path: root/scripts/kconfig
2021-09-30WS cleanup: remove SPACE(s) followed by TABWolfgang Denk
2021-09-30WS cleanup: remove trailing white spaceWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-07-14kconfig / kbuild: Re-sync with Linux 4.20Tom Rini
Align Kconfig and Kbuild logic to Linux 4.20 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit 587e4a429698 ("kconfig / kbuild: Re-sync with Linux 4.19"). As part of this re-sync, a few related changes from previous Linux releases were found to have been missed and merged in, and are not in the following list. The imported Linux commits are: [From prior to v4.19] b1e0d8b70fa3 kbuild: Fix gcc -x syntax a4353898980c kconfig: add CC_IS_GCC and GCC_VERSION 469cb7376c06 kconfig: add CC_IS_CLANG and CLANG_VERSION [From v4.19 to v4.20] 487c7c7702ab kbuild: prefix Makefile.dtbinst path with $(srctree) unconditionally 0d91bf584fe5 kbuild: remove old check for CFLAGS use 25815cf5ffec kbuild: hide most of targets when running config or mixed targets 00d78ab2ba75 kbuild: remove dead code in cmd_files calculation in top Makefile 23066c3f4e21 Compiler Attributes: enable -Wstringop-truncation on W=1 (gcc >= 8) 37c8a5fafa3b kbuild: consolidate Devicetree dtb build rules 80463f1b7bf9 kbuild: add --include-dir flag only for out-of-tree build 77ec0c20c7e0 kbuild: remove VERSION and PATCHLEVEL from $(objtree)/Makefile 74bc0c09b2da kbuild: remove user ID check in scripts/mkmakefile 4fd61277f662 kbuild: do not pass $(objtree) to scripts/mkmakefile 80d0dda3a4e5 kbuild: simplify command line creation in scripts/mkmakefile fb073a4b473e kbuild: add -Wno-pointer-sign flag unconditionally 9df3e7a7d7d6 kbuild: add -Wno-unused-but-set-variable flag unconditionally 69ea912fda74 kbuild: remove unneeded link_multi_deps 7d0ea2524202 kbuild: use 'else ifeq' for checksrc to improve readability 04c459d20448 kconfig: remove oldnoconfig target 0085b4191f3e kconfig: remove silentoldconfig target 3f80babd9ca4 kbuild: remove unused cc-fullversion variable 2cd3faf87d2d merge_config.sh: Allow to define config prefix 076f421da5d4 kbuild: replace cc-name test with CONFIG_CC_IS_CLANG 6bbe4385d035 kconfig: merge_config: avoid false positive matches from comment lines [From post v4.20] 885480b08469 Makefile: Move -Wno-unused-but-set-variable out of GCC only block There are a number of changes related to additional warnings as well as being able to drop cc-name entirely that have been omitted for now as additional work is required first. Cc: Masahiro Yamada <masahiroy@kernel.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-10kconfig / kbuild: Re-sync with Linux 4.19Tom Rini
Align Kconfig and Kbuild logic to Linux 4.19 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit 5972ff077e0f ("kconfig / kbuild: re-sync with Linux 4.18"). In this particular re-sync in order to keep clang support working a number of related changes needed to be pulled in that had been missed previously. Not all of these changes we easily traceable and so have been omitted from the list below. The imported Linux commits are: [From prior to v4.18] 9f3f1fd29976 kbuild: Add __cc-option macro d7f14c66c273 kbuild: Enable Large File Support for hostprogs 6d79a7b424a5 kbuild: suppress warnings from 'getconf LFS_*' 24403874316a Shared library support 86a9df597cdd kbuild: fix linker feature test macros when cross compiling with Clang 0294e6f4a000 kbuild: simplify ld-option implementation [From v4.18 to v4.19] 96f14fe738b6 kbuild: Rename HOSTCFLAGS to KBUILD_HOSTCFLAGS 10844aebf448 kbuild: Rename HOSTCXXFLAGS to KBUILD_HOSTCXXFLAGS b90a368000ab kbuild: Rename HOSTLDFLAGS to KBUILD_HOSTLDFLAGS 8377bd2b9ee1 kbuild: Rename HOST_LOADLIBES to KBUILD_HOSTLDLIBS f92d19e0ef9b kbuild: Use HOST*FLAGS options from the command line 4ab3b80159d4 kconfig: check for pkg-config on make {menu,n,g,x}config 693359f7ac90 kconfig: rename SYMBOL_AUTO to SYMBOL_NO_WRITE f60b992e30ff kbuild: replace $(LDFLAGS) $(ldflags-y) with $(ld_flags) 2fb9279f2c3e kbuild: change ld_flags to contain LDFLAGS_$(@F) c931d34ea085 arm64: build with baremetal linker target instead of Linux when available 5accd7f3360e kconfig: handle format string before calling conf_message_callback() a2ff4040151a kconfig: rename file_write_dep and move it to confdata.c 0608182ad542 kconfig: split out useful helpers in confdata.c adc18acf42a1 kconfig: remove unneeded directory generation from local*config 79123b1389cc kconfig: