path: root/scripts
2016-12-04Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2016-12-04serial: Drop the s3c24x0 serial driverSimon Glass
This is not used by any boards. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: David Müller <d.mueller@elsoft.ch> Reviewed-by: Jagan Teki <jagan@openedev.com>
2016-12-04arm: Remove VCMA9 boardSimon Glass
This board has not been converted to DM_SERIAL by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: David Müller <d.mueller@elsoft.ch> Reviewed-by: Jagan Teki <jagan@openedev.com>
2016-12-04arm: Remove smdk2410 boardSimon Glass
2016-12-04powerpc: mpc86xx: Convert CONFIG_SYS_FSL_NUM_LAWS to Kconfig optionYork Sun
Use Kconfig instead of defining this macro in header file. Signed-off-by: York Sun <york.sun@nxp.com>
2016-12-03cmd: Convert CMD_BOOTMENUTom Rini
Also convert MENU while we're in here. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-03davinci: omapl138_lcdk: use correct name for CONFIG_SYS_NAND_MASK_ALEFabien Parent
CONFIG_SYS_ALE_MASK is not used anywhere. It has probably been renamed to CONFIG_SYS_NAND_MASK_ALE. Rename it and remove the former from the config_whitelist.txt file. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-03davinci: omapl138_lcdk: use correct name for CONFIG_SYS_NAND_MASK_CLEFabien Parent
CONFIG_SYS_CLE_MASK is not used anywhere. It has probably been renamed to CONFIG_SYS_NAND_MASK_CLE. Rename it and remove the former from the config_whitelist.txt file. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-03davinci: omapl138_lcdk: use correct define for 16 bit NAND chipsFabien Parent
The omapl138_lcdk header defines CONFIG_SYS_NAND_BUSWIDTH_16_BIT while the correct name is CONFIG_SYS_NAND_BUSWIDTH_16BIT. While renaming the only occurrence of CONFIG_SYS_NAND_BUSWIDTH_16_BIT, let's also remove it from the config_whitelist.txt file. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-03ARM: davinci: Move CONFIG_SYS_DA850_DDR_INIT to KconfigFabien Parent
Clean config headers by moving CONFIG_SYS_DA850_DDR_INIT away to a Kconfig file. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-03ARM: davinci: Move CONFIG_SYS_DA850_PLL_INIT to KconfigFabien Parent
Clean config headers by moving CONFIG_SYS_DA850_PLL_INIT away to a Kconfig file. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-03ARM: DRA7x/AM57xx: Get rid of CONFIG_AM57XXNishanth Menon
CONFIG_AM57XX is just an unnecessary macro that is redundant given So, remove the same instead of spreading through out the u-boot source code and getting in the way to maintain common code for DRA7x family. Acked-by: Andrew F. Davis <afd@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-02powerpc: mpc86xx: Move CONFIG_FSL_LAW to KconfigYork Sun
Clean up existing definitions and drop from white list. Signed-off-by: York Sun <york.sun@nxp.com>
2016-12-02script: remove CONFIG_SYS_CCSRBAR_DEFAULT from white listYork Sun
Now all mpc85xx and mpc86xx have converted to use SYS_CCSRBAR_DEFAULT in Kconfig. Drop this macro for LSCH2 and remove from white list. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-29Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2016-11-28spl: add USB Gadget config optionStefan Agner
Introduce USB Gadget config option. This allows to combine Makefile entries for SPL_USBETH_SUPPORT and SPL_DFU_SUPPORT. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Ravi Babu <ravibabu@ti.com>
2016-11-28spl: dfu: move DFU Kconfig to SPL KconfigStefan Agner
The DFU Kconfig menu entries should be part of the SPL Kconfig file. Also avoid using the top level Makefile by moving the config dependent build artifacts to the driver/ and driver/usb/gadget/ Makfiles. With that, DFU can be built again in SPL if CONFIG_SPL_DFU_SUPPORT is enabled. Fixes: 6ad6102246d8 ("usb:gadget: Disallow DFU in SPL for now") Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-11-28colibri_vf: usb gadget: toradex pid is now set genericallyMax Krummenacher
remove now unused CONFIG_TRDX_PID_XXX Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-11-28sunxi: Mele_M5_defconfig: Drop non existing STATUSLED settingHans de Goede
And also remove it from scripts/config_whitelist.txt as the Mele_M5_defconfig was the only one defining it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Jagan Teki <jagan@openedev.com>
2016-11-23powerpc: MPC8641HPCN: Remove macro CONFIG_MPC8641HPCNYork Sun
