path: root/scripts/show-gnu-make
2014-07-29scripts: add scripts/show-gnu-make to get GNU Make command nameMasahiro Yamada
U-Boot is expected to be built on various platforms. We should keep in mind that the command 'make' is not always GNU Make, while all the makefiles are written for GNU Make. For example, on Linux, people generally do: make <board>_config; make But FreeBSD folks do gmake <board>_config; gmake (The command 'make' on FreeBSD is BSD Make, not GNU Make) It is not a good idea to hard-code the command name 'make' in MAKEALL or buildman. They should call this helper script and get the command name for GNU Make. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
