path: root/scripts
2015-03-05fixdep: remove multiple .config support codeMasahiro Yamada
Since commit e02ee2548afe (kconfig: switch to single .config configuration), the ".*.cmd" files are not correctly created for SPL/TPL. The U-Boot extension code in fixdep, which was introduced to support the multiple .config, must be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-05scripts/checkstack.pl: update to get AArch64 port from LinuxKim Phillips
Bring checkstack.pl up to date from its upstream Linux development. Effectively, the following linux commits: 208ad00 checkstack.pl: port to AArch64 fda9f99 scripts/checkstack.pl: automatically handle 32-bit and 64-bit mode for ARCH=x86 7eb6e34 kbuild: trivial - remove trailing empty lines 690998b scripts/checkstack.pl: Add metag support Reported-by: York Sun <yorksun@freescale.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2015-03-02kconfig: remove unneeded U-Boot extension codeMasahiro Yamada
This code was introduced to support the multiple .config configuration in U-Boot. We do not need it any more. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-24kconfig: switch to single .config configurationMasahiro Yamada
When Kconfig for U-boot was examined, one of the biggest issues was how to support multiple images (Normal, SPL, TPL). There were actually two options, "single .config" and "multiple .config". After some discussions and thought experiments, I chose the latter, i.e. to create ".config", "spl/.config", "tpl/.config" for Normal, SPL, TPL, respectively. It is true that the "multiple .config" strategy provided us the maximum flexibility and helped to avoid duplicating CONFIGs among Normal, SPL, TPL, but I have noticed some fatal problems: [1] It is impossible to share CONFIG options across the images. If you change the configuration of Main image, you often have to adjust some SPL configurations correspondingly. Currently, we cannot handle the dependencies between them. It means one of the biggest advantages of Kconfig is lost. [2] It is too painful to change both ".config" and "spl/.config". Sunxi guys started to work around this problem by creating a new configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.) added "make *_felconfig" to enable CONFIG_SPL_FEL on both images. Changing the configuration of multiple images in one command is a generic demand. The current implementation cannot propose any good solution about this. [3] Kconfig files are getting ugly and difficult to understand. Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files. [4] The build system got more complicated than it should be. To adjust Linux-originated Kconfig to U-Boot, the helper script "scripts/multiconfig.sh" was introduced. Writing a complicated text processor is a shell script sometimes caused problems. Now I believe the "single .config" will serve us better. With it, all the problems above would go away. Instead, we will have to add some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM, but we will not have much. Anyway, this is what we do now in scripts/Makefile.spl. I admit my mistake with my apology and this commit switches to the single .config configuration. It is not so difficult to do that: - Remove unnecessary processings from scripts/multiconfig.sh This file will remain for a while to support the current defconfig format. It will be removed after more cleanups are done. - Adjust some makefiles and Kconfigs - Add some entries to include/config_uncmd_spl.h and the new file scripts/Makefile.uncmd_spl. Some CONFIG options that are not supported on SPL must be disabled because one .config is shared between SPL and U-Boot proper going forward. I know this is not a beautiful solution and I think we can do better, but let's see how much we will have to describe them. - update doc/README.kconfig More cleaning up patches will follow this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-21kbuild: prepare for moving headers into mach-*/include/machMasahiro Yamada
In U-Boot, SoC-specific headers are placed in arch/$(ARCH)/include/asm/arch-$(SOC) and a symbolic link to that directory is created at the early stage of the build process. Creating and removing a symbolic link during the build is not preferred. In fact, Linux Kernel did away with include/asm-$(ARCH) directories a long time time ago. As for ARM, now it is possible to collect SoC sources into arch/arm/mach-$(SOC). It is also reasonable to move SoC headers into arch/arm/mach-$(SOC)/include/mach. This commit prepares for that. If the directory arch/$(ARCH)/mach-$(SOC)/include/mach exists, a symbolic to that directory is created. Otherwise, a symbolic link to arch/$(ARCH)/include/asm/arch-$(SOC) or arch-$(CPU) is created. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-16sunxi: Normalise FEL supportSimon Glass
