomas Tynkkynen
2018-02-13spi: Migrate CONFIG_MXC_SPI to KconfigTuomas Tynkkynen
2018-02-13spi: Migrate CONFIG_MXS_SPI to KconfigTuomas Tynkkynen
2018-02-13spi: Migrate CONFIG_SH_QSPI to KconfigTuomas Tynkkynen
2018-02-13spi: Migrate CONFIG_SH_SPI to KconfigTuomas Tynkkynen
2018-02-13cmd: fitupd: Convert CONFIG_UPDATE_TFTP and co.Marek Vasut
Convert the CONFIG_UPDATE_TFTP and related symbols to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-02-08Convert CONFIG LIB_HW_RAND to KconfigAdam Ford
config_fallbacks.h had some logic to automatically select LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't already selected. By migrating LIB_HW_RAND to Kconfig, we can remove this check from config_fallbacks.h and put it into Kconfig Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> [trini: Turn into a choice, add NET_RANDOM_ETHADDR] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08Convert CONFIG_APBH_DMA et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_APBH_DMA CONFIG_APBH_DMA_BURST CONFIG_APBH_DMA_BURST8 Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Stefan Agner <stefan.agner@toradex.com> [trini: Add in MMC as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08arm: imx: mx28: Move MX28 selection to KconfigStefan Agner
The motivation for moving MX28 selection to Kconfig is to be able to better handle NAND MXS selection through Kconfig. This selection method also aligns with the way other i.MX SoCs are selected in U-Boot. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2018-02-08arm: imx: mx23: Move MX23 selection to KconfigStefan Agner
The motivation for moving MX23 selection to Kconfig is to be able to better handle NAND MXS selection through Kconfig. This selection method also aligns with the way other i.MX SoCs are selected in U-Boot. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2018-02-08Convert CONFIG_MXC_GPIO to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MXC_GPIO Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-30Convert CONFIG_SYS_OMAP24_I2C_SLAVE et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_OMAP24_I2C_SLAVE CONFIG_SYS_OMAP24_I2C_SPEED Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Paul Kocialkowski <contact@paulk.fr>
2018-01-30Convert CONFIG_SYS_DV_CLKMODE et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_DV_CLKMODE CONFIG_SYS_DA850_PLL0_POSTDIV CONFIG_SYS_DA850_PLL0_PLLDIV1 CONFIG_SYS_DA850_PLL0_PLLDIV2 CONFIG_SYS_DA850_PLL0_PLLDIV3 CONFIG_SYS_DA850_PLL0_PLLDIV4 CONFIG_SYS_DA850_PLL0_PLLDIV5 CONFIG_SYS_DA850_PLL0_PLLDIV6 CONFIG_SYS_DA850_PLL0_PLLDIV7 CONFIG_SYS_DA850_PLL1_POSTDIV CONFIG_SYS_DA850_PLL1_PLLDIV1 CONFIG_SYS_DA850_PLL1_PLLDIV2 CONFIG_SYS_DA850_PLL1_PLLDIV3 Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-30Convert CONFIG_SYS_BOOT_GET_{CMDLINE, KBD} to KconfigDerald D. Woods
This converts the following to Kconfig: CONFIG_SYS_BOOT_GET_CMDLINE CONFIG_SYS_BOOT_GET_KBD Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
2018-01-29kconfig: revert change that was not needed for -Wformat-securityMasahiro Yamada
Recent GCC versions warn if the format string is not a literal because the compiler cannot check the argument validity at compile time. Commit 192bc6948b02 ("Fix GCC format-security errors and convert sprintfs.") blindly replaced sprintf() with strcpy(), including many cases where the format parameter is a string literal. For the kconfig change: sprintf(header, " "); ..., here the format parameter is a string literal " ", so it is definitely equivalent to: strcpy(header, " "); Of course, if the 'header' did not have enough length for containing " ", it would be a security problem, but another problem. (in this case, the 'header' is 4 byte length buffer, so it is not a problem at all.) The kconfig code is kept as synced with Linux as possible, but this change made the code out-of-sync for nothing. Just reverting. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-28bcm2835_mu_serial: Convert to KconfigAlexander Graf
Setting config options using headers is deprecated. This patch converts the BCM2835 Mini-UART to Kconfig. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28pl01x: Convert CONFIG_PL01X_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl01x. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28pl011: Convert CONFIG_PL011_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl011. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28pl010: Convert CONFIG_PL010_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl010. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28powerpc: Drop CONFIG_WALNUT and other related dead codeTuomas Tynkkynen
CONFIG_WALNUT was dropped in June 2017 in: commit 98f705c9cefdfd ("powerpc: remove 4xx support") While at it, the related CONFIG_MACH_SPECIFIC and the have_of and _machine variables are unused as well, so drop them too. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-28host-tools: use python2 explicitly for shebangMasahiro Yamada
All of these host tools are apparently written for Python2, not Python3. Use 'python2' in the shebang line according to PEP 394 (https://www.python.org/dev/peps/pep-0394/). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-27Merge branch 'rmobile-mx' of git://git.denx.de/u-boot-shTom Rini
2018-01-26Merge git://git.denx.de/u-boot-spiTom Rini
2018-01-24ARM: rmobile: Convert CONFIG_R8A77xx to KconfigMarek Vasut