create directories needed for syncconfig by itself 16952b77d8b5 kconfig: make syncconfig update .config regardless of sym_change_count d6c6ab93e17f kbuild: remove deprecated host-progs variable 56869d45e364 kconfig: fix the rule of mainmenu_stmt symbol c151272d1687 kconfig: remove unused sym_get_env_prop() function 1880861226c1 kconfig: remove P_ENV property type e3fd9b5384f3 scripts/dtc: consolidate include path options in Makefile 4bf6a9af0e91 kconfig: add build-only configurator targets f1575595d156 kconfig: error out when seeing recursive dependency 5e8c5299d315 kconfig: report recursive dependency involving 'imply' f498926c47aa kconfig: improve the recursive dependency report 98a4afbfafd2 kconfig: fix "Can't open ..." in parallel build 9a9ddcf47831 kconfig: suppress "configuration written to .config" for syncconfig 87a32e624037 kbuild: pass LDFLAGS to recordmcount.pl d503ac531a52 kbuild: rename LDFLAGS to KBUILD_LDFLAGS 217c3e019675 disable stringop truncation warnings for now bc8d2e20a3eb kconfig: remove a spurious self-assignment fd65465b7016 kconfig: do not require pkg-config on make {menu,n}config 5a4630aadb9a ftrace: Build with CPPFLAGS to get -Qunused-arguments Note that this adds new cleanup work to do in that we should adapt the shared library support we have to what is now upstream. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
2020-03-16kconfig / kbuild: re-sync with Linux 4.18Tom Rini
Align Kconfig and Kbuild logic to Linux 4.18 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit e91610da7c8a ("kconfig: re-sync with Linux 4.17-rc4"). A very small number of changes upstream since our sync with v4.17-rc4 that exist in the v4.18 release have already been applied here and have been omitted from the list in this commit (and are readily available in our own git history). The imported Linux commits are: [From prior to v4.17-rc4] 39a33ff80a25 kbuild: remove cc-option-align db547ef19064 Kbuild: don't add obj tree in additional includes b999596b963a Kbuild: don't add ../../ to include path [From v4.17 to v4.18] b3aa58d2e85d fixdep: suppress consecutive / from file paths in dependency list files 74656b682902 kbuild: disable new dtc graph and unit-address warnings 74d931716151 genksyms: remove symbol prefix support e6ecfb45072c kbuild: do not display CHK for filechk 0b669a5076fd kconfig: refactor Qt package checks for building qconf b464ef583dc7 kconfig: refactor GTK+ package checks for building gconf 1c5af5cf9308 kconfig: refactor ncurses package checks for building mconf and nconf 694c49a7c01c kconfig: drop localization support 96f60dfa5819 trace: Use -mcount-record for dynamic ftrace bb222ceeb327 kconfig: remove string expansion in file_lookup() 96d8e48da55a kconfig: remove string expansion for mainmenu after yyparse() 5b31a9746756 kconfig: remove sym_expand_string_value() 137c0118a900 kconfig: make default prompt of mainmenu less specific e298f3b49def kconfig: add built-in function support 2fd5b09c201e kconfig: add 'shell' built-in function 9de071536c87 kconfig: begin PARAM state only when seeing a command keyword 9ced3bddec08 kconfig: support user-defined function and recursively expanded variable 1175c02506ff kconfig: support simply expanded variable ed2a22f277c6 kconfig: support append assignment operator 82bc8bd82e5c kconfig: expand lefthand side of assignment statement 1d6272e6fe43 kconfig: add 'info', 'warning-if', and 'error-if' built-in functions a702a6176e2f kconfig: add 'filename' and 'lineno' built-in variables 915f64901eb3 kconfig: error out if a recursive variable references itself 2bece88f89fa kconfig: test: add Kconfig macro language tests 21c54b774744 kconfig: show compiler version text in the top comment 59f7b5847b0c kbuild: $(CHECK) doesnt need NOSTDINC_FLAGS twice 145167650b96 kbuild: add endianness flag to CHEKCFLAGS 1f2f01b122d7 kbuild: add machine size to CHECKFLAGS d6a0c8a1326b kconfig: Add testconfig into make help output bb6d83dde191 kbuild: Move last word of nconfig help to the previous line 8593080c0fcf kconfig: fix localmodconfig ed7d40bc67b8 tracing: Fix SKIP_STACK_VALIDATION=1 build due to bad merge with -mrecord-mcount b2d00d7c61c8 kconfig: fix line numbers for if-entries in menu tree ecd53ac2f2c6 kconfig: handle P_SYMBOL in print_symbol() 73d1c580f92b kconfig: loop boundary condition fix 48f6e3cf5bc6 kbuild: do not drop -I without parameter bd412d81b7ea kbuild: .PHONY is not a variable, but PHONY is 6916162c7308 kbuild: remove duplicated comments about PHONY Cc: Masahiro Yamada <masahiroy@kernel.org> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
