path: root/scripts
2018-08-17Convert CONFIG_SYS_I2C_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Removed unused references to CONFIG_SERIALxAdam Ford
After creating CONS_INDEX and migrating a bunch of boards to it, there are a bunch of defined references to CONFIG_SERIALx which are not referenced in any C code or #ifdef, so they can now be removed Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Convert CONFIG_TWL4030_LED et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_TWL4030_LED CONFIG_TWL4030_INPUT This also removes dead references to: CONFIG_TWL4030_KEYPAD Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Convert CONFIG_VIDEO_OMAP3 to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_VIDEO_OMAP3 Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-16CONFIG_SYS_GENERIC_BOARD: Finish migrationTom Rini
While we have long since migrated to CONFIG_SYS_GENERIC_BOARD being enabled, we had just a few places left that still referenced or defined it. Update. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-08-13configs: Resync with savedefconfigTom Rini
2018-08-10configs: omap: Remove dead config CONFIG_SYS_NAND_ADDRAdam Ford
CONFIG_SYS_NAND_ADDR is defined and never referenced. This patch removes the dead code. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-09Merge git://git.denx.de/u-boot-dmTom Rini
2018-08-08libfdt: Update to latest pylibfdt implementationSimon Glass
The enhanced pylibfdt support in U-Boot needed for binman was a placeholder while upstreaming of this work continued. This is now complete, so bring in the changes and update the tools as needed. There are quite a few changes since we decided to split the implementation into three fdt classes instead of two. The Fdt.del_node() method was unfortunately missed in this process and will be dealt with later. It exists in U-Boot but not upstream. Further syncing of libfdt probably needs to wait until we assess the code-size impact of all the new checking code on SPL and possibly provide a way to disable it. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-08-07configs: Resync with savedefconfigTom Rini
2018-08-04Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2018-08-03docproc: RemoveTom Rini
Now that we have moved to Sphinx documentation we don't need the docproc app anymore, remove. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-31configs: sunxi: Drop CONFIG_SUNXI_USB_PHYSJagan Teki
Now number of PHY on Allwinner is handling via dt data, drivers at phy/allwinner/phy-sun4i-usb.c Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2018-07-26ARM: PSCI: Support PSCI v0.2Stephen Warren
Enhance the PSCI DT editing code to allow setting a PSCI v0.2 compatible value in the DT. The CONFIG_ option is added to the whitelist to match the existing PSCI_1_0 option. While not adding new options to Kconfig isn't ideal, I figure it's better to keep related options together. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2018-07-24Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2018-07-25kconfig: Avoid format overflow warning from GCC 8.1Luis Araneda
cherry-pick kernel commit 2ae89c7 (2018-06-05) to avoid warnings when compiling with GCC 8.1 In file included from scripts/kconfig/zconf.tab.c:2486: scripts/kconfig/confdata.c: In function ‘conf_write’: scripts/kconfig/confdata.c:771:22: warning: ‘%s’ directive writing likely 7 or more bytes into a region of size between 1 and 4097 [-Wformat-overflow=] sprintf(newname, "%s%s", dirname, basename); ^~ scripts/kconfig/confdata.c:771:19: note: assuming directive output of 7 bytes sprintf(newname, "%s%s", dirname, basename); ^~~~~~ scripts/kconfig/confdata.c:771:2: note: ‘sprintf’ output 1 or more bytes (assuming 4104) into a destination of size 4097 sprintf(newname, "%s%s", dirname, basename); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ scripts/kconfig/confdata.c:774:23: warning: ‘.tmpconfig.’ directive writing 11 bytes into a region of size between 1 and 4097 [-Wformat-overflow=] sprintf(tmpname, "%s.tmpconfig.%d", dirname, (int)getpid()); ^~~~~~~~~~~ scripts/kconfig/confdata.c:774:3: note: ‘sprintf’ output between 13 and 4119 bytes into a destination of size 4097 sprintf(tmpname, "%s.tmpconfig.%d", dirname, (int)getpid()); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Luis Araneda <luaraneda@gmail.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-07-24config: remove unused CONFIG_SPL_RELOC_STACK_SIZEHeinrich Schuchardt
