path: root/scripts
2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-31Remove unused CONFIG_TWL4030_PWMAdam Ford
CONFIG_TWL4030_PWM is not being used by any source, so let's remove the #define and the whitelist entry Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-31serial: stm32x7: Convert CONFIG_STM32X7_SERIAL to KconfigPatrice Chotard
Add CONFIG_STM32X7_SERIAL as a Kconfig option. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2017-07-30Makefile: Don't shadow actual error when compile ASLAndy Shevchenko
If ASL compiler failed by any reason do not produce output C file. Otherwise sequential run of make will shadow the actual error in ASL, i.e. CC board/intel/edison/dsdt.o board/intel/edison/dsdt.c:1:1: error: unterminated comment /* and user has to remove dsdt.c and run make in order to see the error again. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-28usb: xhci: Convert CONFIG_USB_XHCI_PCI to KconfigBin Meng
Add CONFIG_USB_XHCI_PCI as a Kconfig option. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28configs: Remove CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS in all boardsBin Meng
Now that EHCD does not use CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS, remove it in all boards' config files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28configs: Remove CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS in all boardsBin Meng
Now that xHCD does not use CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS, remove it in all boards' config files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-25Convert CONFIG_ENV_IS_IN_ONENAND to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_ONENAND Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-25Convert CONFIG_ENV_IS_IN_REMOTE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_REMOTE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-25Convert CONFIG_ENV_IS_IN_DATAFLASH to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_DATAFLASH Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-25Convert CONFIG_ENV_IS_IN_EEPROM to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_EEPROM Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-25Convert CONFIG_ENV_IS_IN_NVRAM to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_NVRAM Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-12mmc: fsl_esdhc: drop CONFIG_SYS_FSL_ESDHC_FORCE_VSELECTPeng Fan
CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT is not the correct method to set I/O to 1.8. To boards that does not support vqmmc-supply, use vs18_enable in fsl_esdhc_cfg. If regulator is supported, use fixed 1.8V regulator for vqmmc-supply. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: York Sun <york.sun@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-07-11Merge git://git.denx.de/u-boot-dmTom Rini
2017-07-11Convert CONFIG_CMD_SATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11scsi: Drop sym53c8xx driverSimon Glass
This driver is for a PowerPC board that will likely be removed soon. Rather than converting it to driver model, drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11usb: Kconfig: migrate USB_DWC2 to KconfigPhilipp Tomsich
This change migrates the USB_DWC2 configuration item to Kconfig and runs moveconfig to adjust header files and defconfig. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Split off into a separate patch: Ran moveconfig to migrate other boards: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-08powerpc, 8xx: move Serial driver to drivers/serial/Christophe Leroy
At the same time, move to Kconfig Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-08powerpc, 8xx: move FEC Ethernet driver in drivers/netChristophe Leroy
2017-07-08powerpc, 8xx: Migrate to KconfigChristophe Leroy
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-07-08powerpc: Partialy restore core of mpc8xxChristophe Leroy
CS Systemes d'Information (CSSI) manufactures 8xx boards for critical communication systems. Those boards have been running U-Boot since 2010 and will have to be maintained until at least 2027. commit 5b8e76c35ec312a3f73126bd1a2d2c0965b98a9f ("powerpc, 8xx: remove support for 8xx") orphaned those boards by removing support for the mpc8xx CPU. This commit partially restores support for the 8xx, with the following limitations: - Restores support for MPC866 and MPC885 only - Does not restore IDE, PCMCIA, I2C, USB - Does not restore examples - Does not restore POST - Does not restore Ethernet on SCC - Does not restore console on SCC - Does not restore bedbug and kgdb support As the 866 and 885 do not support the following features, they are not restored either: - VIDEO / LCD - RTC clock The CPM uCODE patch is not restored either, because: - 866 and 885 already have support for I2C and SPI relocation without a uCODE patch - relocation of SMC, I2C or SPI is only needed for using SCCs for Ethernet or QMC The dynamic setup/calculation of clocks is removed, we expect the target being use with the clock and PLPRCR register defined in the configuration. All the clock settings for 8xx prior to 866 is removed as well as we now only support 866 and 885. This code is mature and addresses mature boards. Therefore all code enclosed in '#if 0/#endif' and '#if XX_DEBUG/#endif' is unneeded. The following files are not restored by this patch: - arch/powerpc/cpu/mpc8xx/bedbug_860.c - arch/powerpc/cpu/mpc8xx/fec.h - arch/powerpc/cpu/mpc8xx/kgdb.S - arch/powerpc/cpu/mpc8xx/plprcr_write.S - arch/powerpc/cpu/mpc8xx/scc.c - arch/powerpc/cpu/mpc8xx/upatch.c - arch/powerpc/cpu/mpc8xx/video.c - arch/powerpc/include/asm/status_led.h - arch/powerpc/lib/ide.c - arch/powerpc/lib/ide.h - doc/README.MPC866 - drivers/pcmcia/mpc8xx_pcmcia.c - drivers/rtc/mpc8xx.c - drivers/usb/gadget/mpc8xx_udc.c - drivers/video/mpc8xx_lcd.c - examples/standalone/test_burst.c - examples/standalone/test_burst.h - examples/standalone/test_burst_lib.S - examples/standalone/timer.c - include/mpc823_lcd.h - include/usb/mpc8xx_udc.h - post/cpu/mpc8xx/Makefile - post/cpu/mpc8xx/cache.c - post/cpu/mpc8xx/cache_8xx.S - post/cpu/mpc8xx/ether.c - post/cpu/mpc8xx/spr.c - post/cpu/mpc8xx/uart.c - post/cpu/mpc8xx/usb.c - post/cpu/mpc8xx/watchdog.c Some of the restored files are not located in a proper location. In order to keep traceability of the changes, they will be moved to their correct location and moved to Kconfig in a followup patch. This patch also declares CSSI as point of contact for the update of the 8xx platform, as those boards are the only ones still being maintained on the 8xx area. A later patch will add those boards to the tree. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-07wdt: Unify option of timeout valueAndy Shevchenko