2018-07-25kconfig: Avoid format overflow warning from GCC 8.1Luis Araneda
cherry-pick kernel commit 2ae89c7 (2018-06-05) to avoid warnings when compiling with GCC 8.1 In file included from scripts/kconfig/zconf.tab.c:2486: scripts/kconfig/confdata.c: In function ‘conf_write’: scripts/kconfig/confdata.c:771:22: warning: ‘%s’ directive writing likely 7 or more bytes into a region of size between 1 and 4097 [-Wformat-overflow=] sprintf(newname, "%s%s", dirname, basename); ^~ scripts/kconfig/confdata.c:771:19: note: assuming directive output of 7 bytes sprintf(newname, "%s%s", dirname, basename); ^~~~~~ scripts/kconfig/confdata.c:771:2: note: ‘sprintf’ output 1 or more bytes (assuming 4104) into a destination of size 4097 sprintf(newname, "%s%s", dirname, basename); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ scripts/kconfig/confdata.c:774:23: warning: ‘.tmpconfig.’ directive writing 11 bytes into a region of size between 1 and 4097 [-Wformat-overflow=] sprintf(tmpname, "%s.tmpconfig.%d", dirname, (int)getpid()); ^~~~~~~~~~~ scripts/kconfig/confdata.c:774:3: note: ‘sprintf’ output between 13 and 4119 bytes into a destination of size 4097 sprintf(tmpname, "%s.tmpconfig.%d", dirname, (int)getpid()); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Luis Araneda <luaraneda@gmail.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-05-31kconfig: re-sync with Linux 4.17-rc4Eugeniu Rosca
Align Kconfig to Linux 4.17-rc4 with minimal impact on non-kconfig files. Previous Kconfig sync was done by commit bf7ab1e70fd762 ("kconfig: re-sync with Linux 4.10") and it achieved almost perfect alignment with a few (intended) exceptions, caused by below U-boot commits: [A] v2015.04 5f9eb2207500 ("kbuild: remove scripts/multiconfig.sh") [B] v2015.07 20c20826efab ("Kconfig: Enable usage of escape char '\' in string values") [C] v2016.01 da58dec86616 ("Various Makefiles: Add SPDX-License-Identifier tags") [D] v2016.03 5b8031ccb4ed ("Add more SPDX-License-Identifier tags") [E] v2016.03 192bc6948b02 ("Fix GCC format-security errors and convert sprintfs.") Here is the list of Kconfig commits which followed the v4.10 alignment: [F] v2018.01 0931ed3c0d0f ("kconfig/symbol.c: use correct pointer type argument for sizeof") [G] v2018.03 1414e09b4f25 ("kconfig: revert change that was not needed for -Wformat-security") [H] v2018.05 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style") Commit [F] was subsequently applied to Linux kernel as commit [I] with the same patch id, so it won't contribute to further misalignment. [I] v4.15-rc1 88127dae6ed9 ("kconfig/symbol.c: use correct pointer type argument for sizeof") Commit [G] is a Kconfig-specific revert of commit [E]. Commit [H] relocated and reformatted the license doing no functional change. In summary, the only functional change that makes U-boot Kconfig diverge from Linux Kconfig is commit [B]. After a brief analysis, the purpose of [B] seems to be placing "\n" literals in string symbols like CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" in order to pass them directly to printf and expect correct output at runtime. Currently, Linux doesn't seem to have this requirement, so for the moment [B] looks like a U-boot specific feature/fix. From point of view of further Kconfig alignment and backporting efforts, it is highly desired that commits like [B] are propagated to Linux and any Kconfig fixes/features are contributed to Linux kernel first. This specific Kconfig re-sync just keeps [B] in place. Contrary to 4.10 Kconfig re-sync (which achieves zero non-kconfig changes), 4.17-rc4 re-sync does some amount of updates in Kbuild (striving to keep them at minimum), due to a number of reasons: * Kbuild is affected by the removal of Kconfig "*shipped" files and now requires flex and bison pre-installed on the host. * PYTHON{2,3} variables are defined in top-level Makefile as prerequisite for running the newly developed Kconfig unit tests. * silentoldconfig becomes an "internal implementation detail" deprecated for external use, being renamed to syncconfig. The exact non-kconfig files touched by this commit are: $ git show --format="" --stat -- ':!scripts/kconfig' .gitignore | 2 ++ Makefile | 9 +++++++-- scripts/Makefile.build | 11 +++++++++++ scripts/Makefile.lib | 41 ++++++++++++----------------------------- The imported Linux commits touching the above files are: c054be10ffdbd5 ("remove gperf left-overs from build system") 73a4f6dbe70a1b ("kbuild: add LEX and YACC variables") 033dba2ec06c47 ("kbuild: prepare to remove C files pre-generated by flex and bison") eea199b445f64c ("kbuild: remove unnecessary LEX_PREFIX and YACC_PREFIX") e71de5ee08dcb0 ("kbuild: remove remaining use of undefined YACC_PREFIX") d59fbbd09d5d6b ("kbuild: replace hardcoded bison in cmd_bison_h with $(YACC)") 911a91c39cabcb H ("kconfig: rename silentoldconfig to syncconfig") 59889300274569 (".gitignore: move *.lex.c *.tab.