Make sunxi's FEL code fit with the normal U-Boot boot sequence instead of creating its own. There are some #ifdefs required in start.S. Future work will hopefully remove these. This series is available at u-boot-dm, branch sunxi-working. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-06scripts/Makefile.spl: Add MVEBU DDR code to SPLStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2015-01-14scripts: add a utility to fill blank fields of doc/README.scrapyardMasahiro Yamada
We are removing bunch of non-generic boards these days. Updating doc/README.scrapyard is a really tedious task, but it can be automated. I hope this tool will make our life easier. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-01-14sunxi: Fix CONFIG_UART0_PORT_F build and add it to menuconfigSiarhei Siamashka
The CONFIG_UART0_PORT_F option has been supported since http://git.denx.de/?p=u-boot.git;a=commit;h=ff2b47f6a9cc1025 This option is primarily useful only for low level u-boot debugging on tablets, where normal UART0 is difficult to access and requires device disassembly and/or soldering. This patch now allows it to be selected from menuconfig. A dependency on SPL_FEL is added because u-boot does not support booting from NAND yet and also booting from SD card is impossible when a MicroSD breakout board is plugged into the SD slot. Additionally a compilation problem is fixed: common/spl/built-in.o: In function `spl_mmc_load_image': /tmp/u-boot-sunxi/common/spl/spl_mmc.c:94: undefined reference to `mmc_initialize' /tmp/u-boot-sunxi/common/spl/spl_mmc.c:96: undefined reference to `find_mmc_device' /tmp/u-boot-sunxi/common/spl/spl_mmc.c:104: undefined reference to `mmc_init' scripts/Makefile.spl:206: recipe for target 'spl/u-boot-spl' failed Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-08scripts: fix binutils-version.sh for 'as' without a package.Bill Pringlemeir
Commit 73c25753 fixed the common issue that binutil packages (tool/organization that packaged or built the bin-utils) are included in brackets and this may falsely be recognized as a version. However, some tools do not provide a 'package' and previously we add the 'Gnu assembler..' to the version. Strip out the '(package version text)' and then look for a ##.## string. Signed-off-by: Bill Pringlemeir <bpringlemeir@nbsps.com> Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Hans de Goede <hdegoede@redhat.com>
2014-12-29scripts: fix binutils-version.shMasahiro Yamada
The current binutils-version.sh expects the version string at the end of the first line. It turned out to not work with Linaro toolchain: It has "Linaro 2014.09" at the back. To fix this issue, let's parse the word right after the close parenthesis. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: York Sun <yorksun@freescale.com> Acked-by: Dirk Behme <dirk.behme@gmail.com>
2014-12-08kconfig: Fix warning "‘jump’ may be used uninitialized"Peter Kümmel
Warning: In file included from scripts/kconfig/zconf.tab.c:2537:0: scripts/kconfig/menu.c: In function ‘get_symbol_str’: scripts/kconfig/menu.c:590:18: warning: ‘jump’ may be used uninitialized in this function [-Wmaybe-uninitialized] jump->offset = strlen(r->s); Simplifies the test logic because (head && local) means (jump != 0) and makes GCC happy when checking if the jump pointer was initialized. Signed-off-by: Peter Kümmel <syntheticpp@gmx.net> Signed-off-by: Michal Marek <mmarek@suse.cz> [ imported from Linux Kernel, commit 2d5603060967 ] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08Kbuild: introduce Makefile in arch/$ARCH/Daniel Schwierzeck
Introduce a Makefile under arch/$ARCH/ and include it in the top Makefile (similar to Linux kernel). This allows further refactoringi like moving architecture-specific code out of global makefiles, deprecating config variables (CPU, CPUDIR, SOC) or deprecating arch/$ARCH/config.mk. In contrary to Linux kernel, U-Boot defines the ARCH variable by Kconfig, thus the arch Makefile can only included conditionally after the top config.mk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08get_maintainer.pl: fix source tree detectionDaniel Schwierzeck
get_maintainer.pl always fails with following message: ./scripts/get_maintainer.pl: The current directory does not appear to be a linux kernel source tree. This was caused by commit: commit 548b310c68ac99a0330d8b56c797c09ff0742d1e Author: Masahiro Yamada <yamada.m@jp.panasonic.com> Date: Thu Oct 30 15:50:15 2014 +0900 Remove the CREDITS file This file is not maintained these days. We use MAINTAINERS for the maintainership of the supported boards. For dead boards, we have some clues in doc/README.scrapyard and also imperishable history in git-log. Remove CREDITS from source tree detection to fix this. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-25Align embedded device tree correctlySimon Glass
Device trees must be aligned to a 4-byte boundary. This was dropped in the Kbuild conversion. Bring it back, and use 16-byte alignment for good measure. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-24Merge git://git.denx.de/u-boot-dmTom Rini