Symbol CONFIG_SPL_RELOC_STACK_SIZE is not used anywhere. So remove it. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-23Convert CONFIG_DA8XX_GPIO to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DA8XX_GPIO Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-23doc: Replace DocBook with sphinx-based docsMario Six
The Linux kernel moved to sphinx-based documentation and got rid of the DocBook based documentation quite a while ago. Hence, the DocBook documentation for U-Boot should be converted as well. To achieve this, import the necessary files from Linux v4.17, and convert the current DocBook documentation (three files altogether) to sphinx/reStructuredText. For now, all old DocBook documentation was merged into a single handbook, tentatively named "U-Boot Hacker Manual". For some source files, the documentation style was changed to comply with kernel-doc; no functional changes were applied. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21configs: Convert CONFIG_USE_NAND to CONFIG_NANDAdam Ford
The DA850-EVM and OMAPL138_LCDK both use checks for CONFIG_USE_NAND. This patch changes these checks to CONFIG_NAND which is already defined in Kconfig. Since the OMAPL138_LCDK already had CONFIG_NAND defined in its defconfig, it can be deleted from configs/omapl138_lcdk.h. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_LPC32XX_SLC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_LPC32XX_SLC Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-19board/BuR: drop devicetree loading and lcd setup for linux-targetsHannes Schmelzer
This patch drops the lcd-screen setup, the summary screen and getting mac-addresses based on a previous loaded device-tree for linux targets. Selecting those linux target is simple, since we have only the brppt1. In detail we do: - drop the common lcd-setup code which relys on a fdt_blob - drop the common dtb loading mechanism - drop the now obsolete CONFIG_USE_FDT from board header and whitelist. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-10Merge git://git.denx.de/u-boot-dmTom Rini
2018-07-09configs: Resync with savedefconfigTom Rini
2018-07-09libfdt: Add get_property() and del_node()Simon Glass
Add support for these functions in the Python binding. This patch stands in for a pending upstream change. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09libfdt: Fix the Python pack() functionSimon Glass
This currently fails to reduce the device-tree bytearray size. Fix this. This stands in for a pending upstream change. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-09libfdt: Bring in proposed pylibfdt changesSimon Glass
This provides various patches sent to the devicetree-compiler mailing list to enhance the Python bindings. A final version of this patch may be created once upstreaming is complete, but if it takes too long, this can act as a placeholder. New pylibfdt features: - Support for most remaining, relevant libfdt functions - Support for sequential-write functions Changes are applied to existing U-Boot tools as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-27spl, nand: add option CONFIG_SPL_NAND_IDENT to lookup for supported NAND chipsJörg Krause
Add the config option `CONFIG_SPL_NAND_IDENT` for using the NAND chip ID list to identify the NAND flash in SPL. Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks>