Convert these configuration options to Kconfig, update board defconfigs and drop them from whitelist. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24spi: Remove CONFIG_OF_SPI_FLASHMario Six
Previous patches removed the last usages of this config variable, so that it is now obsolete. This patch removes it from the whitelist. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-24spi: Remove obsolete spi_base_setup_slave_fdtMario Six
0efc024 ("spi_flash: Add spi_flash_probe_fdt() to locate SPI by FDT node") added a helper function spi_base_setup_slave_fdt to to set up a SPI slave from a given FDT blob. The only user was the exynos SPI driver. But commit 73186c9 ("dm: exynos: Convert SPI to driver model") removed the use of this function, hence rendering it obsolete. Remove this function, as well as the CONFIG_OF_SPI option, which guarded only this function. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-22Convert CONFIG_SOC_DA8XX et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SOC_DA8XX CONFIG_SOC_DA850 CONFIG_DA850_LOWLEVEL CONFIG_MACH_DAVINCI_DA850_EVM CONFIG_SYS_DA850_PLL_INIT CONFIG_SYS_DA850_DDR_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: David Lechner <david@lechnology.com> [trini: Rework CONFIG_SYS_DA850_PLL_INIT so it's selected on SOC_DA8XX] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22fs: fat: Drop CONFIG_SUPPORT_VFATTuomas Tynkkynen
fat.h unconditionally defines CONFIG_SUPPORT_VFAT (and has done since 2003), so as a result VFAT support is always enabled regardless of whether a board config defines it or not. Drop this unnecessary option. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-22fs: Migrate ext4 to KconfigTuomas Tynkkynen
Migrate the following symbols to Kconfig: CONFIG_FS_EXT4 CONFIG_EXT4_WRITE The definitions in config_fallbacks.h can now be expressed in Kconfig. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-22Convert CONFIG_ROCKCHIP_USB2_PHY to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ROCKCHIP_USB2_PHY Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22Convert CONFIG_OMAP_USB_PHY to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP_USB_PHY Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22Convert CONFIG_TWL4030_USB to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_TWL4030_USB Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22Convert CONFIG_DAVINCI_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DAVINCI_SPI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22Convert CONFIG_USB_MUSB_HCD et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_USB_MUSB_HCD CONFIG_USB_MUSB_UDC CONFIG_USB_DAVINCI CONFIG_USB_OMAP3 CONFIG_USB_DA8XX CONFIG_USB_AM35X Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22Convert CONFIG_USB_MUSB_OMAP2PLUS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_USB_MUSB_OMAP2PLUS CONFIG_USB_MUSB_AM35X CONFIG_USB_MUSB_DSPS CONFIG_USB_MUSB_PIO_ONLY Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-19powerpc: Drop unreferenced CONFIG_* definesTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_CYRUS CONFIG_IDS8313 CONFIG_MPC8308_P1M CONFIG_MPC8308RDB CONFIG_MPC8349EMDS CONFIG_MPC8349ITXGP CONFIG_SBC8349 CONFIG_SBC8548 CONFIG_SBC8641D CONFIG_TQM834X CONFIG_VE8313 CONFIG_XPEDITE5140 CONFIG_XPEDITE5200 CONFIG_XPEDITE550X Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com> Acked-by: Mario Six <mario.six@gdsys.cc>
2018-01-19m68k: Drop unreferenced CONFIG_* definesTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_AMCORE CONFIG_ASTRO5373L CONFIG_M52277EVB CONFIG_M5253DEMO CONFIG_M5253EVBE CONFIG_M5275EVB CONFIG_M54418TWR CONFIG_STMARK2 Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-19nds32: Drop unreferenced CONFIG_ADP_AG101PTuomas Tynkkynen
Seems to be again one of those CONFIG_ symbols named after a board, with nothing referencing it. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-19pcmcia: Drop a bunch of unused CONFIG_SYS_PCMCIA_ macrosTuomas Tynkkynen
Last users of the following macros (for n = 0..7) were removed in commit 5b8e76c35ec312a ("powerpc, 8xx: remove support for 8xx"): CONFIG_SYS_PCMCIA_PBRn CONFIG_SYS_PCMCIA_PORn Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-15net: sh-eth: Add to Kconfig and convertNobuhiro Iwamatsu
This adds SH_ETHER to drivers/net/Kconfig and convert to Kconfig. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-01-10sh: Drop unreferenced CONFIG_* definesTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_AP325RXA CONFIG_AP_SH4A_4A CONFIG_CPU_SH_TYPE_R CONFIG_ECOVEC CONFIG_ESPT CONFIG_MIGO_R CONFIG_MPR2 CONFIG_MS7720SE CONFIG_MS7722SE CONFIG_MS7750SE CONFIG_R0P7734 CONFIG_R2DPLUS CONFIG_RSK7203 CONFIG_RSK7264 CONFIG_RSK7269 CONFIG_SH7752EVB CONFIG_SH7753EVB CONFIG_SH7757LCR CONFIG_SH7763RDP CONFIG_SH7785LCR Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-10ARM: Drop unreferenced CONFIG_MACH_* definesTuomas Tynkkynen
These macros are all defined once and never checked or used anywhere: CONFIG_MACH_ASPENITE CONFIG_MACH_DAVINCI_CALIMAIN CONFIG_MACH_DOCKSTAR CONFIG_MACH_EDMINIV2 CONFIG_MACH_GOFLEXHOME CONFIG_MACH_GONI CONFIG_MACH_GURUPLUG CONFIG_MACH_KM_KIRKWOOD CONFIG_MACH_OPENRD_BASE CONFIG_MACH_SHEEVAPLUG Almost all of them were only used for the mach_is_foo() logic in arch/arm/asm/mach-types.h that were dropped in commit f9dadaef8b75fa ("arm: Re-sync asm/mach-types.h with Linux Kernel v4.9") Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-08imx: move CONFIG_SYSCOUNTER_TIMER to KconfigStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