[ch] patterns to the top-level .gitignore") 9a8dfb394c0467 ("kbuild: clean up *.lex.c and *.tab.[ch] patterns from top-level Makefile") 833e622459432e H ("genksyms: generate lexer and parser during build instead of shipping") b23d1a241f4eb4 H ("kbuild: add %.lex.c and %.tab.[ch] to 'targets' automatically") e9781b52d4e0e3 H ("kbuild: add PYTHON2 and PYTHON3 variables") The commits marked with 'H' are assessed as "hard" (build will fail) prerequisites and the rest of them are assessed as "soft" prerequisites for the re-sync. In spite of relatively high number of non-H commits, they belong to this Kconfig update topic-wise and decrease the number of cherry pick conflicts for many commits in this series. Additional effort can be put in eliminating the soft prerequisites, if really needed. The commits which contributed to this Kconfig re-sync are listed below. Whenever a conflict resolution has been performed (mostly by hand, but sometimes automatically by git), it is revealed by the '!' sign in the second column, which means a patch id mismatch between Linux and U-boot commits: 9be3213b14d44f ("gconfig: remove misleading parentheses around a condition") ff85a1a80e0034 ("kconfig: Check for libncurses before menuconfig") ad8181060788c8 ("kconfig: fix sparse warnings in nconfig") cb77f0d623ff33 ! ("scripts: Switch to more portable Perl shebang") bb3290d91695bb ! ("Remove gperf usage from toolchain") c054be10ffdbd5 ("remove gperf left-overs from build system") b24413180f5600 ! ("License cleanup: add SPDX GPL-2.0 license identifier to files with no license") 9059a3493efea6 ! ("kconfig: fix relational operators for bool and tristate symbols") 2c37e08464a850 ("kconfig: Warn if choice default is not in choice") 33ca1a24866373 ("kconfig: Document the 'menu' struct") 52aede4ba5efd1 ("kconfig: Document the 'symbol' struct") c873443430ebd1 ("kconfig: Sync zconf.y with zconf.tab.c_shipped") 9a826842ff2fbd ("kconfig: Rename menu_check_dep() to rewrite_m()") fa8cedaef814ce ("kconfig: Clarify expression rewriting") f77850d3fe0c96 ("kconfig: Clean up modules handling and fix crash") e3b03bf29d6b99 ("kconfig: display recursive dependency resolution hint just once") 73a4f6dbe70a1b ! ("kbuild: add LEX and YACC variables") 033dba2ec06c47 ! ("kbuild: prepare to remove C files pre-generated by flex and bison") 29c833061c1d8c ("kconfig: generate lexer and parser during build instead of shipping") 26e47a3c11a25c ("kconfig: Don't leak symbol names during parsing") 24161a6711c945 ("kconfig: Don't leak 'source' filenames during parsing") bc28fe1d5ede88 ("kconfig: Don't leak 'option' arguments during parsing") 0724a7c32a54e3 ("kconfig: Don't leak main menus during parsing") ae7440ef0c8013 ("kconfig: Fix automatic menu creation mem leak") 5b1374b3b3c2fc ("kconfig: Fix expr_free() E_NOT leak") 7cf33f88e29410 ("kconfig: Fix choice symbol expression leak") 05cccce580456d ("kconfig: Document automatic submenu creation code") 0735f7e5def2ab ("kconfig: Document important expression functions") df60f4b92d3d0b ("kconfig: Remove menu_end_entry()") b92d804a51796b ("kconfig: drop 'boolean' keyword") 6479f327dea60d ("kconfig: Warn if there is more than one help text") 52e58a3caeba5d ("kconfig: make input_mode static") 5a3dc717b3c785 ("kconfig: make xfgets() really static") 84dd95d4f87a0d ("kconfig: make conf_unsaved a local variable of conf_read()") 765f4cdef6f80d ("kconfig: use default 'yy' prefix for lexer and parser") eea199b445f64c ("kbuild: remove unnecessary LEX_PREFIX and YACC_PREFIX") e71de5ee08dcb0 ("kbuild: remove remaining use of undefined YACC_PREFIX") d59fbbd09d5d6b ! ("kbuild: replace hardcoded bison in cmd_bison_h with $(YACC)") 3e41ba05b6d60c ("kconfig: Document SYMBOL_OPTIONAL logic") d3465af60f4471 ("kconfig: Clarify choice