Conflicts: drivers/serial/serial-uclass.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23spl: fix descending condition to drivers/mtd/nand/Masahiro Yamada
SPL should not reference CONFIG_CMD_NAND to decide whether or not it should build drivers/mtd/nand. CONFIG_CMD_NAND should be only used to select the NAND utility command on the command parser. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23kbuild: Descend into SOC directory from CPU directoryMasahiro Yamada
Some CPUs of some architectures have SOC directories. At present, the build system directly descends into SOC directories from the top Makefile, but it should generally descend into each directory from its parent directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-21dm: spl: Allow driver model to be usedSimon Glass
When enabled, set up driver model for SPL. This allows SPL to use the same drivers as the main U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com>
2014-11-17arm, at91: generate boot.bin file for all atmel SoCHeiko Schocher
generate the boot.bin file for all atmel SoC (arm920, arm926, armv7) Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com> [fix subject] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-12kbuild: Make scripts executableMasahiro Yamada
The Makefiles call the respective interpreter explicitly, but this makes it easier to use the scripts manually. (This commit follows commit 06ed5c2bfaca of Linux Kernel) Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kbuild: sync misc scripts with Linux 3.18-rc1Masahiro Yamada
This commit imports some updates in misc scripts from Linux 3.18-rc1. [1] commit cbb4d3e6510b99522719c5ef0 by Horia Geanta scripts/kernel-doc: handle object-like macros [2] commit 164f0d2efaaef83 by Michal Marek kbuild: Fix handling of backslashes in *.cmd files [3] commit 270a00963cd367214e by Randy Dunlap scripts/kernel-doc: recognize __meminit [4] commit a4954fd7724c0f55361eb5 by Masahiro Yamada kbuild: remove obj-n and lib-n handling [5] commit 5b2389b45d1a9c12b9f by Masahiro Yamada kbuild: simplify build, clean, modbuiltin shorthands Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kconfig: sync kconfig files with Linux 3.18-rc1Masahiro Yamada
This commit imports Kconfig updates from Linux 3.18-rc1. 'kvmconfig' and 'tinyconfig' help message have been commented out since they are unavailable at least now; in the future perhaps we can implement 'tinyconfig' to disable most of CONFIG_CMD_* to create a very small U-Boot image. [1] commit 3aaefce10351 by Josh Triplett x86, platform, kconfig: move kvmconfig functionality to a helper [2] commit 0da1d4a0b951 by Josh Triplett x86: Add "make tinyconfig" to configure the tiniest possible kernel [3] commit c40724d3f381 by Brian Norris kconfig: lxdialog: fix spelling [4] commit 7285996aa000 by Brian Norris kconfig: nconfig: fix multi-byte UTF handling Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kbuild: sync top Makefile with Linux 3.18-rc1Masahiro Yamada
Since Linux 3.15, relative path feature and related fixes, cleanups have been merged to the top Makefile. The relative path feature looks stable enough, so let's import it to U-Boot along with various cleanups. Commits imported from Linux (some need adjustment) are: [1] commit 7e1c04779efd by Michal Marek kbuild: Use relative path for $(objtree) [2] commit 890676c65d69 by Michal Marek kbuild: Use relative path when building in the source tree [3] commit 9da0763bdd82 by Michal Marek kbuild: Use relative path when building in a subdir of the source tree [4] commit c2e28dc975ea by Michal Marek kbuild: Print the name of the build directory [5] commit 066b7ed95580 by Michal Marek kbuild: Do not print the build directory with make -s [6] commit 3f1d9a6cec01 by Michal Marek kbuild: make -s should be used with kernelrelease/kernelversion/image_name [7] commit 7ff525712acf by Masahiro Yamada kbuild: fake the "Entering directory ..." message more simply [8] commit 745a254322c8 by Masahiro Yamada kbuild: use $(Q) for sub-make target [9] commit aa55c8e2f7a3 by Masahiro Yamada kbuild: handle C=... and M=... after entering into build directory [10] commit ab7474ea5361 by Borislav Petkov Kbuild: Ignore GREP_OPTIONS env variable To use relative path feature, tools/Makefile and scripts/Makefile.autoconf must be tweaked. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kbuild: improve multi-objs dependency and cleanupsMasahiro Yamada
Since Linux 3.18-rc1, Kbuild is able to handle multi-objs dependency correctly, which also allows us futher cleanups of some makefiles. This commit imports those commits: [1] commit c8589d1e9e01 by Masahiro Yamada kbuild: handle multi-objs dependency appropriately [2] commit 97e3226e6e98 by Masahiro Yamada kbuild: handle the dependency of multi-objs hostprogs appropriately [3] commit 022af62d0190 by Masahiro Yamada kbuild: refactor script/kconfig/Makefile [4] commit 221ecca6cafe by Masahiro Yamada kbuild: remove redundant clean-files from scripts/kconfig/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kbuild: bug fixes and cleanups of Makefile.hostMasahiro Yamada