2018-06-15Merge tag 'xilinx-for-v2018.07-rc2' of git://git.denx.de/u-boot-microblazeTom Rini
Xilinx fixes for v2018.07-rc2 Zynq: - Fix missing watchdog header - DT fixes ZynqMP: - emmc configuration split - Enable SPD - Fix PMUFW_INIT_FILE logic - Coverity fixes in SoC code timer - Add timer_get_boot_us mmc: - Fix MMC HS200 tuning command serial: - Fix scrabled chars with OF_LIVE
2018-06-15arm64: zynqmp: accept an absolute path for PMUFW_INIT_FILELuca Ceresoli
The value of PMUFW_INIT_FILE is prefixed with "$(srctree)/", thus forcing it to be a relative path inside the U-Boot source tree. Since the PMUFW is a binary file generated outside of U-Boot, the PMUFW binary must be copied inside the U-Boot source tree before the build. This generates a few problems: * if the source tree is shared among different out-of-tree builds, they will pollute (and potentially corrupt) each other * the source tree cannot be read-only * any buildsystem must add a command to copy the PMUFW binary * putting an externally-generated binary in the source tree is ugly as hell Avoid these problems by accepting an absolute path for PMUFW_INIT_FILE. This would be as simple as removing the "$(srctree)/" prefix, but in order to keep backward compatibility we rather use the shell and readlink to get the absolute path even when starting from a relative path. Since 'readlink -f' produces an empty string if the file does not exist, we also add a check to ensure the file configured in PMUFW_INIT_FILE exists. Otherwise the build would exit successfully, but produce a boot.bin without PMUFW as if PMUFW_INIT_FILE were empty. Tested in the 12 possible combinations of: - PMUFW_INIT_FILE empty, relative, absolute, non-existing - building in-tree, in subdir, in other directory Signed-off-by: Luca Ceresoli <luca@lucaceresoli.net> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: Emmanuel Vadot <manu@bidouilliste.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-06-14Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-06-14 A few minor fixes for the release: - Compile fixes - HI20 relocations for RISC-V - Fix bootefi without load path - Fix Runtime Services with certain compilers
2018-06-14efi_loader: avoid make race conditionHeinrich Schuchardt
When U-Boot is built with 'make -j' there is not guarantee that targets in directory arch/ are built before targets in directory lib/. The current build instruction for EFI binaries in lib/ rely on dependencies in arch/. If $(EFI_CRT0) or $(EFI_RELOC) is not yet built before trying to build %.efi an error *** No rule to make target '%.efi' occurs. With the patch separate copies of $(EFI_CRT0) and $(EFI_RELOC) named efi_crt0.o and efi_reloc.o are built in lib/efi_loader and lib/efi_selftest. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-06-13x86: ivybridge: Drop CONFIG_USBDEBUGBin Meng
This is not used anywhere. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-13x86: acpi: Adopt new version of iASL compilerAndy Shevchenko
The commit f9a88a4c1cd0 ("iASL: Enhance the -tc option (create AML hex file in C)") in ACPICA project changed a template of the variable that is used in the generated C-file. Now, instead of hard coded "AmlCode" the "%s_aml_code" is in use, where the prefix is a lowered case base name of the output file. In our case it will be "dsdt" producing a name as "dsdt_aml_code". The quick solution is to call sed which replaces new name by the old one to keep compatibility with old version of iASL. The long term solution would be to modify code to use the new name because it is more scalable. Cc: Robert Moore <robert.moore@intel.com> Cc: Sami Mujawar <sami.mujawar@arm.com> Cc: Evan Lloyd <evan.lloyd@arm.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: fixed two sentences in the commit message] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2018-06-07script: Make get_default_envs.sh script exclude tools/envSeung-Woo Kim