dependency propagation") 9d1a9e8bc18bea ("kconfig: Document 'if' flattening logic") b53688014e3325 ("kconfig: Clarify menu and 'if' dependency propagation") d0fd0428ecf04b ("kconfig: fix make xconfig when gettext is missing") 312ee68752faaa ("kconfig: announce removal of oldnoconfig if used") 1ccb27143360bd ("kconfig: make "Selected by:" and "Implied by:" readable") cedd55d49dee94 ! ("kconfig: Remove silentoldconfig from help and docs; fix kconfig/conf's help") 1b9eda2e4892cb ("kconfig: Warn if help text is blank") cb67ab2cd2b8ab ("kconfig: do not write choice values when their dependency becomes n") 4f208f392103e8 ("kconfig: show '?' prompt even if no help text is available") cd58a91def2acc ("kconfig: remove 'config*' pattern from .gitignnore") d2a04648a5dbc3 ("kconfig: remove check_stdin()") f3ff6fb5db68bc ("kconfig: echo stdin to stdout if either is redirected") 9e3e10c725360b ("kconfig: send error messages to stderr") d717f24d8c6808 ("kconfig: add xrealloc() helper") 523ca58b7db2e3 ("kconfig: remove const qualifier from sym_expand_string_value()") cd81fc82b93fa4 ("kconfig: add xstrdup() helper") f4bc1eefc1608e ("kconfig: set SYMBOL_AUTO to the symbol marked with defconfig_list") bf0bbdcf100322 ("kconfig: Don't leak choice names during parsing") 1a90ce36c6eff6 ("kconfig: Update ncurses package names for menuconfig") 5ae6fcc4bb82bd ("kconfig: fix line number in recursive inclusion error message") 07a422bb213adb ! ("kbuild: restore autoksyms.h touch to the top Makefile") 9a47ceec543bfb ("kconfig: clean-up reverse dependency help implementation") d9119b5925a03b ("kconfig: Print reverse dependencies in groups") f467c5640c29ad ("kconfig: only write '# CONFIG_FOO is not set' for visible symbols") 59a80b5e892dde ("kconfig: do not call check_conf() for olddefconfig") 4bb3a5b085cd6f ("kconfig: remove unneeded input_mode test in conf()") 99f0b6578bab44 ("kconfig: remove redundant input_mode test for check_conf() loop") 2aad9b89621386 ("kconfig: hide irrelevant sub-menus for oldconfig") 81d2bc2273052e ("kconfig: invoke oldconfig instead of silentoldconfig from local*config") 911a91c39cabcb ! ("kconfig: rename silentoldconfig to syncconfig") 2a61625835c7c8 ! ("kconfig: remove redundant streamline_config.pl prerequisite") 022a4bf6b59dfd ("kconfig: tests: add framework for Kconfig unit testing") 1903c511905984 ("kconfig: tests: add basic choice tests") 49ac3c0c3aa3b7 ("kconfig: tests: test automatic submenu creation") b76960c0f6b25d ("kconfig: tests: test if new symbols in choice are asked") 930c429a656fdb ("kconfig: tests: check unneeded "is not set" with unmet dependency") ee236610653ede ("kconfig: tests: check visibility of tristate choice values in y choice") beaaddb625400e ("kconfig: tests: test defconfig when two choices interact") 3e4888c2e3d77d ("kconfig: tests: test randconfig for choice in choice") 29c434f367ea7b ("kconfig: tests: test if recursive dependencies are detected") e2c75e7667c737 ("kconfig: tests: test if recursive inclusion is detected") f622f827958162 ("kconfig: warn unmet direct dependency of tristate symbols selected by y") f8f69dc0b4e070 ("kconfig: make unmet dependency warnings readable") 26561514cc9def ("kconfig: do not include both curses.h and ncurses.h for nconfig") 32a94b8b0c3e5a ("kconfig: remove duplicated file name and lineno of recursive inclusion") 379a8eb8eb1a55 ("kconfig: detect recursive inclusion earlier") 18492685e479fd ("kconfig: use yylineno option instead of manual lineno increments") 59889300274569 ! (".gitignore: move *.lex.c *.tab.[ch] patterns to the top-level .gitignore") 9a8dfb394c0467 ! ("kbuild: clean up *.lex.c and *.tab.[ch] patterns from top-level Makefile") 833e622459432e ! ("genksyms: generate lexer and parser during build instead of shipping") b23d1a241f4eb4 ! ("kbuild: add %.lex.c and %.tab.