This commit imports updates of scripts/Makefile.host from Linux 3.18-rc1. Imported commits are: [1] commit d8d9efe22709 by Masahiro Yamada kbuild: fix a typo in scripts/Makefile.host [2] commit edb950c17de0 by Masahiro Yamada kbuild: fix a bug of C++ host program handling [3] commit 62e2210798ed by Masahiro Yamada kbuild: drop shared library support from Makefile.host [4] commit 663935593915 by Masahiro Yamada kbuild: clean up scripts/Makefile.host [5] commit 1791ff7179f6 by Masahiro Yamada kbuild: clean-up and bug fix of scripts/Makefile.host Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-05sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.Ian Campbell
$ make BOARD_felconfig is more convenient than $ make BOARD_defconfig $ echo CONFIG_SPL_FEL=y >> .config $ echo CONFIG_SPL_FEL=y >> spl/.config Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-04kbuild: do not hide clang warnings during build with W=1Masahiro Yamada
These lines originate in Linux; it looks like Linux folks chose to hide bunch of warnings reported by clang rather than fixing C code. In U-boot, warnings are being fixed thanks to Jeroen's great efforts. Let's stop suppressing clang warnings. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-27Correct two non-functional misspellings "overrided".Robert P. J. Day
2014-10-23kconfig: invoke silentoldconfig if spl, tpl/.config is updatedMasahiro Yamada
When spl/.config is updated by "make spl/menuconfig" or friends, spl/include/config/auto.conf, spl/include/generated/autoconf.h and some other files must be updated by "make silentoldconfig". There is no hook for SPL in the top Makefile, so this commit touches .config when spl/.config is updated to invoke silentoldconfig. Likewise for TPL. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-23kbuild: fix a bug of the u-boot-spl link ruleMasahiro Yamada
cmd_u-boot-spl includes $(PLATFORM_LIBS) which changes when CONFIG_USE_PRIVATE_GCC is updated. The u-boot-spl image should be re-linked if any prerequisite is newer than it or the command line has changed. $(call, if_changed,...) should be used instead of $(call cmd,...). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-10scripts/multiconfig.sh: Fix a typoYork Sun
Fix the spelling of "configs". Signed-off-by: York Sun <yorksun@freescale.com> CC: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-10multiconfig.sh: replace GNU sed specific matchJeroen Hofstee
A SPL/TPL enabled target would was not recognized as such by BSD sed, since it relies on a GNU extension. Instead of or-ing just spell out both matches. Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-10kconfig: fix another bug of "make savedefconfig"Masahiro Yamada
In some cases, the last lines of SPL or TPL are not output to a file. The entries remaining in the "unmatched" variable must be flushed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-25checkpatch: remove unnecessary + after {8,8}Joe Perches
Pick the following commit from Linux kernel: commit 66cb4ee0e52ca721f609fd5eec16187189ae5fda Author: Joe Perches <joe@perches.com> Date: Wed Sep 10 09:40:47 2014 +1000 checkpatch: remove unnecessary + after {8,8} There's a useless "+" use that needs to be removed as perl 5.20 emits a "Useless use of greediness modifier '+'" message each time it's hit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com>
2014-09-24kconfig: remove config_cmd_defaults.hMasahiro Yamada
Now config_cmd_defaults.h is empty so it can be deleted safely. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-16kconfig: add sanity checks for SPL configurationMasahiro Yamada
For the SPL configuration, "make <dir>/<target>" is used. Here, <dir> is either "spl" or "tpl" <target> is one of "config", "menuconfig", "xconfig", etc. This commit adds two checks: [1] If <dir> is given an unsupported subimage, the configuration should error out like this: $ make qpl/menuconfig *** *** "make qpl/menuconfig" is not supported. *** [2] Make sure that "CONFIG_SPL" is enabled in the ".config" before running "make spl/menuconfig. Otherwise, the SPL image is not built at all. Having "spl/.config" makes no sense. In such a case, the configuration should exit with a message: $ make spl/menuconfig *** *** Create ".config" with "CONFIG_SPL" enabled *** before "make spl/menuconfig". *** Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Suggested-by: Simon Glass <sjg@chromium.org>
2014-09-16scripts/Makefile.clean: clean also $(extra-m) and $(extra-)Masahiro Yamada
This commit is a backport from Linux Kernel, commit 9d5db8949f1ecf4019785b04d8986835d3c0e99e, written by me. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-16kconfig: show an error message when defconfig is not foundMasahiro Yamada