If building envtools, there is env directory in tools directory. Mafe the get_default_envs.sh script exclude tools/env directory. Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
2018-06-04scripts: mailmapper: SPDX license identifierHeinrich Schuchardt
If the SPDX license identifier is in the first line the shell does not recognize which interpreter shall be used to execute the script. Cf. https://www.kernel.org/doc/html/v4.16/process/license-rules.html for scripts which require the '#!PATH_TO_INTERPRETER' in the first line (...) the SPDX identifier goes into the second line. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-06-04Set time and umask on multi-dtb fit images to ensure reproducibile builds.Vagrant Cascadian
When building compressed (lzop, gzip) multi-dtb fit images, the compression tool may embed the time or umask in the image. Work around this by manually setting the time of the source file using SOURCE_DATE_EPOCH and a hard-coded 0600 umask. With gzip, this could be accomplished by using -n/--no-name, but lzop has no current workaround: https://bugs.debian.org/896520 Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
2018-06-01Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2018-05-31scripts/dtc: Re-sync with Linux 4.17-rc4Eugeniu Rosca
To achieve a DTC state (more or less) equivalent to Linux 4.17-rc4, backport the DTC-specific part from below Linux commits: b23d1a241f4eb4 ("kbuild: add %.lex.c and %.tab.[ch] to 'targets' automatically") 9a8dfb394c0467 ("kbuild: clean up *.lex.c and *.tab.[ch] patterns from top-level Makefile") 59889300274569 (".gitignore: move *.lex.c *.tab.[ch] patterns to the top-level .gitignore") e039139be8c251 ("scripts/dtc: generate lexer and parser during build instead of shipping") b24413180f5600 ("License cleanup: add SPDX GPL-2.0 license identifier to files with no license") With this commit, the diff between Linux and U-boot common DTC files is: $ git diff --stat --diff-filter=M v4.17-rc4 <this-commit> -- scripts/dtc scripts/dtc/.gitignore | 2 +- scripts/dtc/Makefile | 3 +++ The delta is coming from U-boot commits: * v2017.11 de163ecedb8a ("scripts: dtc: Add .gitignore") * v2018.01 15b97f5c5e6d ("pylibfdt: move pylibfdt to scripts/dtc/pylibfdt and refactor makefile") Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-05-31scripts/dtc: Update to upstream version v1.4.6-9-gaadd0b65c987Rob Herring
This adds the following commits from upstream: aadd0b65c987 checks: centralize printing of property names in failure messages 88960e398907 checks: centralize printing of node path in check_msg f1879e1a50eb Add limited read-only support for older (V2 and V3) device tree to libfdt. 37dea76e9700 srcpos: drop special handling of tab 65893da4aee0 libfdt: overlay: Add missing license 962a45ca034d Avoid installing pylibfdt when dependencies are missing cd6ea1b2bea6 Makefile: Split INSTALL out into INSTALL_{PROGRAM,LIB,DATA,SCRIPT} 51b3a16338df Makefile.tests: Add LIBDL make(1) variable for portability sake 333d533a8f4d Attempt to auto-detect stat(1) being used if not given proper invocation e54388015af1 dtc: Bump version to v1.4.6 a1fe86f380cb fdtoverlay: Switch from using alloca to malloc c8d5472de3ff tests: Improve compatibility with other platforms c81d389a10cc checks: add chosen node checks e671852042a7 checks: add aliases node checks d0c44ebe3f42 checks: check for #{size,address}-cells without child nodes 18a3d84bb802 checks: add string list check for *-names properties 8fe94fd6f19f checks: add string list check 6c5730819604 checks: add a string check for 'label' property a384191eba09 checks: fix sound-dai phandle with arg property check b260c4f610c0 Fix ambiguous grammar for devicetree rule fe667e382bac tests: Add some basic tests for the pci_bridge checks 7975f6422260 Fix widespread incorrect use of strneq(), replace with new strprefixeq() fca296445eab Add strstarts() helper