[ch] to 'targets' automatically") 17baab68d337a0 ("kconfig: extend output of 'listnewconfig'") e9781b52d4e0e3 ! ("kbuild: add PYTHON2 and PYTHON3 variables") The current Kconfig update generates below build-time warnings: YACC scripts/dtc/dtc-parser.tab.h scripts/dtc/dtc-parser.y: warning: 3 shift/reduce conflicts [-Wconflicts-sr] YACC scripts/dtc/dtc-parser.tab.c scripts/dtc/dtc-parser.y: warning: 3 shift/reduce conflicts [-Wconflicts-sr] This seems to happen because the Kbuild updates apparently didn't make room for both "*shipped"-based builds and flex/bison-based builds. A similar problem has been reported for genksyms parser in v4.17-rc1 commit 833e622459432e ("genksyms: generate lexer and parser during build instead of shipping"). I have figured out empirically that the warnings are healed after updating the in-tree U-boot DTC to upstream v1.4.6-9, same as done by Linux v4.17-rc1 commit 9130ba88464032 ("scripts/dtc: Update to upstream version v1.4.6-9-gaadd0b65c987"). Whether fixing the DTC-related yacc warnings should be done together with the Kconfig re-sync, I would like to hear from community. My testing was limited to: - make defconfig all - make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- r8a7795_ulcb_defconfig all - comparing .config before and after the re-sync - running the newly imported Kconfig unit tests as seen below: $ make testconfig Tested-by: Petr Vorel <petr.vorel@gmail.com> ============================= test session starts ============================= scripts/kconfig/tests/auto_submenu/__init__.py::test PASSED [ 7%] scripts/kconfig/tests/choice/__init__.py::test_oldask0 PASSED [ 14%] scripts/kconfig/tests/choice/__init__.py::test_oldask1 PASSED [ 21%] scripts/kconfig/tests/choice/__init__.py::test_allyes PASSED [ 28%] scripts/kconfig/tests/choice/__init__.py::test_allmod PASSED [ 35%] scripts/kconfig/tests/choice/__init__.py::test_allno PASSED [ 42%] scripts/kconfig/tests/choice/__init__.py::test_alldef PASSED [ 50%] scripts/kconfig/tests/choice_value_with_m_dep/__init__.py::test PASSED [ 57%] scripts/kconfig/tests/err_recursive_inc/__init__.py::test PASSED [ 64%] scripts/kconfig/tests/inter_choice/__init__.py::test PASSED [ 71%] scripts/kconfig/tests/new_choice_with_dep/__init__.py::test PASSED [ 78%] scripts/kconfig/tests/no_write_if_dep_unmet/__init__.py::test PASSED [ 85%] scripts/kconfig/tests/rand_nested_choice/__init__.py::test PASSED [ 92%] scripts/kconfig/tests/warn_recursive_dep/__init__.py::test PASSED [100%] ========================== 14 passed in 0.34 seconds ========================== Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Petr Vorel <petr.vorel@gmail.com>
2018-01-29kconfig: revert change that was not needed for -Wformat-securityMasahiro Yamada
Recent GCC versions warn if the format string is not a literal because the compiler cannot check the argument validity at compile time. Commit 192bc6948b02 ("Fix GCC format-security errors and convert sprintfs.") blindly replaced sprintf() with strcpy(), including many cases where the format parameter is a string literal. For the kconfig change: sprintf(header, " "); ..., here the format parameter is a string literal " ", so it is definitely equivalent to: strcpy(header, " "); Of course, if the 'header' did not have enough length for containing " ", it would be a security problem, but another problem. (in this case, the 'header' is 4 byte length buffer, so it is not a problem at all.) The kconfig code is kept as synced with Linux as possible, but this change made the code out-of-sync for nothing. Just reverting. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-20kconfig/symbol.c: use correct pointer type argument for sizeofHeinrich Schuchardt
sym_arr is of type struct symbol **. So in malloc we need sizeof(struct symbol *). The problem was indicated by coccinelle. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-02-12kconfig: re-sync with Linux 4.10Masahiro Yamada
Re-sync all files under the scripts/kconfig directory with Linux 4.10. Some parts include U-Boot own modification. I made sure to not revert the following commits: 5b8031ccb4ed ("Add more SPDX-License-Identifier tags") 192bc6948b02 ("Fix GCC format-security errors and convert sprintfs.") da58dec86616 ("Various Makefiles: Add SPDX-License-Identifier tags") 20c20826efab ("Kconfig: Enable usage of escape char '\' in string values") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-14Fix GCC format-security errors and convert sprintfs.Ben Whitten
With format-security errors turned on, GCC picks up the use of sprintf with a format parameter not being a string literal. Simple uses of sprintf are also converted to use strcpy. Signed-off-by: Ben Whitten <ben.whitten@gmail.com> Acked-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-07-27kconfig: sync with Linux 4.1Masahiro Yamada