When a non-existing defconfig is specified, display an easy-to-understand message (fake the error message on Linux Kernel): $ make foo_defconfig *** *** Can't find default configuration "confis/foo_defconfig"! *** Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-09-16kconfig: fix savedefconfig to handle TPL correctlyMasahiro Yamada
Since 3ff291f371fa9858426774f3732924bacb61ed1c (kconfig: convert Kconfig helper script into a shell script), "make savedefconfig" of TPL boards has not been working. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.o.rg Acked-by: Simon Glass <sjg@chromium.org>
2014-09-16kconfig: fix whitespace handling bug of savedefconfigMasahiro Yamada
Commit 3ff291f371fa9858426774f3732924bacb61ed1c (kconfig: convert Kconfig helper script into a shell script) introduced another regression. Shell usually handles whitespaces as separators, so "make saveconfig" outputs # CONFIG_FOO is not set into: # CONFIG_FOO is not set Whitespaces should not be treated as separators here. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-16kconfig: fix savedefconfig to output empty defconfigMasahiro Yamada
Commit 3ff291f371fa9858426774f3732924bacb61ed1c (kconfig: convert Kconfig helper script into a shell script) introduced a minor regression. make alldefconfig; make savedefconfig should create an empty 'defconfig'. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-09cc-option: also detect unsupported warnings optionsJeroen Hofstee
By default clang will echo a warning if a warning option is unknown. Turning warnings into errors when polling for options also catches such cases and prevents passing arguments to the compiler which cause warnings. cc: Masahiro Yamada <yamada.m@jp.panasonic.com> cc: Tom Rini <trini@ti.com> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-08-28README.kconfig: document backward compatibility "make *_config"Masahiro Yamada
Commit 3ff291f371fa9858426774f3732924bacb61ed1c (kconfig: convert Kconfig helper script into a shell script) restored "<board>_config" target for backward compatibility. It should be documented. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2014-08-28scripts: refetch scripts/setlocalversion from Linux 3.16Masahiro Yamada
Now we have CONFIG_LOCALVERSION and CONFIG_LOCALVERSION_AUTO in Kconfig so we can use scripts/setlocalversion without any adjustment. Copy it from Linux 3.16 as is. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-22kconfig: convert Kconfig helper script into a shell scriptMasahiro Yamada
Commit 51148790 added scripts/multiconfig.py written in Python 2 to adjust Kconfig for U-Boot. It has been hard for Python 3 users because Python 2 and Python 3 are not compatible with each other. We are not happy about adding a new host tool dependency (in this case, Python version dependency) for the core build process. After some discussion, we decided to use only basic tools. The script may get a bit more unreadable by shell scripting, but we believe it is worthwhile. In addition, this commit revives "<board>_config" target that is equivalent to "<board>_defconfig" for backwards compatibility. It is annoying to adjust various projects which use U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Suggested-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Stephen Warren <swarren@nvidia.com>
2014-08-21scripts/Lindent: import from Linux 3.16Masahiro Yamada
2014-08-21scripts: objdiff: sync with Linux 3.16Masahiro Yamada
Import scripts/objdiff improvements from Linux v3.16, which consists of 7 commits written by me. commit 7fa0e6db3cedc9b70d68a4170f1352e2b1aa0f90 scripts: objdiff: support directories for the augument of record command commit 8ac28bee76eec006aac5ba5c418878a607d53a9b scripts: objdiff: fix a comment commit 8b5d0f20d64f00ffd5685879f8eb3659379f5aaa scripts: objdiff: change the extension of disassembly from .o to .dis commit 18165efa8203a34d82f60a1831ea290e7304c654 scripts: objdiff: improve path flexibility for record command commit 1ecc8e489abfdaa6d8d1689f7ff62fdf1adda30c scripts: objdiff: remove unnecessary code commit 5ab370e91af70d5f1b1dbaec78798a2ff236a2d5 scripts: objdiff: direct error messages to stderr commit fd6e12423311697860f30d10398a0f9eb91977d2 scripts: objdiff: get the path to .tmp_objdiff more simply Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21kbuild: sync mixed targets handling with Linux 3.16Masahiro Yamada
"make %_config all" was supported for the first time in U-Boot: commit 53bca5ab kbuild: support simultaneous board configuration and "make all" Surprisingly it had not been working in Linux Kernel for a long time. So I sent back the patch to the Linux Kbuild community and it was accepted with a little code improvement, at commit 9319f453. Now, you can do "make defconfig all" or "make %_defconfig all" in Linux too. This commit updates some scripts to fill the code-diff between Linux and U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