function cc392f089007 tests: Check non-matching cases for fdt_node_check_compatible() bba26a5291c8 livetree: avoid assertion of orphan phandles with overlays c8f8194d76cc implement strnlen for systems that need it c8b38f65fdec libfdt: Remove leading underscores from identifiers 3b62fdaebfe5 Remove leading underscores from identifiers 2d45d1c5c65e Replace FDT_VERSION() with stringify() 2e6fe5a107b5 Fix some errors in comments b0ae9e4b0ceb tests: Correct warning in sw_tree1.c Commit c8b38f65fdec upstream ("libfdt: Remove leading underscores from identifiers") changed the multiple inclusion define protection, so the kernel's libfdt_env.h needs the corresponding update. Signed-off-by: Rob Herring <robh@kernel.org> [ Linux commit: 9130ba884640328bb78aaa4840e5ddf06ccafb1c ] [erosca: - Fixup conflicts in include/linux/libfdt_env.h caused by v2018.03-rc4 commit b08c8c487083 ("libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>") - Fix build errors in lib/libfdt/fdt_ro.c, tools/libfdt/fdt_rw.c by: - s/_fdt_mem_rsv/fdt_mem_rsv_/ - s/_fdt_offset_ptr/fdt_offset_ptr_/ - s/_fdt_check_node_offset/fdt_check_node_offset_/ - s/_fdt_check_prop_offset/fdt_check_prop_offset_/ - s/_fdt_find_add_string/fdt_find_add_string_/] Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-05-31scripts/dtc: Update to upstream version v1.4.5-6-gc1e55a5513e9Rob Herring
Pickup the fix for handling unresolved phandles in overlays. This adds the following commits from upstream: c1e55a5513e9 checks: fix handling of unresolved phandles for dts plugins f8872e29ce06 tests: Avoid 64-bit arithmetic in assembler 48c91c08bcfa libfdt: add stringlist functions to linker script Signed-off-by: Rob Herring <robh@kernel.org> [ Linux commit: e45fe7f788dd1395befe5639149ad8dacfbd94ab ] Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-05-31kconfig: re-sync with Linux 4.17-rc4Eugeniu Rosca
Align Kconfig to Linux 4.17-rc4 with minimal impact on non-kconfig files. Previous Kconfig sync was done by commit bf7ab1e70fd762 ("kconfig: re-sync with Linux 4.10") and it achieved almost perfect alignment with a few (intended) exceptions, caused by below U-boot commits: [A] v2015.04 5f9eb2207500 ("kbuild: remove scripts/multiconfig.sh") [B] v2015.07 20c20826efab ("Kconfig: Enable usage of escape char '\' in string values") [C] v2016.01 da58dec86616 ("Various Makefiles: Add SPDX-License-Identifier tags") [D] v2016.03 5b8031ccb4ed ("Add more SPDX-License-Identifier tags") [E] v2016.03 192bc6948b02 ("Fix GCC format-security errors and convert sprintfs.") Here is the list of Kconfig commits which followed the v4.10 alignment: [F] v2018.01 0931ed3c0d0f ("kconfig/symbol.c: use correct pointer type argument for sizeof") [G] v2018.03 1414e09b4f25 ("kconfig: revert change that was not needed for -Wformat-security") [H] v2018.05 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style") Commit [F] was subsequently applied to Linux kernel as commit [I] with the same patch id, so it won't contribute to further misalignment. [I] v4.15-rc1 88127dae6ed9 ("kconfig/symbol.c: use correct pointer type argument for sizeof") Commit [G] is a Kconfig-specific revert of commit [E]. Commit [H] relocated and reformatted the license doing no functional change. In summary, the only functional change that makes U-boot Kconfig diverge from Linux Kconfig is commit [B]. After a brief analysis, the purpose of [B] seems to be placing "\n" literals in string symbols like CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" in order to pass them directly to printf and expect correct output at runtime. Currently, Linux doesn't seem to have this requirement, so for the moment [B] looks like a U-boot specific feature/fix. From point of view of further Kconfig alignment and backporting efforts, it is highly desired that commits like [B] are propagated to Linux and any Kconfig fixes/features are contributed to Linux kernel