Update the files under scripts/kconfig/ to match Linux 4.1. Some Kconfig sources have diverged from those in the kernel, so commit-base syncing was done not to lose U-Boot specific updates. The commits cherry-picked from Linux are: [1] commit be8af2d54a66911693eddc556e4f7a866670082b Author: Bjørn Forsman <bjorn.forsman@gmail.com> kconfig/lxdialog: get ncurses CFLAGS with pkg-config [2] commit 3943f42c11896ce82ad3da132c8a5630313bdd0e Author: Andrey Utkin <andrey.krieger.utkin@gmail.com> Replace mentions of "list_struct" to "list_head" [3] commit e4e458b45c5861808674eebfea94cee2258bb2ea Author: Arjun Sreedharan <arjun024@gmail.com> calloc/xcalloc: Fix argument order [4] commit 09950bc256e3628d275f90e016e6f5a039fbdcab Author: Olof Johansson <olof@lixom.net> merge_config.sh: Display usage if given too few arguments [5] commit b6a2ab2cd4739a9573ed41677e53171987b8da34 Author: Colin Ian King <colin.king@canonical.com> kconfig: use va_end to match corresponding va_start [6] commit 70529b1a1784503169416df19ce3d68746401340 Author: Michal Marek <mmarek@suse.cz> kconfig: Get rid of the P() macro in headers [7] commit 463157444e377bf9b279101b1f16a94c4648c03a Author: Michal Marek <mmarek@suse.cz> kconfig: Remove dead code [8] commit ad8d40cda3ad22ad9e8863d55a5c88f85c0173f0 Author: Michal Marek <mmarek@suse.cz> kconfig: Remove unnecessary prototypes from headers [9] commit de4619937229378e81f95e99c9866acc8e207d34 Author: Masahiro Yamada <yamada.masahiro@socionext.com> kbuild: mergeconfig: fix "jobserver unavailable" warning [10] commit b9fe99c5b994c6ddc57780993966b18899526c0b Author: Masahiro Yamada <yamada.masahiro@socionext.com> kbuild: mergeconfig: move an error check to merge_config.sh [11] commit 371cfd4ff0611d8bc5d18bbb9cc6a2bc3d56cd3d Author: Masahiro Yamada <yamada.masahiro@socionext.com> kbuild: mergeconfig: remove redundant $(objtree) [12] commit 3a975b8cfcbe026b535f83bde9a3c009bae214f9 Author: Masahiro Yamada <yamada.masahiro@socionext.com> merge_config.sh: improve indentation [13] commit bc8f8f5fc47cd02c2c5f3580dac2fe6695af1edd Author: Masahiro Yamada <yamada.masahiro@socionext.com> merge_config.sh: rename MAKE to RUNMAKE [14] commit 63a91033d52e64a22e571fe84924c0b7f21c280d Author: Masahiro Yamada <yamada.masahiro@socionext.com> kbuild: add generic mergeconfig target, %.config [15] commit 1cba0c305758c3c1786ecaceb03e142c95a4edc9 Author: Michal Marek <mmarek@suse.cz> kconfig: Simplify Makefile [16] commit 0a1f00a1c86421cc07cec87011c7cf4df68ee54b Author: Michal Marek <mmarek@suse.cz> kconfig: Do not print status messages in make -s mode Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Bjørn Forsman <bjorn.forsman@gmail.com> Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Arjun Sreedharan <arjun024@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-06-08Kconfig: Enable usage of escape char '\' in string valuesStefan Roese
I might have missed something, but I failed to use the escape char '\' in strings. To pass a printf format string like "foo %d bar\n" via Kconfig to the code. Right now its not possible to use the escape character '\' in Kconfig string values correctly to e.g. set this string value "test output\n". The '\n' will be converted to 'n'. The current implementation removes some of the '\' chars from the input string in conf_set_sym_val(). Examples: '\' -> '' '\\' -> '\' '\\\' -> '\' '\\\\' -> '\\' ... And then doubles the backslash chars in the output string in sym_escape_string_value(). Example: '\' -> '' -> '' '\\' -> '\' -> '\\' '\\\' -> '\' -> '\\' '\\\\' -> '\\' -> '\\\\' ... As you see in these examples, its impossible to generate a single '\' charater in the output string as its needed for something like '\n'. This patch now changes this behavior to not drop some backslashes in conf_set_sym_val() and to not add new backslashes in the resulting output string. Removing the function sym_escape_string_value() completely as its not needed anymore. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com>
2015-03-28kbuild: remove scripts/multiconfig.shMasahiro Yamada
We have switched to the single .config configuration system, the same one as used in Linux Kernel. The necessary glue code is small enough now, so move it to the top-level Makefile and scripts/kconfig/Makefile, and then delete scripts/multiconfig.sh. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-02kconfig: remove unneeded U-Boot extension codeMasahiro Yamada
This code was introduced to support the multiple .config configuration in U-Boot. We do not need it any more. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08kconfig: Fix warning "‘jump’ may be used uninitialized"Peter Kümmel