There is no need to duplicate same option with different name. Kill HW_WATCHDOG_TIMEOUT_MS in favor of WATCHDOG_TIMEOUT_MSECS. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-07-03drivers, block: remove sil680 driverHeiko Schocher
driver is not used anymore, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-29scripts: config_whitelist: Handle lines with leading spaces/tabsBin Meng
Some Kconfig options are defined in a line with leading spaces/tabs. Update build-whitelist/check-config scripts to handle such cases. Generate a new config_whitelist.txt with new scripts. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-06-27Merge git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/imx6qdl_icore_rqs.h include/configs/imx6ul_geam.h include/configs/imx6ul_isiot.h
2017-06-20arm: zynq: Move CONFIG_SF_DUAL_FLASH to defconfigMike Looijmans
Move the only use of CONFIG_SF_DUAL_FLASH to defconfig. This makes the associated topic_miamiplus.h header obsolete, so remove that as well. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-16board/BuR/brxre1: drop obsolete CONFIG_LCD_NOSTDOUT from config-headerHannes Schmelzer
This define isn't used anymore in the u-boot source tree, so we drop it from the config header. We drop it also from the 'config_whitelist.txt' Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-12powerpc, 5xx: remove support for 5xxHeiko Schocher
There was for long time no activity in the 5xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 5xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8260: remove support for mpc8260Heiko Schocher
There was for long time no activity in the 8260 area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8260, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-09rtc: ds1337: drop "SYS" from config variablesChris Packham
There is some inconsistency between uses of CONFIG_RTC_DS13xx and CONFIG_SYS_RTC_DS13xx. Address this by dropping the "SYS" from these variables. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-05scripts/Makefile.lib: Only apply u-boot.dtsi files in the target directoryTom Rini
We only want to apply files such as 'omap5-u-boot.dtsi', which resides in arch/arm/dts/ to other files in arch/arm/dts/ and not say test/overlay/. Rework the make logic to check for -u-boot.dtsi files in the same directory as their target dts. Cc: Simon Glass <sjg@chromium.org> Reported-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-05samsung: Drop more references fo s3c24x0Simon Glass
This is dead code now. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05samsung: mmc: Drop s3c_sdi driverSimon Glass
This is no-longer used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-06-05t81xx: Migrate TI81XX/TI816X/TI814X symbols to KconfigTom Rini
The symbol CONFIG_TI81XX is used for the parts that are common to the TI816x and TI814x SoCs and are not part of CONFIG_ARCH_OMAP2PLUS nor CONFIG_AM33XX. It however has so few uses that we can just modify the code to check for both and drop the symbol. The symbols CONFIG_TI816X and CONFIG_TI814X are for the repective SoCs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-05ti816x: Rework DDR initialization sequenceTom Rini
The ti816x/am389x SoC is the first generation in what U-Boot calls the "am33xx" family. In the first generation of this family the DDR initialization sequence is quite different from all of the subsequent generations. Whereas with ti814x (second generation) we can easily work the minor differenced between that and am33xx (third generation), our attempts to do this for ti816x weren't sufficient. Rather than add a large amount of #ifdef logic to make this different sequence work we add a new file, ti816x_emif4.c to handle the various required undocumented register writes and sequence and leverage what we can from arch/arm/mach-omap2/am33xx/ddr.c still. As DDR2 has similar problems today but I am unable to test it, we drop the DDR2 defines from the code rather than imply that it works by leaving it. We also remove a bunch of other untested code about changing the speed the DDR runs at. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-04Merge git://git.denx.de/u-boot-fdtTom Rini
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-02fdt: Makefile: Build python libfdt library if neededSimon Glass
This is needed by binman and dtoc, so if those are being used, check that the library is present and complain if not. Make sure that any error appears on stderr so that buildman notices it. This means that the fallback library (which uses fdtget) will not be used anymore and swig will need to be installed to use binman / dtoc. This affects any board which uses binman (currently sunxi and x86) or dtoc (anything that uses CONFIG_SPL_OF_PLATDATA, currently some rockchip boards). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-31Kconfig: Finish migration of hashing commandsDaniel Thompson
Currently these (board agnostic) commands cannot be selected using menuconfig and friends. Fix this the obvious way. As part of this, don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v' and "we have a hashing command" as this makes the Kconfig logic odd. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> [trini: Re-apply, add imply for a few cases, run moveconfig.py, also migrate CRC32_VERIFY] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-31arm: mx6: remove unused config variable CONFIG_SPL_NAND_MXSLothar Waßmann
The config variable CONFIG_SPL_NAND_MXS is only set in include/configs/imx6_spl.h but used nowhere. Remove it. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2017-05-23Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2017-05-22Merge git://git.denx.de/u-boot-sunxiTom Rini
trini: Make Kconfig SPL_xxx entires only show if SPL, so that we don't get Kconfig errors on platforms without SPL, ie sandbox (without SPL). Signed-off-by: Tom Rini <trini@konsulko.com>