Use TARGET_MPC8641HPCN from Kconfig instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8641: Remove macro CONFIG_MPC8641York Sun
Replace CONFIG_MPC8641 with ARCH_MPC8641 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8610HPCD: Remove macro CONFIG_MPC8610HPCDYork Sun
Use TARGET_MPC8610HPCD from Kconfig instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8610: Remove macro CONFIG_MPC8610York Sun
Replace CONFIG_MPC8610 with ARCH_MPC8610 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4240: Remove macro CONFIG_PPC_T4240York Sun
Use CONFIG_ARCH_T4240 from Kconfig instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4160: Remove macro CONFIG_PPC_T4160York Sun
Use CONFIG_ARCH_T4160 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4240RDB: Remove macro CONFIG_T4240RDBYork Sun
Use CONFIG_TARGET_T4240RDB instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T4240QDS: Remove macro CONFIG_T4240QDSYork Sun
Use CONFIG_TARGET_T4240QDS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T2080, T2081: Remove macro CONFIG_PPC_T2080 and CONFIG_PPC_T2081York Sun
Use CONFIG_ARCH_T2080 and CONFIG_ARCH_T2081 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T104xRDB: Remove macro CONFIG_T104xRDB and T104xD4RDBYork Sun
CONFIG_T104xRDB is defined in T104xRDB.h, so it is always enabled for all T1040RDB, T1040D4RDB, T1042RDB, T1042D4RDB, T1042RDB_PI. CONFIG_T104XD4RDB is defined for all T1040D4RDB, T1042D4RDB. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1042RDB: Remove macro CONFIG_T1042RDBYork Sun
Use TARGET_T1042RDB instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1042D4RDB: Separate from T1042RDB in KconfigYork Sun
Use TARGET_T1042D4RDB in Kconfig to simplify config options. Remove macro CONFIG_T1042D4RDB. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1042RDB_PI: Split from T1042RDB in KconfigYork Sun
Use separated TARGET_T1042RDB_PI to simplify config options. Remove macro CONFIG_T1042RDB_PI. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1042: Remove macro CONFIG_PPC_T1042York Sun
Replace CONFIG_PPC_T1042 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1040RDB: Remove macro CONFIG_T1040RDBYork Sun
Use CONFIG_TARGET_T1040RDB instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1040D4RDB: Separate from T1040RDB in KconfigYork Sun
Use TARGET_T1040D4RDB in Kconfig to simplify config macros. Replace CONFIG_T1040D4RDB with TARGET_T1040D4RDB and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1040: Remove macro CONFIG_PPC_T1040York Sun
Replace CONFIG_PPC_T1040 with ARCH_T1040 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1024: Remove macro CONFIG_PPC_T1024York Sun
Replace CONFIG_PPC_T1024 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1023: Remove macro CONFIG_PPC_T1023York Sun
Replace CONFIG_PPC_T1023 with ARCH_T1023 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: QEMU_E500: Remove macro CONFIG_QEMU_E500York Sun
Replace CONFIG_QEMU_E500 with ARCH_QEMU_E500 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: B4420: Remove macro CONFIG_PPC_B4420York Sun
Replace CONFIG_PPC_B4420 with ARCH_B4420 in Kconfig and clean up existing macros.
2016-11-23powerpc: B4860QDS: Remove macro CONFIG_B4860QDSYork Sun
Use CONFIG_TARGET_B4860QDS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: B4860: Remove macro CONFIG_PPC_B4860York Sun
Replace CONFIG_PPC_B4860 with ARCH_B4860 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5040DS: Remove macro CONFIG_P5040DSYork Sun
Use CONFIG_TARGET_P5040DS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5040: Remove macro CONFIG_P5040York Sun
Replace CONFIG_P5040 with ARCH_P5040 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5020DS: Remove macro CONFIG_P5020DSYork Sun
Use CONFIG_TARGET_P5020DS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5020: Remove macro CONFIG_PPC_P5020York Sun
Replace CONFIG_PPC_P5020 with ARCH_P5020 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P4080DS: Remove macro CONFIG_P4080DSYork Sun
Use CONFIG_TARGET_P4080DS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P4080: Remove macro CONFIG_PPC_P4080York Sun
Replace CONFIG_PPC_P4080 with ARCH_P4080 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P3041DS: Remove macro CONFIG_P3041DSYork Sun
Use CONFIG_TARGET_P3041DS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P3041: Remove macro CONFIG_PPC_P3041York Sun
Replace CONFIG_PPC_P3041 with ARCH_P3041 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