Warning: In file included from scripts/kconfig/zconf.tab.c:2537:0: scripts/kconfig/menu.c: In function ‘get_symbol_str’: scripts/kconfig/menu.c:590:18: warning: ‘jump’ may be used uninitialized in this function [-Wmaybe-uninitialized] jump->offset = strlen(r->s); Simplifies the test logic because (head && local) means (jump != 0) and makes GCC happy when checking if the jump pointer was initialized. Signed-off-by: Peter Kümmel <syntheticpp@gmx.net> Signed-off-by: Michal Marek <mmarek@suse.cz> [ imported from Linux Kernel, commit 2d5603060967 ] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-12kbuild: Make scripts executableMasahiro Yamada
The Makefiles call the respective interpreter explicitly, but this makes it easier to use the scripts manually. (This commit follows commit 06ed5c2bfaca of Linux Kernel) Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kconfig: sync kconfig files with Linux 3.18-rc1Masahiro Yamada
This commit imports Kconfig updates from Linux 3.18-rc1. 'kvmconfig' and 'tinyconfig' help message have been commented out since they are unavailable at least now; in the future perhaps we can implement 'tinyconfig' to disable most of CONFIG_CMD_* to create a very small U-Boot image. [1] commit 3aaefce10351 by Josh Triplett x86, platform, kconfig: move kvmconfig functionality to a helper [2] commit 0da1d4a0b951 by Josh Triplett x86: Add "make tinyconfig" to configure the tiniest possible kernel [3] commit c40724d3f381 by Brian Norris kconfig: lxdialog: fix spelling [4] commit 7285996aa000 by Brian Norris kconfig: nconfig: fix multi-byte UTF handling Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kbuild: improve multi-objs dependency and cleanupsMasahiro Yamada
Since Linux 3.18-rc1, Kbuild is able to handle multi-objs dependency correctly, which also allows us futher cleanups of some makefiles. This commit imports those commits: [1] commit c8589d1e9e01 by Masahiro Yamada kbuild: handle multi-objs dependency appropriately [2] commit 97e3226e6e98 by Masahiro Yamada kbuild: handle the dependency of multi-objs hostprogs appropriately [3] commit 022af62d0190 by Masahiro Yamada kbuild: refactor script/kconfig/Makefile [4] commit 221ecca6cafe by Masahiro Yamada kbuild: remove redundant clean-files from scripts/kconfig/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-27Correct two non-functional misspellings "overrided".Robert P. J. Day
2014-07-30kconfig: switch to KconfigMasahiro Yamada
This commit enables Kconfig. Going forward, we use Kconfig for the board configuration. mkconfig will never be used. Nor will include/config.mk be generated. Kconfig must be adjusted for U-Boot because our situation is a little more complicated than Linux Kernel. We have to generate multiple boot images (Normal, SPL, TPL) from one source tree. Each image needs its own configuration input. Usage: Run "make <board>_defconfig" to do the board configuration. It will create the .config file and additionally spl/.config, tpl/.config if SPL, TPL is enabled, respectively. You can use "make config", "make menuconfig" etc. to create a new .config or modify the existing one. Use "make spl/config", "make spl/menuconfig" etc. for spl/.config and do likewise for tpl/.config file. The generic syntax of configuration targets for SPL, TPL is: <target_image>/<config_command> Here, <target_image> is either 'spl' or 'tpl' <config_command> is 'config', 'menuconfig', 'xconfig', etc. When the configuration is done, run "make". (Or "make <board>_defconfig all" will do the configuration and build in one time.) For futher information of how Kconfig works in U-Boot, please read the comment block of scripts/multiconfig.py. By the way, there is another item worth remarking here: coexistence of Kconfig and board herder files. Prior to Kconfig, we used C headers to define a set of configs. We expect a very long term to migrate from C headers to Kconfig. Two different infractructure must coexist in the interim. In our former configuration scheme, include/autoconf.mk was generated for use in makefiles. It is still generated under include/, spl/include/, tpl/include/ directory for the Normal, SPL, TPL image, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-07-30kconfig: import Kconfig files from Linux 3.16-rc7Masahiro Yamada
Import - scripts/kconfig/* - include/linux/kconfig.h from Linux 3.16-rc7. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