first. This specific Kconfig re-sync just keeps [B] in place. Contrary to 4.10 Kconfig re-sync (which achieves zero non-kconfig changes), 4.17-rc4 re-sync does some amount of updates in Kbuild (striving to keep them at minimum), due to a number of reasons: * Kbuild is affected by the removal of Kconfig "*shipped" files and now requires flex and bison pre-installed on the host. * PYTHON{2,3} variables are defined in top-level Makefile as prerequisite for running the newly developed Kconfig unit tests. * silentoldconfig becomes an "internal implementation detail" deprecated for external use, being renamed to syncconfig. The exact non-kconfig files touched by this commit are: $ git show --format="" --stat -- ':!scripts/kconfig' .gitignore | 2 ++ Makefile | 9 +++++++-- scripts/Makefile.build | 11 +++++++++++ scripts/Makefile.lib | 41 ++++++++++++----------------------------- The imported Linux commits touching the above files are: c054be10ffdbd5 ("remove gperf left-overs from build system") 73a4f6dbe70a1b ("kbuild: add LEX and YACC variables") 033dba2ec06c47 ("kbuild: prepare to remove C files pre-generated by flex and bison") eea199b445f64c ("kbuild: remove unnecessary LEX_PREFIX and YACC_PREFIX") e71de5ee08dcb0 ("kbuild: remove remaining use of undefined YACC_PREFIX") d59fbbd09d5d6b ("kbuild: replace hardcoded bison in cmd_bison_h with $(YACC)") 911a91c39cabcb H ("kconfig: rename silentoldconfig to syncconfig") 59889300274569 (".gitignore: move *.lex.c *.tab.[ch] patterns to the top-level .gitignore") 9a8dfb394c0467 ("kbuild: clean up *.lex.c and *.tab.[ch] patterns from top-level Makefile") 833e622459432e H ("genksyms: generate lexer and parser during build instead of shipping") b23d1a241f4eb4 H ("kbuild: add %.lex.c and %.tab.[ch] to 'targets' automatically") e9781b52d4e0e3 H ("kbuild: add PYTHON2 and PYTHON3 variables") The commits marked with 'H' are assessed as "hard" (build will fail) prerequisites and the rest of them are assessed as "soft" prerequisites for the re-sync. In spite of relatively high number of non-H commits, they belong to this Kconfig update topic-wise and decrease the number of cherry pick conflicts for many commits in this series. Additional effort can be put in eliminating the soft prerequisites, if really needed. The commits which contributed to this Kconfig re-sync are listed below. Whenever a conflict resolution has been performed (mostly by hand, but sometimes automatically by git), it is revealed by the '!' sign in the second column, which means a patch id mismatch between Linux and U-boot commits: 9be3213b14d44f ("gconfig: remove misleading parentheses around a condition") ff85a1a80e0034 ("kconfig: Check for libncurses before menuconfig") ad8181060788c8 ("kconfig: fix sparse warnings in nconfig") cb77f0d623ff33 ! ("scripts: Switch to more portable Perl shebang") bb3290d91695bb ! ("Remove gperf usage from toolchain") c054be10ffdbd5 ("remove gperf left-overs from build system") b24413180f5600 ! ("License cleanup: add SPDX GPL-2.0 license identifier to files with no license") 9059a3493efea6 ! ("kconfig: fix relational operators for bool and tristate symbols") 2c37e08464a850 ("kconfig: Warn if choice default is not in choice") 33ca1a24866373 ("kconfig: Document the 'menu' struct") 52aede4ba5efd1 ("kconfig: Document the 'symbol' struct") c873443430ebd1 ("kconfig: Sync zconf.y with zconf.tab.c_shipped") 9a826842ff2fbd ("kconfig: Rename menu_check_dep() to rewrite_m()") fa8cedaef814ce ("kconfig: Clarify expression rewriting") f77850d3fe0c96 ("kconfig: Clean up modules handling and fix crash") e3b03bf29d6b99 ("kconfig: display recursive dependency resolution hint just once") 73a4f6dbe70a1b ! ("kbuild: add LEX and YACC variables") 033dba2ec06c47 ! ("kbuild: prepare to remove C files pre-generated by flex and bison") 29c833061c1d8c ("kconfig: generate lexer and parser during build instead of shipping") 26e47a3c11a25c ("kconfig: Don't leak symbol names during parsing") 24161a6711c945 ("kconfig: Don't leak 'source' filenames during parsing") bc28fe1d5ede88 ("kconfig: Don't leak 'option' arguments during parsing") 0724a7c32a54e3 ("kconfig: Don't leak main menus during parsing") ae7440ef0c8013 ("kconfig: Fix automatic menu creation mem leak") 5b1374b3b3c2fc ("kconfig: Fix expr_free() E_NOT leak") 7cf33f88e29410 ("kconfig: Fix choice symbol expression leak") 05cccce580456d ("kconfig: Document automatic submenu creation code") 0735f7e5def2ab ("kconfig: Document important expression functions") df60f4b92d3d0b ("kconfig: Remove menu_end_entry()") b92d804a51796b ("kconfig: drop 'boolean' keyword") 6479f327dea60d ("kconfig: Warn if there is more than one help text") 52e58a3caeba5d ("kconfig: make input_mode static") 5a3dc717b3c785 ("kconfig: make xfgets() really static") 84dd95d4f87a0d ("kconfig: make conf_unsaved a local variable of conf_read()") 765f4cdef6f80d ("kconfig: use default 'yy' prefix for lexer and parser") eea199b445f64c ("kbuild: remove unnecessary LEX_PREFIX and YACC_PREFIX") e71de5ee08dcb0 ("kbuild: remove remaining use of undefined YACC_PREFIX") d59fbbd09d5d6b ! ("kbuild: replace hardcoded bison in cmd_bison_h with $(YACC)") 3e41ba05b6d60c ("kconfig: Document SYMBOL_OPTIONAL logic") d3465af60f4471 ("kconfig: Clarify choice dependency propagation") 9d1a9e8bc18bea ("kconfig: Document 'if' flattening logic") b53688014e3325 ("kconfig: Clarify menu and 'if' dependency propagation") d0fd0428ecf04b ("kconfig: fix make xconfig when gettext is missing") 312ee68752faaa ("kconfig: announce removal of oldnoconfig if used") 1ccb27143360bd ("kconfig: make "Selected by:" and "Implied by:" readable") cedd55d49dee94 ! ("kconfig: Remove silentoldconfig from help and docs; fix kconfig/conf's help") 1b9eda2e4892cb ("kconfig: Warn if help text is blank") cb67ab2cd2b8ab ("kconfig: do not write choice values when their dependency becomes n") 4f208f392103e8 ("kconfig: show '?' prompt even if no help text is available") cd58a91def2acc ("kconfig: remove 'config*' pattern from .gitignnore") d2a04648a5dbc3 ("kconfig: remove check_stdin()") f3ff6fb5db68bc ("kconfig: echo stdin to stdout if either is redirected") 9e3e10c725360b ("kconfig: send error messages to stderr") d717f24d8c6808 ("kconfig: add xrealloc() helper") 523ca58b7db2e3 ("kconfig: remove const qualifier from sym_expand_string_value()") cd81fc82b93fa4 ("kconfig: add xstrdup() helper") f4bc1eefc1608e ("kconfig: set SYMBOL_AUTO to the symbol marked with defconfig_list") bf0bbdcf100322 ("kconfig: Don't leak choice names during parsing") 1a90ce36c6eff6 ("kconfig: Update ncurses package names for menuconfig") 5ae6fcc4bb82bd ("kconfig: fix line number in recursive inclusion error message") 07a422bb213adb ! ("kbuild: restore autoksyms.h touch to the top Makefile") 9a47ceec543bfb ("kconfig: clean-up reverse dependency help implementation") d9119b5925a03b ("kconfig: Print reverse dependencies in groups") f467c5640c29ad ("kconfig: only write '# CONFIG_FOO is not set' for visible symbols") 59a80b5e892dde ("kconfig: do not call check_conf() for olddefconfig") 4bb3a5b085cd6f ("kconfig: remove unneeded input_mode test in conf()") 99f0b6578bab44 ("kconfig: remove redundant input_mode test for check_conf() loop") 2aad9b89621386 ("kconfig: hide irrelevant sub-menus for oldconfig") 81d2bc2273052e ("kconfig: invoke oldconfig instead of silentoldconfig from local*config") 911a91c39cabcb ! ("kconfig: rename silentoldconfig to syncconfig") 2a61625835c7c8 ! ("kconfig: remove redundant streamline_config.pl prerequisite") 022a4bf6b59dfd ("kconfig: tests: add framework for Kconfig unit testing") 1903c511905984 ("kconfig: tests: add basic choice tests") 49ac3c0c3aa3b7 ("kconfig: tests: test automatic submenu creation") b76960c0f6b25d ("kconfig: tests: test if new symbols in choice are asked") 930c429a656fdb ("kconfig: tests: check unneeded "is not set" with unmet dependency") ee236610653ede ("kconfig: tests: check visibility of tristate choice values in y choice") beaaddb625400e ("kconfig: tests: test defconfig when two choices interact") 3e4888c2e3d77d ("kconfig: tests: test randconfig for choice in choice") 29c434f367ea7b ("kconfig: tests: test if recursive dependencies are detected") e2c75e7667c737 ("kconfig: tests: test if recursive inclusion is detected") f622f827958162 ("kconfig: warn unmet direct dependency of tristate symbols selected by y") f8f69dc0b4e070 ("kconfig: make unmet dependency warnings readable") 26561514cc9def ("kconfig: do not include both curses.h and ncurses.h for nconfig") 32a94b8b0c3e5a ("kconfig: remove duplicated file name and lineno of recursive inclusion") 379a8eb8eb1a55 ("kconfig: detect recursive inclusion earlier") 18492685e479fd ("kconfig: use yylineno option instead of manual lineno increments") 59889300274569 ! (".gitignore: move *.lex.c *.tab.[ch] patterns to the top-level .gitignore") 9a8dfb394c0467 ! ("kbuild: clean up *.lex.c and *.tab.[ch] patterns from top-level Makefile") 833e622459432e ! ("genksyms: generate lexer and parser during build instead of shipping") b23d1a241f4eb4 ! ("kbuild: add %.lex.c and %.tab.[ch] to 'targets' automatically") 17baab68d337a0 ("kconfig: extend output of 'listnewconfig'") e9781b52d4e0e3 ! ("kbuild: add PYTHON2 and PYTHON3 variables") The current Kconfig update generates below build-time warnings: YACC scripts/dtc/dtc-parser.tab.h scripts/dtc/dtc-parser.y: warning: 3 shift/reduce conflicts [-Wconflicts-sr] YACC scripts/dtc/dtc-parser.tab.c scripts/dtc/dtc-parser.y: warning: 3 shift/reduce conflicts [-Wconflicts-sr] This seems to happen because the Kbuild updates apparently didn't make room for both "*shipped"-based builds and flex/bison-based builds. A similar problem has been reported for genksyms parser in v4.17-rc1 commit 833e622459432e ("genksyms: generate lexer and parser during build instead of shipping"). I have figured out empirically that the warnings are healed after updating the in-tree U-boot DTC to upstream v1.4.6-9, same as done by Linux v4.17-rc1 commit 9130ba88464032 ("scripts/dtc: Update to upstream version v1.4.6-9-gaadd0b65c987"). Whether fixing the DTC-related yacc warnings should be done together with the Kconfig re-sync, I would like to hear from community. My testing was limited to: - make defconfig all - make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- r8a7795_ulcb_defconfig all - comparing .config before and after the re-sync - running the newly imported Kconfig unit tests as seen below: $ make testconfig Tested-by: Petr Vorel <petr.vorel@gmail.com> ============================= test session starts ============================= scripts/kconfig/tests/auto_submenu/__init__.py::test PASSED [ 7%] scripts/kconfig/tests/choice/__init__.py::test_oldask0 PASSED [ 14%] scripts/kconfig/tests/choice/__init__.py::test_oldask1 PASSED [ 21%] scripts/kconfig/tests/choice/__init__.py::test_allyes PASSED [ 28%] scripts/kconfig/tests/choice/__init__.py::test_allmod PASSED [ 35%] scripts/kconfig/tests/choice/__init__.py::test_allno PASSED [ 42%] scripts/kconfig/tests/choice/__init__.py::test_alldef PASSED [ 50%] scripts/kconfig/tests/choice_value_with_m_dep/__init__.py::test PASSED [ 57%] scripts/kconfig/tests/err_recursive_inc/__init__.py::test PASSED [ 64%] scripts/kconfig/tests/inter_choice/__init__.py::test PASSED [ 71%] scripts/kconfig/tests/new_choice_with_dep/__init__.py::test PASSED [ 78%] scripts/kconfig/tests/no_write_if_dep_unmet/__init__.py::test PASSED [ 85%] scripts/kconfig/tests/rand_nested_choice/__init__.py::test PASSED [ 92%] scripts/kconfig/tests/warn_recursive_dep/__init__.py::test PASSED [100%] ========================== 14 passed in 0.34 seconds ========================== Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Petr Vorel <petr.vorel@gmail.com>
